[技术问答] 用nuc972,移植触摸屏和qt应用,运行/mnt # ./hello -qws 报段错误
3452|8
 楼主| 烟熏味的菠萝包 发表于 2016-11-25 10:31 | 显示全部楼层 |阅读模式
开发使用的是nuc972的芯片,使用的是串口屏,AD口控制触摸屏,移植触摸屏后,能正常使用,移植qt后能正常使用
但是打开:export  QWS_MOUSE_PROTO="Tslib:/dev/input/event0"
Segmentation fault
出现以上错误。
qt编译的配置为:
配置文件qmake.conf
include(../../common/linux.conf)
  6 include(../../common/gcc-base-unix.conf)
  7 include(../../common/g++-unix.conf)
  8 include(../../common/qws.conf)
10 # modifications to g++.conf
11 QMAKE_CC                = arm-linux-gcc
12 QMAKE_CXX               = arm-linux-g++
13 QMAKE_LINK              = arm-linux-g++
14 QMAKE_LINK_SHLIB        = arm-linux-g++
15
16 # modifications to linux.conf
17 QMAKE_AR                = arm-linux-ar cqs
18 QMAKE_OBJCOPY           = arm-linux-objcopy
19 QMAKE_STRIP             = arm-linux-strip
20
21 # Support static build.
22 QMAKE_LFLAGS            = -static
23
24 # Reduce code size.
25 QMAKE_CFLAGS_RELEASE    = -Os
26 QMAKE_CXXFLAGS_RELEASE  = -Os
27
28 # Include/library path for tslib
29 QMAKE_INCDIR            = /usr/local/arm_linux_4.8/usr/include
30 QMAKE_LIBDIR            = /usr/local/arm_linux_4.8/usr/lib
配置configure配置configure:
./configure \
-prefix /home/zhang/test/qt4.8.5 \
-release \
-opensource \
-static \
-qconfig dist \
-no-exceptions \
-no-accessibility \
-no-stl \
-no-qt3support \
-no-xmlpatterns \
-no-multimedia \
-no-audio-backend \
-no-phonon \
-no-phonon-backend \
-no-svg \
-no-webkit \
-no-javascript-jit \
-no-script \
-no-scripttools \
-no-declarative \
-no-declarative-debug \
-qt-zlib \
-qt-freetype \
-no-gif \
-qt-libpng \
-no-libmng \
-no-libtiff \
-qt-libjpeg \
-no-openssl \
-nomake tools \
-nomake demos \
-nomake examples \
-nomake docs \
-nomake translations \
-no-nis \
-no-cups \
-no-iconv \
-no-pch \
-no-dbus \
-embedded arm \
-platform qws/linux-x86-g++ \
-xplatform qws/linux-nuc970-g++ \
-no-gtkstyle \
-no-nas-sound \
-no-opengl \
-no-openvg \
-no-sm \
-no-xshape \
-no-xvideo \
-no-xsync \
-no-xinerama \
-no-xcursor \
-no-xfixes \
-no-xrandr \
-no-xrender \
-no-mitshm \
-no-fontconfig \
-no-xinput \
-no-xkb \
-no-glib \
-qt-gfx-linuxfb \
-qt-mouse-tslib \
-qt-kbd-linuxinput
将编译后的lib库放入到板子的usr/qt/下,运行编译后的 程序,
在板子上能正常显示,前提是注释掉:
# export  QWS_MOUSE_PROTO="Tslib:/dev/input/event0"
tslib移植后,也能正常使用,
触摸屏的校准和测试,没有出现问题,能正常使用。
/etc/profile的设置为:
export QTDIR=/usr/qt/lib
export TSLIB_CONFFILE=/etc/ts.conf
export TSLIB_PLUGINDIR=/lib/ts
export TSLIB_TSDEVICE=/dev/input/event0
export TSLIB_CALIBFILE="/etc/pointercal"
export TSLIB_CONSOLEDEVICE="none"
export  LD_LIBRARY_PATH=/lib:$QTDIR:$LD_LIBRARY_PATH
export  QT_QWS_FONTDIR=$QTDIR/fonts/
export  QWS_SIZE=800x480
export  QWS_DISPLAY="LinuxFb:mmWidth80:mmHeight160:0"
export  QT_PLUGIN_PATH=$QTDIR/plugins/
export  POINTERCAL_FILE=/etc/pointercal
#export  QWS_KEYBOARD="TTY:/dev/tty5"
export  QWS_MOUSE_PROTO=Tslib:/dev/input/event0
export  PATH=/bin:$PATH
ts.conf的配置为:
module_raw input
module pthres pmin=1
module variance delta=30
module dejitter delta=100
module linear
全部都顶格
现在查询过网上的方法:
#export  QWS_MOUSE_PROTO="Intellimouse:/dev/input/mouse0"
注释到上面一句,用下面这句,触摸屏可用,不报错,但是指针出现漂移的现象,应该没校准,然后查询发现
因为触摸屏用到了event0和mouse0两个接口,但是我们实际要用的是event0的接口,所以不能去掉他。
现在的问题就是去掉event0,换上mouse0能用,但是指针漂移,不能校准
用上event0的时候,运行qt程序会报egmentation fault
求各位大神指导,是哪块配置错误,还是说内核中缺少该添加的东西,或者有详细的步骤,供参考的。
jonywang 发表于 2016-11-25 16:34 | 显示全部楼层
zhuomuniao110 发表于 2016-11-25 19:01 | 显示全部楼层
这个Linux的东西吧,应该去嵌入式版块问吧
 楼主| 烟熏味的菠萝包 发表于 2016-11-26 13:40 | 显示全部楼层
问题已解决,主要是qt编译的配置部分,有点问题,还有文件系统缺少了一点东西,换了文件系统,就好啦
 楼主| 烟熏味的菠萝包 发表于 2016-11-26 13:41 | 显示全部楼层
好的,谢谢
phoenight 发表于 2017-1-17 00:17 | 显示全部楼层
问题已解决,主要是qt编译的配置部分,有点问题,还有文件系统缺少了一点东西,换了文件系统,就好啦 ...
你好,能不能说下具体什么问题,我现在也遇到了类似问题
落叶行健ywm 发表于 2017-1-17 08:58 | 显示全部楼层
让我回忆起了三年前的调试想法。
依稀记得egmentation fault是段错误,就是指针错误。
开启printfk函数进行跟踪吧!qt移植的时候好像有个触摸屏配置选项的。忘了具体名字了。qt官方移植网页有的
mintspring 发表于 2017-1-17 09:05 | 显示全部楼层
楼主厉害,Linux还不错。
