[STM32F1] TIM1重映像到PE引脚不出波形,使用默认引脚时有波形
1403|7
 楼主| ZHOU@JIE 发表于 2016-9-5 13:50 | 显示全部楼层 |阅读模式
  1.         GPIO_InitTypeDef GPIO_InitStructure;
  2.         GPIO_PinRemapConfig(GPIO_FullRemap_TIM1,ENABLE);
  3.         RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO|RCC_APB2Periph_GPIOE|RCC_APB2Periph_TIM1,ENABLE);
  4.         GPIO_InitStructure.GPIO_Mode=GPIO_Mode_AF_PP;
  5.         GPIO_InitStructure.GPIO_Pin=GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_10|GPIO_Pin_11|GPIO_Pin_12|GPIO_Pin_13;
  6.         GPIO_InitStructure.GPIO_Speed=GPIO_Speed_50MHz;
  7.         GPIO_Init(GPIOE,&GPIO_InitStructure);
xmshao 发表于 2016-9-5 14:36 | 显示全部楼层
如果不做REMAP是否能正常输出呢?
注意stm32f1系列的TIM1 的 Full remap 仅限于100脚和144脚封装;
另外 请注意TIM1的时钟是APB2 以及需使能其MOE.
 楼主| ZHOU@JIE 发表于 2016-9-5 14:49 | 显示全部楼层
如果不做REMAP是否能正常输出呢?
不做REMP能输出我用的是STMF103VET6 100引脚的
 楼主| ZHOU@JIE 发表于 2016-9-5 14:50 | 显示全部楼层
如果不做REMAP是否能正常输出呢?
  1. void TIM1_GPIO_Configuration(void)
  3.         GPIO_InitTypeDef GPIO_InitStructure;
  4.         GPIO_PinRemapConfig(GPIO_FullRemap_TIM1,ENABLE);
  5.         RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO|RCC_APB2Periph_GPIOE|RCC_APB2Periph_TIM1,ENABLE);
  6.         GPIO_InitStructure.GPIO_Mode=GPIO_Mode_AF_PP;
  7.         GPIO_InitStructure.GPIO_Pin=GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_10|GPIO_Pin_11|GPIO_Pin_12|GPIO_Pin_13;
  8.         GPIO_InitStructure.GPIO_Speed=GPIO_Speed_50MHz;
  9.         GPIO_Init(GPIOE,&GPIO_InitStructure);
  10.
  11. //        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_TIM1,ENABLE);
  12. //        GPIO_InitStructure.GPIO_Mode=GPIO_Mode_AF_PP;
  13. //        GPIO_InitStructure.GPIO_Pin=GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_10|GPIO_Pin_11|GPIO_Pin_12|GPIO_Pin_13;
  14. //        GPIO_InitStructure.GPIO_Speed=GPIO_Speed_50MHz;
  15. //        GPIO_Init(GPIOA,&GPIO_InitStructure);
  16. }
  17. void TIM1_MODE_Configuration(void)
  18. {
  19.         TIM_TimeBaseInitTypeDef TIM_TimeBaseInitStructure;
  20.         TIM_OCInitTypeDef TIM_OCInitStructure;
  21.         NVIC_InitTypeDef NVIC_InitStructure;
  22.         TIM_BDTRInitTypeDef TIM_BDTRInitStructure;
  23.
  24.         TIM_TimeBaseInitStructure.TIM_Period=14399;
  25.         TIM_TimeBaseInitStructure.TIM_Prescaler=0;
  26.         TIM_TimeBaseInitStructure.TIM_ClockDivision=TIM_CKD_DIV1;
  27.         TIM_TimeBaseInitStructure.TIM_CounterMode=TIM_CounterMode_CenterAligned1;
  28.         TIM_TimeBaseInitStructure.TIM_RepetitionCounter=0;
  29.         TIM_TimeBaseInit(TIM1,&TIM_TimeBaseInitStructure);
  30.
