yeyangyun 发表于 2015-6-26 10:00
ubuntu编译ltib出错
collect2: ld returned 1 exit status
make: *** Error 1
error: Bad exit status from /home/zc/ltib-mpc8536rdk-20100630/tmp/rpm-tmp.31362 (%build)
RPM build errors:
Build time for lkc: 3 seconds
Failed building lkc
Died at ./ltib line 1384.
traceback:
main::build_host_rpms:1384
main::host_checks:1439
   main:542
Started: Wed Jan 21 17:40:00 2015
Ended:   Wed Jan 21 17:50:18 2015
Elapsed: 618 seconds
These packages failed to build:
lkc
Build Failed
错误如上,不知道怎么弄,刚开始接手,请问下大家怎么改?
我的是MPC8536
用的ubuntu12.04,32位
yeyangyun 发表于 2015-6-29 21:38
ambercctv 发表于 2015-6-27 10:00
./ltib -m scbuild -p kernel 吗?
已经解决了,没有下载patch-ltib-ubuntu12.04.sh才导致lkc建立失败
mini1986 发表于 2015-6-30 08:55
关注一下......
页: [1]
查看完整版本: ubuntu编译ltib出错
