- #ifndef __BSP_LCD_H__
- #define __BSP_LCD_H__
- /* 包含头文件 ----------------------------------------------------------------*/
- #include "stm32f1xx_hal.h"
- /* 类型定义 ------------------------------------------------------------------*/
- typedef enum
- USB_FONT_16=16,
- USB_FONT_24=24,
- }USB_FONT_Typdef;
- #define IS_USB_FONT(FONT) (((FONT) == USB_FONT_16) || ((FONT) == USB_FONT_24))
- /* 宏定义 --------------------------------------------------------------------*/
- 2^26 =0X0400 0000 = 64MB,每个 BANK 有4*64MB = 256MB
- 64MB:FSMC_Bank1_NORSRAM1:0X6000 0000 ~ 0X63FF FFFF
- 64MB:FSMC_Bank1_NORSRAM2:0X6400 0000 ~ 0X67FF FFFF
- 64MB:FSMC_Bank1_NORSRAM3:0X6800 0000 ~ 0X6BFF FFFF
- 64MB:FSMC_Bank1_NORSRAM4:0X6C00 0000 ~ 0X6FFF FFFF
- 选择BANK1-BORSRAM4 连接 TFT,地址范围为0X6C00 0000 ~ 0X6FFF FFFF
- YS-F1P开发板选择 FSMC_A0 接LCD的DC(寄存器/数据选择)脚
- 寄存器基地址 = 0X6C00 0000
- RAM基地址 = 0X6C00 0002 = 0X6C00 0000+(1<<(0+1))
- 如果电路设计时选择不同的地址线时,地址要重新计算
- /******************************* ILI9488 显示屏的 FSMC 参数定义 ***************/
- #define FSMC_LCD_CMD ((uint32_t)0x6C000000) //FSMC_Bank1_NORSRAM1用于LCD命令操作的地址
- #define FSMC_LCD_DATA ((uint32_t)0x6C000002) //FSMC_Bank1_NORSRAM1用于LCD数据操作的地址
- #define LCD_WRITE_CMD(x) *(__IO uint16_t *)FSMC_LCD_CMD = x
- #define LCD_WRITE_DATA(x) *(__IO uint16_t *)FSMC_LCD_DATA = x
- #define LCD_READ_DATA() *(__IO uint16_t *)FSMC_LCD_DATA
- #define FSMC_LCD_BANKx FSMC_NORSRAM_BANK4
- /************************* ILI9488 显示屏8080通讯引脚定义 *********************/
- #define FSMC_LCD_CS_GPIO_ClK_ENABLE() __HAL_RCC_GPIOG_CLK_ENABLE()
- #define FSMC_LCD_CS_PORT GPIOG
- #define FSMC_LCD_CS_PIN GPIO_PIN_12
- #define FSMC_LCD_DC_GPIO_ClK_ENABLE() __HAL_RCC_GPIOF_CLK_ENABLE()
- #define FSMC_LCD_DC_PORT GPIOF
- #define FSMC_LCD_DC_PIN GPIO_PIN_0
- #define FSMC_LCD_BK_GPIO_ClK_ENABLE() __HAL_RCC_GPIOF_CLK_ENABLE()
- #define FSMC_LCD_BK_PORT GPIOF
- #define FSMC_LCD_BK_PIN GPIO_PIN_10
- #define LCD_BK_ON() HAL_GPIO_WritePin(FSMC_LCD_BK_PORT, FSMC_LCD_BK_PIN, GPIO_PIN_SET);
- #define LCD_BK_OFF() HAL_GPIO_WritePin(FSMC_LCD_BK_PORT, FSMC_LCD_BK_PIN, GPIO_PIN_RESET);
- /**************** 显示方向选择,可选(1,2,3,4)四个方向 *************************/
- #define LCD_DIRECTION 1 // 原点在屏幕左上角 X*Y=320*480
- //#define LCD_DIRECTION 2 // 原点在屏幕右上角 X*Y=480*320
- //#define LCD_DIRECTION 3 // 原点在屏幕右下角 X*Y=320*480
- //#define LCD_DIRECTION 4 // 原点在屏幕左下角 X*Y=480*320
- /******** ILI934 显示屏全屏默认(扫描方向为1时)最大宽度和最大高度*************/
- #if (LCD_DIRECTION==1)||(LCD_DIRECTION==3)
- #define LCD_DEFAULT_WIDTH 320 // X轴长度
