发新帖本帖赏金 1.00元(功能说明)我要提问
返回列表
[Kinetis]
ke02z epwm 例程疑问
1569|13
lhy995|  楼主 | 2015-7-14 18:31 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
今天刚刚看了看ke02zepwm的例程并用示波器做了测试,但现在有一些问题想问一下各位大神
现附上例程/******************************************************************************
* Freescale Semiconductor Inc.
* (c) Copyright 2013 Freescale Semiconductor, Inc.
* ALL RIGHTS RESERVED.
* THIS SOFTWARE IS PROVIDED BY FREESCALE "AS IS" AND ANY EXPRESSED OR
* IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
* OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED.
* IN NO EVENT SHALL FREESCALE OR ITS CONTRIBUTORS BE LIABLE FOR ANY DIRECT,
* INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
* (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR
* SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
* HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT,
* STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING
* IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF
* THE POSSIBILITY OF SUCH DAMAGE.
* @file FTM_EPWM_demo.c
* @author Freescale
* @version 0.0.1
* @date Jun. 25, 2013
* @brief Demonstrate EPWM, output pwm from FTM2 Ch1,
         LED RED on FRDM-KE02 board will blink as pwm pulse width changing..
#include "common.h"
#include "ics.h"
#include "ftm.h"
#include "uart.h"
#include "sysinit.h"
* Global variables
* Constants and macros
* Local types
* Local function prototypes
* Local variables
* Local functions
void FTM2_Task(void);
* Global functions
int main (void)
    /* Perform processor initialization */
    sysinit();
    SIM_RemapFTM2CH1Pin();
    SIM_RemapFTM2CH0Pin();
    /* FTM2 is set as edge aligned pwm mode, high true pulse */
    FTM_PWMInit(FTM2, FTM_PWMMODE_EDGEALLIGNED, FTM_PWM_HIGHTRUEPULSE);
    /* FTMEN enable */
    FTM_SetFTMEnhanced(FTM2);
    /* update MOD value */
    FTM_SetModValue(FTM2,4999);
    /* set clock source, start counter */
        FTM_ClockSet(FTM2, FTM_CLOCK_SYSTEMCLOCK, FTM_CLOCK_PS_DIV1);
    /* enable FTM2 interrupt in NVIC */
    NVIC_EnableIRQ(FTM2_IRQn);
    /* setup call back function for interrupt */
    FTM_SetCallback(FTM2, FTM2_Task);
    /* enable FTM2 overflow interrupt */
    FTM_EnableOverflowInt(FTM2);
        while(1)
* @brief callback routine of FTM2 driver. FTM2 CH5 will change the duty cycle
*        periodically.
* @param  none.
* @return none.
* @ Pass/ Fail criteria: none.
uint16_t u16ChV_old, u16ChV_new;
    static uint16_t u16count;
    static uint8_t u8DirMark=1;
    /* clear the flag */
    FTM_ClrOverFlowFlag(FTM2);
    if(50 == u16count)
        u16count = 0;
        u16ChV_old = FTM2->CONTROLS[1].CnV;
        if(!u8DirMark)
            u16ChV_new = u16ChV_old + 200;
            if(u16ChV_new >= FTM2->MOD)
                u16ChV_new = FTM2->MOD - 200;
                u8DirMark  = 1;
            else
        else
            u16ChV_new = u16ChV_old - 200;
            if(u16ChV_new <  200)
                u16ChV_new = 200;
                u8DirMark  = 0;
            else
        /* update the channel value */
        FTM_SetChannelValue(FTM2, FTM_CHANNEL_CHANNEL1, u16ChV_new);
    else
        u16count++;
先说现象
例程烧录后板子上的灯会有呼吸灯的效果同时ptc2 ptc3 ptb5 pth0四个管脚会有PWM输出
现在有三个问题
1、板子上的灯有呼吸灯的效果,但是灯的亮暗本身由什么决定?是PWM的占空比吗?如果是 那么是哪个管脚的?
2、根据FTM_SetChannelValue()的原型,我理解的是第三个参数应该是决定cnv的值,我将其改为定值200后呼吸灯的效果小时,但是四个管脚的pwm占空比却没有变化,如果不做修改,灯会有呼吸灯的效果但是四个管脚输出的pwm的占空比一直是一个值,不随灯的亮度改变(如PTB5一直是15%左右)这是为什么?
