偏爱番茄酱 发表于 2014-11-24 17:35
【21ic飞控】我的四旋翼经验分享
很高兴二姨家举办此次活动,我也很荣幸参加此次活动,下面就分享一下自己四旋翼奋斗之路
飞雨 发表于 2014-11-24 23:22
dirtwillfly 发表于 2014-11-25 13:49
坐等楼主的故事
hhf1112 发表于 2014-11-27 16:19
还有吗
偏爱番茄酱 发表于 2014-12-5 20:52
分享一下我的姿态融合的一阶互补滤波、二阶互补滤波、卡尔曼滤波核心程序
//一阶互补
// a=tau / (tau + loop time)
// newAngle = angle measured with atan2 using the accelerometer
//加速度传感器输出值
// newRate = angle measured using the gyro
// looptime = loop time in millis()
float tau = 0.075;
float a = 0.0;
float Complementary(float newAngle, float newRate, int looptime)
    float dtC = float(looptime) / 1000.0;
    a = tau / (tau + dtC);
    x_angleC = a * (x_angleC + newRate * dtC) + (1 - a) * (newAngle);
    return x_angleC;
//二阶互补
float Complementary2(float newAngle, float newRate, int looptime)
    float k = 10;
    float dtc2 = float(looptime) / 1000.0;
    x1 = (newAngle -   x_angle2C) * k * k;
    y1 = dtc2 * x1 + y1;
    x2 = y1 + (newAngle -   x_angle2C) * 2 * k + newRate;
    x_angle2C = dtc2 * x2 + x_angle2C;
    return x_angle2C;
//Here too we just have to set the k and magically we get the angle. 卡尔曼滤波
// KasBot V1 - Kalman filter module
float Q_angle=0.01; //0.001
float Q_gyro   =0.0003;//0.003
float R_angle=0.01;//0.03
float x_bias = 0;
float P_00 = 0, P_01 = 0, P_10 = 0, P_11 = 0;
floaty, S;
float K_0, K_1;
float kalmanCalculate(float newAngle, float newRate, int looptime)
    float dt = float(looptime) / 1000;
    x_angle += dt * (newRate - x_bias);
    P_00 +=- dt * (P_10 + P_01) + Q_angle * dt;
    P_01 +=- dt * P_11;
    P_10 +=- dt * P_11;
    P_11 +=+ Q_gyro * dt;
    y = newAngle - x_angle;
    S = P_00 + R_angle;
    K_0 = P_00 / S;
    K_1 = P_10 / S;
    x_angle +=K_0 * y;
    x_bias+=K_1 * y;
    P_00 -= K_0 * P_00;
    P_01 -= K_0 * P_01;
    P_10 -= K_1 * P_00;
    P_11 -= K_1 * P_01;
    return x_angle;
//To get the answer, you have to set 3 parameters: Q_angle, R_angle, R_gyro.
//详细卡尔曼滤波
/* -*- indent-tabs-mode:T; c-basic-offset:8; tab-width:8; -*- vi: set ts=8:
* $Id: tilt.c,v 1.1 2003/07/09 18:23:29 john Exp $
* 1 dimensional tilt sensor using a dual axis accelerometer
* and single axis angular rate gyro.The two sensors are fused
* via a two state Kalman filter, with one state being the angle
* and the other state being the gyro bias.*
* Gyro bias is automatically tracked by the filter.This seems
* like magic.
* Please note that there are lots of comments in the functions and
* in blocks before the functions.Kalman filtering is an already complex
* subject, made even more so by extensive hand optimizations to the C code
* that implements the filter.I've tried to make an effort of explaining
* the optimizations, but feel free to send mail to the mailing list,
* autopilot-devel@lists.sf.net, with questions about this code.
* (c) 2003 Trammell Hudson <hudson@rotomotion.com>
*This file is part of the autopilot onboard code package.
*Autopilot is free software; you can redistribute it and/or modify
*it under the terms of the GNU General Public License as published by
*the Free Software Foundation; either version 2 of the License, or
*(at your option) any later version.
