[STM32F1]
仿真有波形示波器没波形。。。在线等,急!!!!
1093|4
ZHOU@JIE|  楼主 | 2016-9-3 10:24 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
void TIM1_GPIO_Configuration(void)
        GPIO_PinRemapConfig(GPIO_FullRemap_TIM1,ENABLE);
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO|RCC_APB2Periph_GPIOE|RCC_APB2Periph_TIM1,ENABLE);
        GPIO_InitStructure.GPIO_Mode=GPIO_Mode_AF_PP;
        GPIO_InitStructure.GPIO_Pin=GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_10|GPIO_Pin_11|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14|GPIO_Pin_15;
        GPIO_InitStructure.GPIO_Speed=GPIO_Speed_50MHz;
        GPIO_Init(GPIOE,&GPIO_InitStructure);
void TIM1_MODE_Configuration(void)
        TIM_TimeBaseInitTypeDef TIM_TimeBaseInitStructure;
        TIM_OCInitTypeDef TIM_OCInitStructure;
        NVIC_InitTypeDef NVIC_InitStructure;
        TIM_BDTRInitTypeDef TIM_BDTRInitStructure;
        TIM_TimeBaseInitStructure.TIM_Period=14399;
        TIM_TimeBaseInitStructure.TIM_Prescaler=0;
        TIM_TimeBaseInitStructure.TIM_ClockDivision=TIM_CKD_DIV1;
        TIM_TimeBaseInitStructure.TIM_CounterMode=TIM_CounterMode_CenterAligned1;
        TIM_TimeBaseInitStructure.TIM_RepetitionCounter=0;
        TIM_TimeBaseInit(TIM1,&TIM_TimeBaseInitStructure);
        TIM_OCInitStructure.TIM_OCMode=TIM_OCMode_PWM2;
        TIM_OCInitStructure.TIM_OutputState=TIM_OutputState_Enable;
        TIM_OCInitStructure.TIM_OutputNState=TIM_OutputNState_Enable;
        TIM_OCInitStructure.TIM_Pulse=0;
        TIM_OCInitStructure.TIM_OCPolarity=TIM_OCPolarity_Low;
        TIM_OCInitStructure.TIM_OCNPolarity=TIM_OCNPolarity_Low;
        TIM_OCInitStructure.TIM_OCIdleState=TIM_OCIdleState_Set;
        TIM_OCInitStructure.TIM_OCNIdleState=TIM_OCNIdleState_Reset;
        TIM_OC1Init(TIM1,&TIM_OCInitStructure);
        TIM_OC1PreloadConfig(TIM1,TIM_OCPreload_Enable);
        TIM_OC2Init(TIM1,&TIM_OCInitStructure);
        TIM_OC2PreloadConfig(TIM1,TIM_OCPreload_Enable);
        TIM_OC3Init(TIM1,&TIM_OCInitStructure);
        TIM_OC3PreloadConfig(TIM1,TIM_OCPreload_Enable);
//        TIM_OCInitStructure.TIM_OutputState=TIM_OutputState_Enable;
//        TIM_OCInitStructure.TIM_Pulse=125;
//        TIM_OC4Init(TIM1,&TIM_OCInitStructure);
//        TIM_OC4PreloadConfig(TIM1,TIM_OCPreload_Enable);
  NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1);
  NVIC_InitStructure.NVIC_IRQChannel=TIM1_UP_IRQn;
        NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority=0;
        NVIC_InitStructure.NVIC_IRQChannelSubPriority=0;
        NVIC_InitStructure.NVIC_IRQChannelCmd=ENABLE;
        NVIC_Init(&NVIC_InitStructure);
        TIM_ITConfig(TIM1,TIM_IT_Update,ENABLE);
        TIM_BDTRInitStructure.TIM_OSSRState=TIM_OSSRState_Disable;
        TIM_BDTRInitStructure.TIM_OSSIState=TIM_OSSIState_Disable;
        TIM_BDTRInitStructure.TIM_LOCKLevel=TIM_LOCKLevel_OFF;
        TIM_BDTRInitStructure.TIM_DeadTime=0;
        TIM_BDTRInitStructure.TIM_Break=TIM_Break_Disable;
        TIM_BDTRInitStructure.TIM_BreakPolarity=TIM_BreakPolarity_High;
        TIM_BDTRInitStructure.TIM_AutomaticOutput=TIM_AutomaticOutput_Enable;
        TIM_BDTRConfig(TIM1,&TIM_BDTRInitStructure);
        TIM_ARRPreloadConfig(TIM1,ENABLE);
        TIM_Cmd(TIM1,ENABLE);
        TIM_CtrlPWMOutputs(TIM1,ENABLE);
中断里
                TIM1->CCR1 =svpwmdq1.Ta*72;
                TIM1->CCR2 =svpwmdq1.Tb*72;
                TIM1->CCR3 =svpwmdq1.Tc*72;
mmuuss586| | 2016-9-3 11:32 | 只看该作者
看程序好像没什么问题;
你再仔细查查看,对照官方程序是不是什么遗漏了;
输出PWM很简单的了
还有就是检查硬件,用示波器看看;
ZHOU@JIE|  楼主 | 2016-9-3 12:59 | 只看该作者
mmuuss586 发表于 2016-9-3 11:32
看程序好像没什么问题;
输出PWM很简单的了 ...
还有就是检查硬件,用示波器看看;
怎么给你分
