[STM32L0] STM32L073 AD转换
1807|5
 楼主| songxu125400 发表于 2017-5-18 21:07 | 显示全部楼层 |阅读模式
大神们好,我刚接触STM32L0系列芯片,现在搞AD转换,用HAL库,可以正常转换,但是转换时间太长了,效率很低。不知道是我程序有问题还是什么望大神们指点,谢谢。下面是我用库写的
void vInitAdc(void)
  AdcHandle.Instance = ADC1;
  AdcHandle.Init.OversamplingMode      = DISABLE;
  AdcHandle.Init.ClockPrescaler        = ADC_CLOCK_SYNC_PCLK_DIV1;
  AdcHandle.Init.LowPowerAutoPowerOff  = DISABLE;
  AdcHandle.Init.LowPowerFrequencyMode = ENABLE;
  AdcHandle.Init.LowPowerAutoWait      = DISABLE;
  AdcHandle.Init.Resolution            = ADC_RESOLUTION_12B;
  AdcHandle.Init.SamplingTime          = ADC_SAMPLETIME_7CYCLES_5;
  AdcHandle.Init.ScanConvMode          = ADC_SCAN_DIRECTION_FORWARD;
  AdcHandle.Init.DataAlign             = ADC_DATAALIGN_RIGHT;
  AdcHandle.Init.ContinuousConvMode    = DISABLE;//ENABLE;
  AdcHandle.Init.DiscontinuousConvMode = DISABLE;
  AdcHandle.Init.ExternalTrigConvEdge  = ADC_EXTERNALTRIGCONVEDGE_NONE;
  AdcHandle.Init.EOCSelection          = ADC_EOC_SINGLE_CONV;
  AdcHandle.Init.DMAContinuousRequests = DISABLE;
  /* Initialize ADC peripheral according to the passed parameters */
  if (HAL_ADC_Init(&AdcHandle) != HAL_OK)
    ;//Error_Handler();
  /* ### - 2 - Start calibration ############################################ */
  if (HAL_ADCEx_Calibration_Start(&AdcHandle, ADC_SINGLE_ENDED) != HAL_OK)
    ;//Error_Handler();
unsigned int uiADC_Result(unsigned char ucChannel)
        unsigned char i;
        unsigned int uiMaxResult = 0, uiMinResult = 0xFFFF;
        unsigned int j,uiResult = 0;
      ADC_ChannelConfTypeDef            sConfig;
      ADC1->CHSELR=0;
      ADC1->CHSELR=ucChannel;//sConfig.Channel;
     HAL_ADC_Start(&AdcHandle);
     for (i = 0;i < 6;i++)
          HAL_ADC_PollForConversion(&AdcHandle, 10);
          /* Check if the continous conversion of regular channel is finished */
          if ((HAL_ADC_GetState(&AdcHandle) & HAL_ADC_STATE_REG_EOC) == HAL_ADC_STATE_REG_EOC)
                j = HAL_ADC_GetValue(&AdcHandle);
          if (j > uiMaxResult)
                        uiMaxResult = j;
                if (j < uiMinResult)
                        uiMinResult = j;
                uiResult += j;
           uiResult -= uiMaxResult;
        uiResult -= uiMinResult;
       uiResult /= 4;
    return uiResult;
mmuuss586 发表于 2017-5-18 21:33 | 显示全部楼层
这个值这么小,正常应该很快了
 楼主| songxu125400 发表于 2017-5-18 22:03 | 显示全部楼层
这个值这么小,正常应该很快了
就是啊,就是不知道我的其他配置是否是正确的,还有取值函数里是否正确?
gygp 发表于 2017-5-19 00:12 | 显示全部楼层
你的芯片的时钟是多大的
gygp 发表于 2017-5-19 00:13 | 显示全部楼层
AdC转换跟你的系统时钟配置有关系。
mmuuss586 发表于 2017-5-19 08:17 | 显示全部楼层
就是啊,就是不知道我的其他配置是否是正确的,还有取值函数里是否正确? ...
还有时钟分频函数;
函数是否正确我也不知道,我不用HAL库的