*Autopilot is distributed in the hope that it will be useful,
*but WITHOUT ANY WARRANTY; without even the implied warranty of
*MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.See the
*GNU General Public License for more details.
*You should have received a copy of the GNU General Public License
*along with Autopilot; if not, write to the Free Software
*Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA02111-1307USA
#include <math.h>
* Our update rate.This is how often our state is updated with
* gyro rate measurements.For now, we do it every time an
* 8 bit counter running at CLK/1024 expires.You will have to
* change this value if you update at a different rate.
static const float dt = ( 1024.0 * 256.0 ) / 8000000.0;
* Our covariance matrix.This is updated at every time step to
* determine how well the sensors are tracking the actual state.
static floatP =
    { 1, 0 },
    { 0, 1 },
* Our two states, the angle and the gyro bias.As a byproduct of computing
* the angle, we also have an unbiased angular rate available.   These are
* read-only to the user of the module.
float   angle;
float   q_bias;
float   rate;
* R represents the measurement covariance noise.In this case,
* it is a 1x1 matrix that says that we expect 0.3 rad jitter
* from the accelerometer.
static const float R_angle = 0.3;
* Q is a 2x2 matrix that represents the process covariance noise.
* In this case, it indicates how much we trust the acceleromter
* relative to the gyros.
static const float Q_angle = 0.001;
static const float Q_gyro = 0.003;
* state_update is called every dt with a biased gyro measurement
* by the user of the module.It updates the current angle and
* rate estimate.
* The pitch gyro measurement should be scaled into real units, but* does not need any bias removal.The filter will track the bias.
* Our state vector is:
* X = [ angle, gyro_bias ]
* It runs the state estimation forward via the state functions:
* Xdot = [ angle_dot, gyro_bias_dot ]
* angle_dot = gyro - gyro_bias
* gyro_bias_dot = 0
* And updates the covariance matrix via the function:
* Pdot = A*P + P*A' + Q
* A is the Jacobian of Xdot with respect to the states:
* A = [ d(angle_dot)/d(angle)   d(angle_dot)/d(gyro_bias) ]
*   [ d(gyro_bias_dot)/d(angle) d(gyro_bias_dot)/d(gyro_bias) ]
*   = [ 0 -1 ]
*   [ 00 ]
* Due to the small CPU available on the microcontroller, we've
* hand optimized the C code to only compute the terms that are
* explicitly non-zero, as well as expanded out the matrix math
* to be done in as few steps as possible.This does make it harder
* to read, debug and extend, but also allows us to do this with
* very little CPU time.
void state_update( const floatq_m /* Pitch gyro measurement */)
    /* Unbias our gyro */
    const floatq = q_m - q_bias;
   * Compute the derivative of the covariance matrix
   * We've hand computed the expansion of A = [ 0 -1, 0 0 ] multiplied   * by P and P multiplied by A' = [ 0 0, -1, 0 ].This is then added
   * to the diagonal elements of Q, which are Q_angle and Q_gyro.
    const floatPdot =
      Q_angle - P - P, /* 0,0 */
      - P,                        /* 0,1 */
      - P,                        /* 1,0 */
      Q_gyro                                          /* 1,1 */
    /* Store our unbias gyro estimate */
    rate = q;
   * Update our angle estimate
   * angle += angle_dot * dt
   *       += (gyro - gyro_bias) * dt
   *       += q * dt
    angle += q * dt;
    /* Update the covariance matrix */
    P += Pdot * dt;
    P += Pdot * dt;
    P += Pdot * dt;
    P += Pdot * dt;
* kalman_update is called by a user of the module when a new
* accelerometer measurement is available.ax_m and az_m do not
* need to be scaled into actual units, but must be zeroed and have
* the same scale.
* This does not need to be called every time step, but can be if
* the accelerometer data are available at the same rate as the
* rate gyro measurement.
* For a two-axis accelerometer mounted perpendicular to the rotation
* axis, we can compute the angle for the full 360 degree rotation
* with no linearization errors by using the arctangent of the two
* readings.
