关于candence16.6的一点疑问
刚用16.6版本,不知为什么老提示有错误不知道怎么解决。在低版本上没有发现同样问题:以下是错误说明#1 ERROR(SPMHNI-176): Device library error detected.
ERROR(SPMHNI-164): Problems with device 'CY2305'. JEDEC_TYPE property 'sop-8p127-620x500-pericom-pi6c2405a' is illegal: 'Package name is too long.'.
ERROR(SPMHNI-170): Device 'CY2305' has library errors. Unable to transfer to Allegro.
#2 ERROR(SPMHNI-176): Device library error detected.
ERROR(SPMHNI-164): Problems with device '841'. JEDEC_TYPE property 'SOP-DIP-16P254-790X2032-ISOCOM-TLP521-4' is illegal: 'Package name is too long.'.
ERROR(SPMHNI-170): Device '841' has library errors. Unable to transfer to Allegro.
#3 ERROR(SPMHNI-176): Device library error detected.
ERROR(SPMHNI-164): Problems with device '842'. JEDEC_TYPE property 'SOP-DIP-16P254-790X2032-ISOCOM-TLP521-4' is illegal: 'Package name is too long.'.
ERROR(SPMHNI-170): Device '842' has library errors. Unable to transfer to Allegro.
#4 ERROR(SPMHNI-176): Device library error detected.
ERROR(SPMHNI-164): Problems with device '670'. JEDEC_TYPE property 'QFP-48P050-900X900-REALTECK-RTL8211CL' is illegal: 'Package name is too long.'.
ERROR(SPMHNI-170): Device '670' has library errors. Unable to transfer to Allegro.
#5 ERROR(SPMHNI-176): Device library error detected.
ERROR(SPMHNI-164): Problems with device '299'. JEDEC_TYPE property 'sop-14p127-620x875-philips-74hc14d' is illegal: 'Package name is too long.'.
ERROR(SPMHNI-170): Device '299' has library errors. Unable to transfer to Allegro.
------ Library Paths ------
MODULEPATH =.
D:/Cadence/SPB_16.6/share/local/pcb/modules
PSMPATH =E:/layout/lib/
PADPATH =E:/layout/lib/
------ Summary Statistics ------
#6 Run stopped because errors were detected
netrev run on Apr 1 22:59:21 2013
DESIGN NAME : 'DVR-16D1-MAINB-C2-2013-02-27'
PACKAGING ON Sep 10 2012 04:46:09
COMPILE 'logic'
CHECK_PIN_NAMES OFF
CROSS_REFERENCE OFF
FEEDBACK OFF
INCREMENTAL OFF
INTERFACE_TYPE PHYSICAL
MAX_ERRORS 500
MERGE_MINIMUM 5
NET_NAME_CHARS '#%&()*+-./:=>?@[]^_`|'
NET_NAME_LENGTH 24
OVERSIGHTS ON
REPLACE_CHECK OFF
SINGLE_NODE_NETS ON
SPLIT_MINIMUM 0
SUPPRESS 20
WARNINGS ON
6 errors detected
No oversight detected
No warning detected
cpu time 0:01:32
elapsed time0:00:00
INFO(ORCAP-32005): *** Done ***
一直把candence和cadence混淆 jakfens 发表于 2013-4-2 09:04 static/image/common/back.gif
有一个是错的额 qin552011373 发表于 2013-4-2 21:32 static/image/common/back.gif
有一个是错的额
呃 我以为都是他们公司的产品 jakfens 发表于 2013-4-3 08:57 static/image/common/back.gif
呃 我以为都是他们公司的产品
解决了吗?
这个问题。。。
页:
[1]
