帮帮忙!找找毛病!
2615|4
 楼主| suoma 发表于 2009-11-15 22:53 | 显示全部楼层 |阅读模式
//基于单片机串行口的电子钟的设计
//请大家帮忙看一下,提提建议!
//我采用的是74HC595芯片。程序如下:
//基于单片机串行口的电子钟的设计
//利用74HC595
//下面有几个不太明白的地方,请高手指点指点!!
#include <reg52.h>
#include <intrins.h>
#include <stdio.h>
#define uchar unsigned char
#define uint unsigned int
#define NOP _nop_()
sbit SDA=P1^1;
sbit SHIFT=P1^2;
sbit ST=P1^0;
sbit P0_0=P1^3;
sbit P0_1=P1^4;
sbit P0_2=P1^5;
sbit P0_3=P1^6;
sbit P1_7=P1^7;
//共阳极数码管
uchar duan[] = {0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0xbf,0x0c};
uchar wei[] = {0x80,0x40,0x20,0x10,0x08,0x04,0x02,0x01,0x80};
//我想在P2口接pnp三极管,是否要改变位码。我自己改成 {0xfe,0x7f,0xbf,0xdf,0xef,0xf7,0xfb,0xfd}这个口,发现P2口高电平时就通了!
//如果我仿真的时候不接三极管,实物制作的时候加上会不会出现问题。
uchar dispbuf[]={0,0,16,0,0,16,0,0};
void key(void);
uchar i;
uchar second;
uchar minite;
uchar hour;
uchar mstcnt;
uchar V=0;
void Init( )
  P1_7=0;
  TMOD=0x01;
  TH0=(65536-50000)/256;
  TL0=(65536-50000)%256;
  TR0=0;
  ET0=1;
  EA=1;
  SDA = 0;
  SHIFT = 0;
  ST = 0;
void delay(uint m)
  while(m--);
void display(uchar dat)
  uchar ii;
  uchar sdata=dat;
  for(ii=0;ii<8;ii++)
    if(sdata&0x80)
    SDA=1;
    else
    SDA = 0;
    sdata<<=1;
    SHIFT =0;
    NOP;
    NOP;
    SHIFT = 1;
    NOP;
    NOP;
  ST = 1;
  NOP;
  NOP;
  ST = 0;
void main()
  Init();
  while(1)
    delay(360);
    P2 = wei[8];
    display(duan[11]);
    if(P0_0==0)
      while(1)
        key();
        for(i=0;i<8;i++)
          delay(360);
          P2 = wei;
          display(duan[dispbuf]);
void key(void)
dispbuf[2]=10;
dispbuf[5]=10;
if(P0_0==0)
  delay(50);
  if(P0_0==0)
   V++;
   if(V==2)
     V=0;
     switch(V)
      case 0:TR0=0;break;
      case 1:TR0=1;break;
if(P0_1==0)
    delay(50);
if(P0_1==0)
   second++;
   if(second==60)
     second=0;
   dispbuf[0]=second%10;
   dispbuf[1]=second/10;
while(P0_1==0);
if(P0_2==0)
    delay(100);
if(P0_2==0)
   minite++;
   if(minite==60)
     minite=0;
     dispbuf[3]=minite%10;
  dispbuf[4]=minite/10;
  while(P0_2==0);
  if(P0_3==0)
    delay(50);
if(P0_3==0)
   hour++;
      if(hour==24)
     hour=0;
   dispbuf[6]=hour%10;
   dispbuf[7]=hour/10;
   while(P0_3==0);
void t0(void) interrupt 1 using 0
mstcnt++;
if(mstcnt==15)
   mstcnt=0;
   second++;
   if(second==60)
     second=0;
     minite++;
     if(minite==60)
       minite=0;
       hour++;
       if(hour==24)
          hour=0;
   dispbuf[6]=hour%10;
   dispbuf[7]=hour/10;
huamunv 发表于 2009-11-16 12:56 | 显示全部楼层
搞电平时?应该是高电平是吧!
 楼主| suoma 发表于 2009-11-16 21:48 | 显示全部楼层
对对对,改了。大家说点啥吧,悬赏分很高哦
 楼主| suoma 发表于 2009-12-2 22:34 | 显示全部楼层
 楼主| suoma 发表于 2009-12-2 22:35 | 显示全部楼层
可惜了分数啊
