[STC单片机]
51单片机使用两片74HC595级联驱动八位数码管电子时钟C程序
1257|0
zixuanok|  楼主 | 2015-10-15 22:52 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
那位帮看看这个程序怎么更改为51单片机使用两片74HC595级联驱动八位数码管电子时钟C
#include <AT89X51.H>
#define MAIN_Fosc  11059200UL //?????
#define Timer0_Reload (MAIN_Fosc / 12000)
#define uchar unsigned char   //ÉùÃ÷ÎÞ·ûºÅ×Ö·û±äÁ¿£¬
#define uint unsigned int     //ÉùÃ÷ÎÞ·ûºÅ×Ö·û±äÁ¿£
//º¯ÊýÉùÃ÷
void main (void);                                            // Ö÷º¯Êý
void LED_Display (void);                        // LEDÏÔʾ³ÌÐò
void LED_OUT(uchar LED);                                // LEDµ¥×Ö½Ú´®ÐÐÒÆλº¯Êý
void delay(void);              //ÑÓʱ³ÌÐò
void time_pro(void);          //ʱ¼ä´¦Àí³ÌÐò
void key_pro(void);            //¼üÅÌɨÃè³ÌÐò
uchar code segment[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0xbf,0xff}; //¶ÎÂë
uchar code segbit[]={0x01,0x02,0x04,0x08,0x10,0x20,0x40,0x80};  //λÂë
uchar  LED[8]={0,0,0,0,0,0,0,0};   //ÓÃÓÚLEDµÄ8λÏÔʾ»º´æ
uchar LED_bit;   //¶¨ÒåÒ»¸ö´ýÊä³ö×Ö½Ú±äÁ¿
uchar display_index; //LEDÏÔʾλË÷Òý
sbit DIO = P1^0; //´®ÐÐÊý¾ÝÊäÈë pin 14 SER  data input
sbit RCLK = P1^1; //ʱÖÓÂö³åÐźšª¡ªÉÏÉýÑØÓÐЧ pin 12 RCLk store (latch) clock
sbit SCLK = P1^2; //´òÈëÐźšª¡ª¡ª¡ªÉÏÉýÑØÓÐЧ pin 11 SRCLK Shift data clock
bit    B_1ms;   //1msÑÓʱ
void main(void)
        SCLK = 0;
        DIO = 1;
        while(1)
                uchar i;
                for(i=0;i<8;i++)
                        LED_bit = LED;
                        LED_OUT(i);
                        delay();
void delay(void)
uchar i,k;
uint j;
TMOD = 0x00; //Timer 0 config as 16bit timer, 12T
TH0  = (65536 - Timer0_Reload) / 256;
TL0  = (65536 - Timer0_Reload) % 256;
ET0 = 1;
TR0 = 1;
EA  = 1;
for(i=0; i<8; i++) LED[i] = 0x10; //ÉϵçÏûÒþ
j = 0;
k = 0;
        while(1)
  while(!B_1ms) ; //µÈ´ý1msµ½
  B_1ms = 0;
  if(++j >= 500);  //500msµ½
   j = 0;
   for(i=0; i<8; i++) LED[i] = k; //Ë¢ÐÂÏÔʾ
   if(++k > 7) k = 0;  //8¸öÊýÂë¹ÜÑ­»·ÏÔʾ0,1,2...,A,B..F,ÏûÒþ.    Õâ¸ö¿ÉÒÔµ÷ÕûÏÔʾÄǸö²»ÏÔʾÄǸö
void LED_OUT(uchar LED) //·¢ËÍÒ»¸ö×Ö½Ú
uchar i;
for(i=0; i<8; i++)
        if(LED & 0x80) DIO = 1;
  else   DIO = 0;
        LED = LED << 1;
  SCLK = 1;
  SCLK = 0;
void LED_Display(void) //ÏÔʾɨÃ躯Êý
        uchar i;
        LED_bit = segment;
        i = LED_bit;
LED_OUT(segment[display_index]);   //¹²ÑôÊä³öλÂë
LED_OUT(segbit[LED[display_index]]); //¹²ÑôÊä³ö¶ÎÂë
RCLK = 1;
RCLK = 0;           //??????
if(++display_index >= 8) display_index = 0; //8λ½áÊø»Ø0
void timer0 (void) interrupt 1 //Timer0 1ms ÖжϺ¯Êý
TH0  = (65536 - Timer0_Reload) / 256; //ÖØ×°¶¨Ê±Æ÷
LED_Display(); //1msɨÃèÏÔʾһλ
B_1ms = 5;  //1ms±êÖ¾
