[Atmel]
每天跟我读点资料:SAM D SERCOM USART配置12
907|1
最终的”硬件握手配置”看起来如下:
#include <asf.h>
#define USART_BAUD_RATE 115200
#define USART_SAMPLE_NUM 16
#define SHIFT 32
uint8_t ext_rx_data, ext_tx_data = 0xAA;
/* Function Prototype */
void ext_usart_clock_init(void);
void ext_usart_pin_init(void);
void ext_usart_init(void);
uint16_t calculate_baud_value(const uint32_t baudrate,const uint32_t peripheral_clock,
uint8_t sample_num);
/*ext_usart handler*/
void SERCOM2_Handler()
if (SERCOM2->USART.INTFLAG.bit.DRE) {
SERCOM2->USART.DATA.reg = ext_tx_data;
/*Assigning pin to the alternate peripheral function*/
static inline void pin_set_peripheral_function(uint32_t pinmux)
uint8_t port = (uint8_t)((pinmux >> 16)/32);
PORT->Group[port].PINCFG[((pinmux >> 16) - (port*32))].bit.PMUXEN = 1;
PORT->Group[port].PMUX[((pinmux >> 16) - (port*32))/2].reg &= ~(0xF << (4 * ((pinmux >> 16) & 0x01u)));
PORT->Group[port].PMUX[((pinmux >> 16) - (port*32))/2].reg |= (uint8_t)((pinmux & 0x0000FFFF) << (4 * ((pinmux >> 16) & 0x01u)));
* internal Calculate 64 bit division, ref can be found in
static uint64_t long_division(uint64_t n, uint64_t d)
int32_t i;
uint64_t q = 0, r = 0, bit_shift;
for (i = 63; i >= 0; i--) {
bit_shift = (uint64_t)1 << i;
r = r << 1;
if (n & bit_shift) {
r |= 0x01;
if (r >= d) {
r = r - d;
q |= bit_shift;
return q;
* internal Calculate asynchronous baudrate value (UART)
uint8_t sample_num)
/* Temporary variables */
uint64_t ratio = 0;
uint64_t scale = 0;
uint64_t baud_calculated = 0;
uint64_t temp1;
/* Calculate the BAUD value */
temp1 = ((sample_num * (uint64_t)baudrate) << SHIFT);
ratio = long_division(temp1, peripheral_clock);
scale = ((uint64_t)1 << SHIFT) - ratio;
baud_calculated = (65536 * scale) >> SHIFT;
return baud_calculated;
/* External connector(SERCOM2) UART bus and generic clock initialization */
struct system_gclk_chan_config gclk_chan_conf;
uint32_t gclk_index = SERCOM2_GCLK_ID_CORE;
/* Turn on module in PM */
system_apb_clock_set_mask(SYSTEM_CLOCK_APB_APBC, PM_APBCMASK_SERCOM2);
/* Turn on Generic clock for USART */
system_gclk_chan_get_config_defaults(&gclk_chan_conf);
//Default is generator 0. Other wise need to configure like below
gclk_chan_conf.source_generator = GCLK_GENERATOR_1;
system_gclk_chan_set_config(gclk_index, &gclk_chan_conf);
system_gclk_chan_enable(gclk_index);
/* External connector(SERCOM2) pin initialization */
/* PA08,PA09,PA10,PA11 set into peripheral function*/
pin_set_peripheral_function(PINMUX_PA08D_SERCOM2_PAD0); //TXD
pin_set_peripheral_function(PINMUX_PA09D_SERCOM2_PAD1); //RXD
pin_set_peripheral_function(PINMUX_PA10D_SERCOM2_PAD2); //RTS
pin_set_peripheral_function(PINMUX_PA11D_SERCOM2_PAD3); //CTS
/* External connector(SERCOM2) UART initialization */
uint16_t baud_value;
baud_value = calculate_baud_value(USART_BAUD_RATE,sys-tem_gclk_chan_get_hz(SERCOM2_GCLK_ID_CORE),
USART_SAMPLE_NUM);
/* By setting the DORD bit LSB is transmitted first and setting the RXPO bit as 1 corresponding SERCOM PAD[1] will be used for data reception RXD, PAD[0] will be used as TxD pin, PAD[2] as RTS pin,PAD[3] as CTS signal pin by setting TXPO bit as 2,
16x over-sampling is selected by setting the SAMPR bit as 0,
Generic clock is enabled in all sleep modes by setting RUNSTDBY bit as 1,
USART clock mode is selected as USART with internal clock by setting MODE bit into 1.
SERCOM2->USART.CTRLA.reg = SERCOM_USART_CTRLA_DORD |
SERCOM_USART_CTRLA_RXPO(0x1) |
SERCOM_USART_CTRLA_TXPO(0x2) |
SERCOM_USART_CTRLA_SAMPR(0x0)|
SERCOM_USART_CTRLA_RUNSTDBY |
SERCOM_USART_CTRLA_MODE_USART_INT_CLK ;
/* baud register value corresponds to the device communication baud rate */
SERCOM2->USART.BAUD.reg = baud_value;
/* 8-bits size is selected as character size by setting the bit CHSIZE as 0,
TXEN bit and RXEN bits are set to enable the Transmitter and receiver*/
SERCOM2->USART.CTRLB.reg = SERCOM_USART_CTRLB_CHSIZE(0x0) |
SERCOM_USART_CTRLB_TXEN |
SERCOM_USART_CTRLB_RXEN ;
/* synchronization busy */
while(SERCOM2->USART.SYNCBUSY.bit.CTRLB);
//SERCOM2->USART.INTENSET.bit.RXC = 1;
/* SERCOM2 handler enabled */
system_interrupt_enable(SERCOM2_IRQn);
SERCOM2->USART.INTENSET.reg = SERCOM_USART_INTENSET_DRE;
SERCOM2->USART.CTRLA.reg |= SERCOM_USART_CTRLA_ENABLE;
int main (void)
system_init();
delay_init();
ext_usart_clock_init();
ext_usart_pin_init();
ext_usart_init();
while(1)
/* Delay of 1 ms is added to emulate that the CPU is busy doing something */
delay_ms(1);
if (SERCOM2->USART.INTFLAG.bit.RXC)
ext_rx_data = SERCOM2->USART.DATA.reg;
下图展示了SEROM USART硬件握手的应用。
相关下载
snubber| | 2016-3-30 16:28 | 只看该作者
赞一个
个人签名:http://shop34182318.taobao.com/ http://shop562064536.taobao.com
2398
