串口中断函数进不去?求大神帮助?
849|1
 楼主| SHILINCHUAN 发表于 2017-4-13 10:10 | 显示全部楼层 |阅读模式
#include <m8c.h>        // part specific constants and macros
#include "PSoCAPI.h"    // PSoC API definitions for all User Modules
#pragma interrupta_handler UART_1_RX_ISR;
        char *strPtr,count;
        char iResult_up8=0,iResult_down8=0;
void yanshi(int x)
        for(x;x>0;x--)
                ;//  LCD_1_Delay50u();
void switch_INT2byte(int data)
        iResult_down8 = data;
        data = data>>8;
        iResult_up8 = data;
void main(void)
    int iResult1, iResult2,j,z;
    double  prssure1,prssure2,dianya,dianya2;
    unsigned long int sum1=0;
    unsigned long int sum2=0;
    M8C_EnableGInt;                       // Enable global interrupts
    DUALADC_Start(DUALADC_HIGHPOWER);     // Turn on Analog section
    DUALADC_SetResolution(12);            // Set resolution to 12 Bits
    DUALADC_GetSamples(0);                // Start ADC to read continuously
    PGA_1_Start(PGA_1_MEDPOWER);                         /* Turn on PGA power */
    PGA_2_Start(PGA_2_MEDPOWER);                         /* Turn on PGA power */
    LED_Start();
        UART_1_Start(UART_PARITY_NONE);                       /* Enable UART */
        UART_1_EnableInt();
        LCD_Start();                    // Initialize LCD hardware
    UART_1_CmdReset();
        //CyGlobalIntEnable;
   while (1) {
      if(DUALADC_fIsDataAvailable() == 0);  // Wait for data to be ready
                iResult1 = DUALADC_iGetData1ClearFlag();          // Get Data from ADC Input1
        iResult2 = DUALADC_iGetData2ClearFlag();
            strPtr = UART_1_szGetRestOfParams();
        } // Get Data from ADC Input2
                //while(*strPtr==97)
            while(count==1)
                     LCD_Position(0,0);             // Position cursor @ row 0, col 4
                        LCD_PrHexInt(iResult1);
                        LCD_Position(1,0);             // Position cursor @ row 0, col 4
                        LCD_PrHexInt(iResult2);
                // prssure1=sum1/5.0;
            //  dianya=prssure1/4096*5+0.03;
                // //prssure1=(dianya/5.1-0.04)/0.00369;
           //  sum1=0;
           //  prssure2=sum2/5.0;
          //   dianya2=prssure2/4096*5;
           //  prssure2=(dianya2*20.83-2)/0.4;
         //         sum2=0;
                    switch_INT2byte(iResult1 );
                    UART_1_Write(&iResult_up8,1);  //send up8
                    UART_1_Write(&iResult_down8,1);  //send down8
                        switch_INT2byte(iResult2);
                    *strPtr=0;
                     count=0;
                        UART_1_CmdReset();
                    UART_1_CmdReset();
void _UART_1_RX_ISR()
        if ( UART_1_szGetRestOfParams())
           count=1;
接收中断放在这个模块的   对应程序也已经改了
    org   28h                      ;PSoC Block DCB02 Interrupt Vector
  ljmp _UART_1_RX_ISR
    reti
  波特率这些配置是没有问题的!能发送   求大神支招    谢谢你们了!
 楼主| SHILINCHUAN 发表于 2017-4-14 10:03 | 显示全部楼层
大神些  能不能给点建议啊   卡死在这了   用扫描做串口通信  要丢数据哇   中断程序进不去?
