程序一:
library ieee;
use ieee.std_logic_1164.all;
entity text1 is
    port(a0,a1,b:in std_logic;
                  sel:in std_logic;
              result:out std_logic);
end text1;
architecture art of text1 is
   signal temp:std_logic;
begin
   process(a0,a1,b,sel)
        begin
             if(sel='0')then
                    temp<=a0;
             else
                    temp<=a1;
             end if;
             result<=temp and b;  --在process里面
     end process;
end art;
程序二:
library ieee;
entity text2 is
                 sel:in std_logic;
end text2;
architecture art of text2 is
begin
    process(a0,a1,sel)
       begin
             if(sel='0')then
               temp<=a0;
             else
               temp<=a1;
              end if;
      end process;
      result<=temp and b;    --在process外面
end art;
     这两个程序在时序上我认为是有区别的。但是为什么两个程序的时序仿真图是一样的呢? 并且生成的RTL也是一样的,哪位高手能帮我解释一下,谢谢了! |