- #define LCD_DEFAULT_HEIGTH 480 // Y轴长度
- #else
- #define LCD_DEFAULT_WIDTH 480 // X轴长度
- #define LCD_DEFAULT_HEIGTH 320 // Y轴长度
- #endif
- /******************************* 定义 ILI9488 显示屏常用颜色 ********************************/
- #define BACKGROUND WHITE //默认背景颜色
- #define BLUE (uint16_t)0x001F //蓝色
- #define GREEN (uint16_t)0x07E0 //绿色
- #define RED (uint16_t)0xF800 //红色
- #define CYAN (uint16_t)0x07FF //蓝绿色,青色
- #define MAGENTA (uint16_t)0xF81F //红紫色,洋红色
- #define YELLOW (uint16_t)0xFFE0 //黄色
- #define LIGHTBLUE (uint16_t)0x841F
- #define LIGHTGREEN (uint16_t)0x87F0
- #define LIGHTRED (uint16_t)0xFC10
- #define LIGHTCYAN (uint16_t)0x87FF
- #define LIGHTMAGENTA (uint16_t)0xFC1F
- #define LIGHTYELLOW (uint16_t)0xFFF0
- #define DARKBLUE (uint16_t)0x0010
- #define DARKGREEN (uint16_t)0x0400
- #define DARKRED (uint16_t)0x8000
- #define DARKCYAN (uint16_t)0x0410
- #define DARKMAGENTA (uint16_t)0x8010
- #define DARKYELLOW (uint16_t)0x8400
- #define WHITE (uint16_t)0xFFFF //白色
- #define LIGHTGRAY (uint16_t)0xD69A
- #define GRAY (uint16_t)0x8410 //灰色
- #define DARKGRAY (uint16_t)0x4208
- #define BLACK (uint16_t)0x0000 //黑色
- #define BROWN (uint16_t)0xA145
- #define ORANGE (uint16_t)0xFD20
- /* 扩展变量 ------------------------------------------------------------------*/
- extern SRAM_HandleTypeDef hlcd;
- /* 函数声明 ------------------------------------------------------------------*/
- uint32_t BSP_LCD_Init(void);
- void LCD_SetDirection(uint8_t ucOtion);
- void LCD_OpenWindow(uint16_t usX,uint16_t usY,uint16_t usWidth,uint16_t usHeight);
- void LCD_Clear(uint16_t usX,uint16_t usY,uint16_t usWidth,uint16_t usHeight,uint16_t usColor);
- void LCD_SetPointPixel(uint16_t usX,uint16_t usY,uint16_t usColor);
- uint16_t LCD_GetPointPixel(uint16_t usX,uint16_t usY);
- void LCD_DrawLine(uint16_t usX1,uint16_t usY1,uint16_t usX2,uint16_t usY2,uint16_t usColor);
- void LCD_DrawRectangle(uint16_t usX_Start,uint16_t usY_Start, uint16_t usWidth,uint16_t usHeight,uint16_t usColor,uint8_t ucFilled);
- void LCD_DrawCircle(uint16_t usX_Center,uint16_t usY_Center,uint16_t usRadius,uint16_t usColor,uint8_t ucFilled);
- void LCD_DispChar_EN(uint16_t usX,uint16_t usY,const char cChar,uint16_t usColor_Background,uint16_t usColor_Foreground,USB_FONT_Typdef font);
- void LCD_DispString_EN(uint16_t usX,uint16_t usY,const char *pStr,uint16_t usColor_Background,uint16_t usColor_Foreground,USB_FONT_Typdef font);
- #endif /* __BSP_LCD_H__ */
- /******************* (C) COPYRIGHT 2015-2020 硬石嵌入式开发团队 *****END OF FILE****/
