【AM335x】为 SD 卡创建分区的过程
1257|6
FCCdsp|  楼主 | 2017-5-24 11:48 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
首先,我用的是 VirtualBox,将 SD 卡放到 USB Adapter 之后,安装完驱动。即可执行 bin 下的 creat-sdcard.sh 脚本.
simon@simon-laptop:~/Work/ti-sdk-am335x-evm-05.04.01.00/bin$ sudo ./create-sdcard.sh
This script will create a bootable SD card from custom or pre-built binaries.
The script must be run with root permissions and from the bin directory of
the SDK
Example:
Formatting can be skipped if the SD card is already formatted and
partitioned properly.
Availible Drives to write images to:
#  major   minor    size   name
1:   8       16    3813376 sdb
Enter Device Number: 1
sdb was selected
Checking the device is unmounted
unmounted /dev/sdb1
unmounted /dev/sdb2
unmounted /dev/sdb3
sdb1  sdb2   sdb3
72261 923737 2795310
   Detected device has 3 partitions already
   Re-partitioning will allow the choice of 2 or 3 partitions
Would you like to re-partition the drive anyways [y/n] : y
Now partitioning sdb ...
        Select 2 partitions if only need boot and rootfs (most users)
        Select 3 partitions if need SDK & CCS on SD card.  This is usually used
        by device manufacturers with access to partition tarballs.
        ****WARNING**** continuing will erase all data on sdb
Number of partitions needed [2/3] : 2
Now partitioning sdb with 2 partitions...
                Now making 2 partitions
1024+0 records in
1024+0 records out
1048576 bytes (1.0 MB) copied, 2.89689 s, 362 kB/s
Disk /dev/sdb doesn't contain a valid partition table
DISK SIZE - 3904897024 bytes
Checking that no-one is using this disk right now ...
OK
Disk /dev/sdb: 474 cylinders, 255 heads, 63 sectors/track
sfdisk: ERROR: sector 0 does not have an msdos signature
/dev/sdb: unrecognized partition table type
Old situation:
No partitions found
New situation:
Units = cylinders of 8225280 bytes, blocks of 1024 bytes, counting from 0
   Device Boot Start     End   #cyls    #blocks   Id  System
/dev/sdb1   *      0+      8       9-     72261    c  W95 FAT32 (LBA)
/dev/sdb2         10     473     464    3727080   83  Linux
/dev/sdb3          0       -       0          0    0  Empty
/dev/sdb4          0       -       0          0    0  Empty
Successfully wrote the new partition table
Re-reading the partition table ...
If you created or changed a DOS partition, /dev/foo7, say, then use dd(1)
to zero the first 512 bytes:  dd if=/dev/zero of=/dev/foo7 bs=512 count=1
(See fdisk(8).)
                Partitioning Boot
mkfs.vfat 3.0.7 (24 Dec 2009)
                Partitioning rootfs
mke2fs 1.41.11 (14-Mar-2010)
Filesystem label=rootfs
OS type: Linux
Block size=4096 (log=2)
Fragment size=4096 (log=2)
Stride=0 blocks, Stripe width=0 blocks
233392 inodes, 931770 blocks
46588 blocks (5.00%) reserved for the super user
First data block=0
Maximum filesystem blocks=956301312
29 block groups
32768 blocks per group, 32768 fragments per group
8048 inodes per group
Superblock backups stored on blocks:
        32768, 98304, 163840, 229376, 294912, 819200, 884736
Writing inode tables: done
Creating journal (16384 blocks): done
Writing superblocks and filesystem accounting information: done
This filesystem will be automatically checked every 31 mounts or
180 days, whichever comes first.  Use tune2fs -c or -i to override.
   Partitioning is now done
   Continue to install filesystem or select 'n' to safe exit
   **Warning** Continuing will erase files any files in the partitions
Would you like to continue? [y/n] : y
Mount the partitions
Emptying partitions
Syncing....
        Choose file path to install from
        1 ) Install pre-built images from SDK
        2 ) Enter in custom boot and rootfs file paths
Choose now [1/2] : 1
Will now install from SDK pre-built images
now installing:  ti-sdk-am335x-evm-05.04.01.00
        Copying files now... will take minutes
Copying boot partition
MLO copied
u-boot.bin file not found
u-boot.img copied
uImage copied
Copying rootfs System partition
Written 100%
Syncing...
Un-mount the partitions
Remove created temp directories
Operation Finished
qudongdong| | 2017-5-29 09:46 | 只看该作者
你好 我用AM335x  SD卡启动时 没有反应 什么也没输出  拔掉SD卡 打印CCC......  不知道大神可遇到过这样的问题
51xlf| | 2017-5-29 22:56 | 只看该作者
这个直接SD卡能不能启动?
51xlf| | 2017-5-29 23:00 | 只看该作者
嵌入式开发不是很容易。
lzmm| | 2017-6-2 23:12 | 只看该作者
这个外部的SD直接启动芯片?
lzmm| | 2017-6-2 23:15 | 只看该作者
不是使用内部的EMMC加载的吗?
acq| | 2019-7-15 11:26 | 只看该作者
qudongdong 发表于 2017-5-29 09:46
你好 我用AM335x  SD卡启动时 没有反应 什么也没输出  拔掉SD卡 打印CCC......  不知道大神可遇到过这样的 ...
跟我遇到的一模一样
