APM32E030的IWDT驱动
本帖最后由 口天土立口 于 2025-9-7 18:32 编辑APM32E030拥有一个独立看门狗,此看门狗可用于监控程序的运行。
驱动代码如下:
/* LSI理论: 40KHz,实际值有差异 */
/* PSC = 4 -> 10KHz = 100us, CNTRLD = 0 ~ 4095-> 100us ~ 409.6ms */
/* PSC = 8 -> 5KHz = 200us, CNTRLD = 0 ~ 4095-> 200us ~ 819.2ms */
/* PSC = 16 -> 2.5KHz = 400us, CNTRLD = 0 ~ 4095-> 400us ~ 1638.4ms */
/* PSC = 32 -> 1.25KHz = 800us, CNTRLD = 0 ~ 4095-> 800us ~ 3276.8ms */
/* PSC = 64 -> 625Hz = 1600us, CNTRLD = 0 ~ 4095-> 1600us ~ 6553.6ms */
/* PSC = 128 -> 312.5Hz = 3200us, CNTRLD = 0 ~ 4095-> 3200us ~ 13107.2ms */
/* PSC = 256 -> 156.25Hz = 6400us, CNTRLD = 0 ~ 4095-> 6400us ~ 26214.4ms */
* @brief 独立看门狗初始化
* @param timeout_ms: 看门狗超时时间
* is_debug_stop: 调试是否停止
* @retval None
void bsp_iwdt_init(uint16_t timeout_ms, uint8_t is_debug_stop)
uint32_t iwdt_clk = 40000; /* 独立看门狗时钟为LSI 40KHz */
IWDT_DIV_T div = IWDT_DIV_4;
uint16_t reload = 0;
float tmp = 0.0f;
/* 最大26s超时时间 */
if (timeout_ms > 26000) {
return ;
/* 800ms以内 */
if (timeout_ms <= 800) {
div = IWDT_DIV_8;
tmp = (float)iwdt_clk / 8; /* 计数频率 */
tmp = 1000.0f / tmp; /* ms */
reload = (float)timeout_ms / tmp;
/* 3s以内 */
} else if (timeout_ms <= 3000) {
div = IWDT_DIV_32;
tmp = (float)iwdt_clk / 32; /* 计数频率 */
/* 26s以内 */
} else {
div = IWDT_DIV_256;
tmp = (float)iwdt_clk / 256; /* 计数频率 */
/* 清独立看门狗复位标志 */
if (RCM_ReadStatusFlag(RCM_FLAG_IWDTRST) != RESET) {
RCM_ClearStatusFlag();
IWDT_EnableWriteAccess();
IWDT_ConfigDivider(div);
IWDT_ConfigReload(reload);
IWDT_Refresh();
IWDT_Enable();
/* 调试时看门狗计数器是否停止工作 */
RCM_EnableAPB2PeriphClock(RCM_APB2_PERIPH_DBGMCU);
if (is_debug_stop != 0) {
DBG_EnableAPB1Periph(DBG_APB1_PER_IWDT_STOP);
} else {
DBG_DisableAPB1Periph(DBG_APB1_PER_IWDT_STOP);
* @brief 看门狗喂狗
* @param None
* @retval None
void bsp_iwdt_feed(void)
IWDT_Refresh();
测试代码如下:
void gpio_test(void)
GPIO_Config_T gpioConfig;
RCM_EnableAHBPeriphClock(RCM_AHB_PERIPH_GPIOB);
GPIO_ConfigStructInit(&gpioConfig);
gpioConfig.pin = GPIO_PIN_6;
gpioConfig.mode = GPIO_MODE_OUT;
gpioConfig.outtype = GPIO_OUT_TYPE_PP;
gpioConfig.speed = GPIO_SPEED_50MHz;
gpioConfig.pupd = GPIO_PUPD_NO;
GPIO_Config(GPIOB, &gpioConfig);
GPIO_SetBit(GPIOB, GPIO_PIN_6);
// 应用初始化
void app_init(void)
bsp_iwdt_init(100, 1);
gpio_test();
// 应用任务
void app_task(void)
详细代码,请查看附件!
楼主的代码写得可是真规范。
我的代码就没有边界检查 心跳回响 发表于 2025-9-7 23:01
楼主的代码写得可是真规范。
我的代码就没有边界检查
在做高安全性的应用时,边界检查是最基本的要求,要养成良好的习惯 学习了,谢谢楼主了 代码中对于看门狗的配置和喂狗操作都很清楚,但是有没有考虑到异常情况下的处理,比如看门狗计数器溢出?
页:
[1]
