CCS4.2导入工程的问题
我把CCS3.3工程导入CCS4.2时,出现如下错误:在migration.log文件里提示
!WARNING: Source file 'rts55x.lib' has been linked into the project relative to version-specific Code-generation Tool variable 'CCS_C5500_4_3_6_CG_ROOT'.
It is recommended, however, that you do not link any resources from the Code-generation Tool directory -
consider using build-options to reference include-files and libraries, or linking the resource into your project using a new version-independent variable.
这是什么意思?谢谢!
供参考
http://wenku.baidu.com/link?url=3bEUJIkEKl-ze3hkFkqm4F2k_XgYqXQ3bPa3JI-mFpnYYJmsh2AovB8fnNW-vu2_7WEHVD203HETQj4Rwhj1u7iV07GoIqF18E3HuQvN7MO
有积分下载的朋友可以给大家分享一下
页:
[1]