** As commented in state_update, the math here is simplified to
* make it possible to execute on a small microcontroller with no
* floating point unit.It will be hard to read the actual code and
* see what is happening, which is why there is this extensive
* comment block.
* The C matrix is a 1x2 (measurements x states) matrix that
* is the Jacobian matrix of the measurement value with respect
* to the states.In this case, C is:
* C = [ d(angle_m)/d(angle)d(angle_m)/d(gyro_bias) ]
*   = [ 1 0 ]
* because the angle measurement directly corresponds to the angle
* estimate and the angle measurement has no relation to the gyro
* bias.
void kalman_update(
    const floatax_m, /* X acceleration */
    const floataz_m /* Z acceleration */
    /* Compute our measured angle and the error in our estimate */
    const floatangle_m = atan2( -az_m, ax_m );
    const floatangle_err = angle_m - angle;
   * C_0 shows how the state measurement directly relates to
   * the state estimate.
   * The C_1 shows that the state measurement does not relate
   * to the gyro bias estimate.We don't actually use this, so
   * we comment it out.
    const floatC_0 = 1;
    /* const floatC_1 = 0; */
   * PCt<2,1> = P<2,2> * C'<2,1>, which we use twice.This makes
   * it worthwhile to precompute and store the two values.
   * Note that C = C_1 is zero, so we do not compute that
   * term.   */
    const floatPCt_0 = C_0 * P; /* + C_1 * P = 0 */
    const floatPCt_1 = C_0 * P; /* + C_1 * P = 0 */
   * Compute the error estimate.From the Kalman filter paper:
   * E = C P C' + R
   * Dimensionally,
   * E<1,1> = C<1,2> P<2,2> C'<2,1> + R<1,1>
   * Again, note that C_1 is zero, so we do not compute the term.
    const floatE =
      R_angle
      + C_0 * PCt_0
      /* + C_1 * PCt_1 = 0 */
   * Compute the Kalman filter gains.From the Kalman paper:
   * K = P C' inv(E)
   * Dimensionally:
   * K<2,1> = P<2,2> C'<2,1> inv(E)<1,1>
   * Luckilly, E is <1,1>, so the inverse of E is just 1/E.
    const floatK_0 = PCt_0 / E;
    const floatK_1 = PCt_1 / E;
   * Update covariance matrix.Again, from the Kalman filter paper:
   * P = P - K C P
   * Dimensionally:
   * P<2,2> -= K<2,1> C<1,2> P<2,2>
   *   * We first compute t<1,2> = C P.Note that:
   * t = C * P + C * P
   * But, since C_1 is zero, we have:
   * t = C * P = PCt
   * This saves us a floating point multiply.
    const floatt_0 = PCt_0; /* C_0 * P + C_1 * P */
    const floatt_1 = C_0 * P; /* + C_1 * P= 0 */
    P -= K_0 * t_0;
    P -= K_0 * t_1;
    P -= K_1 * t_0;
    P -= K_1 * t_1;
   * Update our state estimate.Again, from the Kalman paper:
   * X += K * err
   * And, dimensionally,
   * X<2> = X<2> + K<2,1> * err<1,1>
   * err is a measurement of the difference in the measured state
   * and the estimate state.In our case, it is just the difference
   * between the two accelerometer measured angle and our estimated
   * angle.
    angle += K_0 * angle_err;
    q_bias += K_1 * angle_err;
偏爱番茄酱 发表于 2014-12-5 20:54
无感无刷直流电机之电调设计全攻略
偏爱番茄酱 发表于 2014-12-5 20:56
爆照啦
偏爱番茄酱 发表于 2014-12-5 21:01
小班儿 发表于 2015-1-12 13:20
期待后续故事!!!!
qinhuan7 发表于 2015-1-31 15:49
请问楼主,你在的四轴在空心杯上电后,roll和pitch会漂吗?
页: [1]
查看完整版本: 【21ic飞控】我的四旋翼经验分享
