[i.MX]
dequeueBuffer: can't dequeue multiple buffers without setting the buffer count
7248|10
hx999|  楼主 | 2015-7-24 14:49 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
android4.2.2 logcat打印,不知道哪里的问题,感觉好像和硬件加速有关,是否系统配置的问题?
2260-2438/? E/BufferQueue﹕ [com.android.settings/com.android.settings.SubSettings] dequeueBuffer: can't dequeue multiple buffers without setting the buffer count
01-01 00:03:08.070    2260-2260/? E/BufferQueue﹕ [com.android.settings/com.android.settings.SubSettings] dequeueBuffer: can't dequeue multiple buffers without setting the buffer count
01-01 00:03:13.220    2260-2260/? E/BufferQueue﹕ [com.android.settings/com.android.settings.Settings] dequeueBuffer: can't dequeue multiple buffers without setting the buffer count
01-01 00:03:31.430    2260-2438/? E/BufferQueue﹕ [com.android.settings/com.android.settings.SubSettings] dequeueBuffer: can't dequeue multiple buffers without setting the buffer count
01-01 00:03:42.350    2260-2260/? E/BufferQueue﹕ [Legal information] dequeueBuffer: can't dequeue multiple buffers without setting the buffer count
01-01 00:03:46.490    2260-2594/? E/BufferQueue﹕ [com.android.settings/com.android.settings.deviceinfo.Status] dequeueBuffer: can't dequeue multiple buffers without setting the buffer count
01-01 00:08:44.220    2260-3075/? E/BufferQueue﹕ [com.android.settings/com.android.settings.Settings] dequeueBuffer: can't dequeue multiple buffers without setting the buffer count
01-01 00:08:51.300    2260-2438/? E/BufferQueue﹕ [com.android.settings/com.android.settings.SubSettings] dequeueBuffer: can't dequeue multiple buffers without setting the buffer count
01-01 00:08:54.760    2260-2438/? E/BufferQueue﹕ [com.android.settings/com.android.settings.SubSettings] dequeueBuffer: can't dequeue multiple buffers without setting the buffer count
01-01 00:08:58.720    2260-2438/? E/BufferQueue﹕ [com.android.settings/com.android.settings.SubSettings] dequeueBuffer: can't dequeue multiple buffers without setting the buffer count
01-01 00:08:59.590    2260-2594/? E/BufferQueue﹕ [com.android.settings/com.android.settings.Settings] dequeueBuffer: can't dequeue multiple buffers without setting the buffer count
01-01 00:09:01.260    2260-3075/? E/BufferQueue﹕ [com.android.launcher/com.android.launcher2.Launcher] dequeueBuffer: can't dequeue multiple buffers without setting the buffer count
01-01 01:04:24.601    2260-2594/? E/BufferQueue﹕ [Keyguard] dequeueBuffer: can't dequeue multiple buffers without setting the buffer count
01-01 03:28:22.571    2260-2594/? E/BufferQueue﹕ [Keyguard] dequeueBuffer: can't dequeue multiple buffers without setting the buffer count
01-01 03:40:10.591    2260-2260/? E/BufferQueue﹕ [com.android.settings/com.android.settings.Settings] dequeueBuffer: can't dequeue multiple buffers without setting the buffer count
01-01 03:40:14.171    2260-3075/? E/BufferQueue﹕ [com.android.settings/com.android.settings.SubSettings] dequeueBuffer: can't dequeue multiple buffers without setting the buffer count
01-01 03:40:26.991    2260-3075/? E/BufferQueue﹕ [com.android.settings/com.android.settings.SubSettings] dequeueBuffer: can't dequeue multiple buffers without setting the buffer count
01-01 03:40:35.161    2260-2594/? E/BufferQueue﹕ [com.android.settings/com.android.settings.Settings] dequeueBuffer: can't dequeue multiple buffers without setting the buffer count
01-01 03:40:37.471    2260-2594/? E/BufferQueue﹕ [com.android.launcher/com.android.launcher2.Launcher] dequeueBuffer: can't dequeue multiple buffers without setting the buffer count
01-01 03:40:46.641    2260-2260/? E/BufferQueue﹕ [com.android.settings/com.android.settings.UsbSettings] dequeueBuffer: can't dequeue multiple buffers without setting the buffer count
01-01 03:40:48.471    2260-3075/? E/BufferQueue﹕ [com.android.launcher/com.android.launcher2.Launcher] dequeueBuffer: can't dequeue multiple buffers without setting the buffer count
01-01 03:40:54.881    2260-2260/? E/BufferQueue﹕ [com.android.systemui/com.android.systemui.usb.UsbDebuggingActivity] dequeueBuffer: can't dequeue multiple buffers without setting the buffer count
mini1986| | 2015-7-25 19:01 | 只看该作者
目前没遇到,关注一下......
春风的暖暖| | 2015-7-26 09:28 | 只看该作者
好复杂的说,关注一下
hx999|  楼主 | 2015-7-27 09:11 | 只看该作者
主要表现是所有应用都有这个error
/BufferQueue﹕ [。。。。] dequeueBuffer: can't dequeue multiple buffers without setting the buffer count
史迪威将军| | 2015-7-27 09:15 | 只看该作者
没有遇到过这个问题,帮顶一下
hx999|  楼主 | 2015-7-28 17:40 | 只看该作者
FSL_TICS_Rita| | 2015-7-28 18:09 | 只看该作者
楼主你好,请问你这里如何操作出现帖中现象呢?
hx999|  楼主 | 2015-7-29 09:18 | 只看该作者
您好,我没有做什么操作,厂家提供的源码包
isdqwq| | 2015-11-30 08:57 | 只看该作者
哎,楼主,你解决了吗?我也遇到这个问题. 我的是  Android 5.0
每个APK至少都有一次出现.
kim8488960| | 2015-12-4 15:00 | 只看该作者
热敏打印机方案提供,有需要的可咨询,QQ:81617129
hx999|  楼主 | 2016-5-13 11:44 | 只看该作者
每个APK至少都有一次出现. ...
有解决吗
