Bestend 发表于 2014-1-14 11:22
请大家帮忙看看为什么modelsim仿真不出现波形框呢?
这是一个乘法器的模块
module multiplier_module(
clk,
rstn,
done_sig,
multiplier,
multiplicand,
product,
start_sig
input start_sig;
input clk;
input rstn;
input multiplier;
input multiplicand;
output done_sig;
output product;
reg isdone;
reg i;
reg mer;
reg mnd;
reg temp;
reg isneg;
always @(posedge clk or negedge rstn)
if(!rstn)
begin
i<=2'd0;
isdone<=1'b0;
mer<=8'd0;;
mnd<=8'd0;
temp<=8'd0;
isneg<=1'b0;
end
else if(start_sig)
case(i)
0:
begin
isneg<=multiplicand^multiplier;
mer<=multiplier?(~multiplier+1'b1):multiplier;
mnd<=multiplicand?(~multiplicand+1'b1):multiplicand;
//{mer,mnd}<=mer<mnd?{mnd,mer}:{mer,mnd};
temp<=16'd0;
i<=i+1'b1;
end
1:
if(mnd==0)
i<=i+1'b1;
else
begin
temp<=temp+mer;
mnd<=mnd-1'b1;
end
2:
begin
   isdone<=1'b1;
i<=i+1'b1;
end
3:
begin
isdone<=1'b0;
i<=2'b0;
end
endcase
assign done_sig=isdone;
assign product=isneg?(~temp+1'b1):temp;
endmodule
这是testbench:
`timescale 1 ps/ 1 ps
module multiplier_module_simulation();
    reg clk;
       reg rstn;
       reg start_sig;
    reg multiplicand;
    reg multiplier;
    wire done_sig;
    wire product;
    initial
    begin
      rstn = 0; #10; rstn = 1;
             clk = 1; forever #10 clk = ~clk;
       end
    multiplier_module U1
          .clk(clk),
               .rstn(rstn),
               .start_sig(start_sig),
          .multiplicand(multiplicand),
          .multiplier(multiplier),
               .done_sig(done_sig),
          .product(product)
       reg i;
    always @ ( posedge clk or negedge rstn )
      if( !rstn )
            begin
                                  i <= 4'd0;
                                  start_sig <= 1'b0;
                multiplicand <= 8'd0;
                        multiplier <= 8'd0;
            end
                  else
                      case( i )
                                  0: // Multiplicand = 10 , Multiplier = 2
                                       if( done_sig ) begin start_sig <= 1'b0; i <= i + 1'b1; end
                                       else begin multiplicand <= 8'd10; multiplier <= 8'd2; start_sig <= 1'b1; end
                                       1: // Multiplicand = 2 , Multiplier = 10
                                       else begin multiplicand <= 8'd2; multiplier <= 8'd10; start_sig <= 1'b1; end
                                       2: // Multiplicand = 11 , Multiplier = -5
                                       else begin multiplicand <= 8'd11; multiplier <= 8'b11111011; start_sig <= 1'b1; end
                                  3: // Multiplicand = -5 , Multiplier = -11
                                       else begin multiplicand <= 8'b11111011; multiplier <= 8'b11110101; start_sig <= 1'b1; end
                                  4:
                                       begin i <= 4'd4; end
                                endcase
endmodule
仿真只到这一步就不再出现其他框了。这是为什么呢?
gaochy1126 发表于 2014-1-15 16:10
只能被帮你顶一下,这个仿真一般不用的。
页: [1]
查看完整版本: 请大家帮忙看看为什么modelsim仿真不出现波形框呢?