  31.         TIM_OCInitStructure.TIM_OCMode=TIM_OCMode_PWM2;
  32.         TIM_OCInitStructure.TIM_OutputState=TIM_OutputState_Enable;
  33.         TIM_OCInitStructure.TIM_OutputNState=TIM_OutputNState_Enable;
  34.         TIM_OCInitStructure.TIM_Pulse=0;
  35.         TIM_OCInitStructure.TIM_OCPolarity=TIM_OCPolarity_Low;
  36.         TIM_OCInitStructure.TIM_OCNPolarity=TIM_OCNPolarity_Low;
  37.         TIM_OCInitStructure.TIM_OCIdleState=TIM_OCIdleState_Set;
  38.         TIM_OCInitStructure.TIM_OCNIdleState=TIM_OCNIdleState_Reset;
  39.         TIM_OC1Init(TIM1,&TIM_OCInitStructure);
  40.         TIM_OC1PreloadConfig(TIM1,TIM_OCPreload_Enable);
  41.
  42.         TIM_OCInitStructure.TIM_OutputState=TIM_OutputState_Enable;
  43.         TIM_OCInitStructure.TIM_Pulse=0;
  44.         TIM_OC2Init(TIM1,&TIM_OCInitStructure);
  45.         TIM_OC2PreloadConfig(TIM1,TIM_OCPreload_Enable);
  46.
  47.         TIM_OCInitStructure.TIM_OutputState=TIM_OutputState_Enable;
  48.         TIM_OCInitStructure.TIM_Pulse=0;
  49.         TIM_OC3Init(TIM1,&TIM_OCInitStructure);
  50.         TIM_OC3PreloadConfig(TIM1,TIM_OCPreload_Enable);
  51.
  52. //        TIM_OCInitStructure.TIM_OutputState=TIM_OutputState_Enable;
  53. //        TIM_OCInitStructure.TIM_Pulse=125;
  54. //        TIM_OC4Init(TIM1,&TIM_OCInitStructure);
  55. //        TIM_OC4PreloadConfig(TIM1,TIM_OCPreload_Enable);
  56.   NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1);
  57.   NVIC_InitStructure.NVIC_IRQChannel=TIM1_UP_IRQn;
  58.         NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority=0;
  59.         NVIC_InitStructure.NVIC_IRQChannelSubPriority=0;
  60.         NVIC_InitStructure.NVIC_IRQChannelCmd=ENABLE;
  61.         NVIC_Init(&NVIC_InitStructure);
  62.         TIM_ITConfig(TIM1,TIM_IT_Update,ENABLE);
  63.
  64.         TIM_BDTRInitStructure.TIM_OSSRState=TIM_OSSRState_Disable;
  65.         TIM_BDTRInitStructure.TIM_OSSIState=TIM_OSSIState_Disable;
  66.         TIM_BDTRInitStructure.TIM_LOCKLevel=TIM_LOCKLevel_OFF;
  67.         TIM_BDTRInitStructure.TIM_DeadTime=0;
  68.         TIM_BDTRInitStructure.TIM_Break=TIM_Break_Disable;
  69.         TIM_BDTRInitStructure.TIM_BreakPolarity=TIM_BreakPolarity_High;
  70.         TIM_BDTRInitStructure.TIM_AutomaticOutput=TIM_AutomaticOutput_Enable;
  71.         TIM_BDTRConfig(TIM1,&TIM_BDTRInitStructure);
  72.
  73.         TIM_ARRPreloadConfig(TIM1,ENABLE);
  74.         TIM_Cmd(TIM1,ENABLE);
  75.         TIM_CtrlPWMOutputs(TIM1,ENABLE);
  76. }
xmshao 发表于 2016-9-5 15:08 | 显示全部楼层
记得开启AFIO时钟, RCC_APB2ENR_AFIOEN
 楼主| ZHOU@JIE 发表于 2016-9-5 21:02 | 显示全部楼层
问题解决了,是REMAP函数位置放错了。
放到哪里了,说说  发表于 2019-1-12 14:56
tao180539 发表于 2019-1-12 14:56 | 显示全部楼层
放到哪里了