3、同样根据FTM_SetChannelValue()我理解第二个参数是决定用那个通道输出pwm波,但是为什么中断里只配值了1通道但是会有四个脚有pwm波?还有就是FTM2 CH1所对应的PTC1并没有PWM波输出 这是为什么?
是我的理解有误吗?如果我想用一个特定的管脚(如PTC1)来输出特定占空比的PWM波(如20%)那么我应该怎么改程序?
先附上FTM_SetChannelValue()的原型
* @brief  set the ftm channel value.
* @param[in]    pFTM             pointer to one of three FTM base register address.
* @param[in]    u16ChannelValue  the CnV value required to set.
* @param[in]    u8FTM_Channel    ftm channel number.
* @return none.
* @see FTM_SetModValue.
__STATIC_INLINE void FTM_SetChannelValue(FTM_Type *pFTM, uint8_t u8FTM_Channel, uint16_t u16ChannelValue)
    pFTM->CONTROLS[u8FTM_Channel].CnV = u16ChannelValue;
    if(FTM2 == pFTM)
        if(pFTM->MODE & FTM_MODE_FTMEN_MASK)
            if(u8FTM_Channel < 2)
                pFTM->COMBINE |= FTM_COMBINE_SYNCEN0_MASK;  /* enable the sync function */
            else if (u8FTM_Channel < 4)
                pFTM->COMBINE |= FTM_COMBINE_SYNCEN1_MASK;
            else
                pFTM->COMBINE |= FTM_COMBINE_SYNCEN2_MASK;
            pFTM->PWMLOAD |= FTM_PWMLOAD_LDOK_MASK;
        else
    else
打赏榜单
xyz549040622 打赏了 1.00 元 2015-07-15
lhy995|  楼主 | 2015-7-14 18:36 | 只看该作者
这个是通道对应的管脚
Kinetis KE02Z40M_Sheild Compatibility_Pin Out .pdf
33.59 KB
春风的暖暖| | 2015-7-14 21:02 | 只看该作者
我也看了一下,非常的有帮助啊
lhy995|  楼主 | 2015-7-14 22:01 | 只看该作者
又重新看了一下手册  pdf文档里和官网文档里FTM2CH1对应的管脚不一样根据led的现象可以认为官网给的那个是对的(如图) 还是说FTM2CH1同时对应两个管脚?
FSL_TICS_ZJJ| | 2015-7-15 09:51 | 只看该作者
所有的通道都有PWM波,是因为在初始化的时候,初始化了所有的通道,而且占空比设定了固定值,你可以查看这个函数:
void FTM_PWMInit(FTM_Type *pFTM, uint8_t u8PWMModeSelect, uint8_t u8PWMEdgeSelect)
另外,关于小灯对应的引脚,以原理图为准。
红灯对应的就是PTH1/FTM2CH1, 没有其他引脚了。
小狗爱吃骨头| | 2015-7-15 10:07 | 只看该作者
关注一下,学习了
xyz549040622| | 2015-7-15 10:24 | 只看该作者
发帖有奖,希望常来21ic提问呦
lhy995|  楼主 | 2015-7-15 13:51 | 只看该作者
FSL_TICS_ZJJ 发表于 2015-7-15 09:51
所有的通道都有PWM波,是因为在初始化的时候,初始化了所有的通道,而且占空比设定了固定值,你可以查看这 ...
哦哦谢谢
lhy995|  楼主 | 2015-7-15 13:53 | 只看该作者
还有FTM_SetChannelValue()这个函数有配置占空比的功能吗?
lhy995|  楼主 | 2015-7-15 13:55 | 只看该作者
lhy995|  楼主 | 2015-7-15 14:24 | 只看该作者
这个函数能够配置Cnv 那就是应该有改变占空比的功能吧
FSL_TICS_ZJJ| | 2015-7-15 14:32 | 只看该作者
当然可以啊,你看官方例程就是用这个去改变占空比的。
lhy995|  楼主 | 2015-7-15 17:39 | 只看该作者
恩恩已经改成功了 谢谢了
FSL_TICS_ZJJ| | 2015-7-16 09:28 | 只看该作者
lhy995 发表于 2015-7-15 17:39
恩恩已经改成功了 谢谢了
好的,后续有问题,欢迎继续发帖交流。
发新帖 本帖赏金 1.00元(功能说明)我要提问
