[应用相关]
通过ADC测量 AVDD电压
1974|31
* [url=home.php?mod=space&uid=288409]@file[/url]     main.c
* [url=home.php?mod=space&uid=895143]@version[/url]  V2.0
* $Revision: 1 $
* $Date: 16/06/22 10:09a $
* @brief
*           Measure AVDD voltage by ADC.
* @note
* Copyright (C) 2014~2015 Nuvoton Technology Corp. All rights reserved.
#include <stdio.h>
#include "NUC123.h"
#define PLL_CLOCK       72000000
#define VBG_VOLTAGE (1200) /* 1.20V = 1200 mV (Typical band-gap voltage) */
#define ADC_SAMPLE_COUNT 128 /* The last line of GetAVDDCodeByADC() need revise when ADC_SAMPLE_COUNT is changed. */
/* For example, if ADC_SAMPLE_COUNT is changed to 64, then the code need revised to "return (u32Sum >> 6);" */
/* Define Function Prototypes        */
void SYS_Init(void);
void UART0_Init(void);
void AdcMeasureAVDD(void);
uint32_t GetAVDDCodeByADC(void);
uint32_t GetAVDDVoltage(void);
/* Define global variables and constants        */
volatile uint8_t g_u8ADF;
void SYS_Init(void)
    /* Init System Clock        */
    /* Enable Internal RC 22.1184MHz clock */
    CLK_EnableXtalRC(CLK_PWRCON_OSC22M_EN_Msk);
    /* Waiting for Internal RC clock ready */
    CLK_WaitClockReady(CLK_CLKSTATUS_OSC22M_STB_Msk);
    /* Switch HCLK clock source to Internal RC and HCLK source divide 1 */
    CLK_SetHCLK(CLK_CLKSEL0_HCLK_S_HIRC, CLK_CLKDIV_HCLK(1));
    /* Enable XT1_OUT(PF.0) and XT1_IN(PF.1) */
    SYS->GPF_MFP |= SYS_GPF_MFP_PF0_XT1_OUT | SYS_GPF_MFP_PF1_XT1_IN;
    /* Enable external XTAL 12MHz clock */
    CLK_EnableXtalRC(CLK_PWRCON_XTL12M_EN_Msk);
    /* Waiting for external XTAL clock ready */
    CLK_WaitClockReady(CLK_CLKSTATUS_XTL12M_STB_Msk);
    /* Set core clock as PLL_CLOCK from PLL */
    CLK_SetCoreClock(PLL_CLOCK);
    /* Enable UART module clock */
    CLK_EnableModuleClock(UART0_MODULE);
    /* Enable ADC module clock */
    CLK_EnableModuleClock(ADC_MODULE);
    /* Select UART module clock source */
    CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UART_S_PLL, CLK_CLKDIV_UART(1));
    /* ADC clock source is 22.1184MHz, set divider to 7, ADC clock is 22.1184/7 MHz */
    CLK_SetModuleClock(ADC_MODULE, CLK_CLKSEL1_ADC_S_HIRC, CLK_CLKDIV_ADC(7));
    /* Init I/O Multi-function        */
    /* Set GPB multi-function pins for UART0 RXD and TXD */
    SYS->GPB_MFP &= ~(SYS_GPB_MFP_PB0_Msk | SYS_GPB_MFP_PB1_Msk);
    SYS->GPB_MFP |= SYS_GPB_MFP_PB0_UART0_RXD | SYS_GPB_MFP_PB1_UART0_TXD;
/* Init UART        */
void UART0_Init()
    /* Reset IP */
    SYS_ResetModule(UART0_RST);
    /* Configure UART0 and set UART0 Baudrate */
    UART_Open(UART0, 115200);
/* Function: GetAVDDVoltage        */
/* Parameters:        */
/*   None.        */
/* Returns:        */
/*   AVDD voltage(mV).        */
/* Description:        */
/*   Use Band-gap voltage to calculate AVDD voltage                                                        */
    uint32_t  u32ConversionResult;
    uint64_t u64MvAVDD;
    /* Calculate Vref by using conversion result of VBG */
    u32ConversionResult = GetAVDDCodeByADC();
    /* u32ConversionResult = VBG * 1024 / Vref, Vref = AVDD */
    /* => AVDD = VBG * 1024 / u32ConversionResult */
    u64MvAVDD = (VBG_VOLTAGE << 10) / (uint64_t)u32ConversionResult;
    printf("Conversion result: 0x%X\n", u32ConversionResult);
    return (uint32_t)u64MvAVDD;
/* Function: GetAVDDCodeByADC        */
/* Parameters:        */
/*   None.        */
/* Returns:        */
/*   ADC code of AVDD voltage.        */
/* Description:        */
/*   Get ADC conversion result of Band-gap voltage.                                                        */
    uint32_t u32Count, u32Sum, u32Data;
    /* Configure ADC: single-end input, single scan mode, enable ADC analog circuit. */
    ADC_Open(ADC, NULL, ADC_ADCR_ADMD_SINGLE, BIT7);
    /* Configure the analog input source of channel 7 as internal band-gap voltage */
    ADC_CONFIG_CH7(ADC, ADC_ADCHER_PRESEL_INT_BANDGAP);
    /* Power on ADC */
    ADC_POWER_ON(ADC);
    /* Clear conversion finish flag */
    ADC_CLR_INT_FLAG(ADC, ADC_ADF_INT);
    /* Enable ADC conversion finish interrupt */
    ADC_EnableInt(ADC, ADC_ADF_INT);
    NVIC_EnableIRQ(ADC_IRQn);
    g_u8ADF = 0;
    u32Sum = 0;
    /* sample times are according to ADC_SAMPLE_COUNT definition */
    for(u32Count = 0; u32Count < ADC_SAMPLE_COUNT; u32Count++)
        /* Delay for band-gap voltage stability */
        CLK_SysTickDelay(100);
        /* Start A/D conversion */
        ADC_START_CONV(ADC);
        u32Data = 0;
        /* Wait conversion done */
        while(g_u8ADF == 0);
        g_u8ADF = 0;
        /* Get the conversion result */
        u32Data = ADC_GET_CONVERSION_DATA(ADC, 7);
        /* Sum each conversion data */
        u32Sum += u32Data;
    /* Disable ADC interrupt */
    ADC_DisableInt(ADC, ADC_ADF_INT);
    /* Disable ADC */
    ADC_POWER_DOWN(ADC);
    /* Return the average of ADC_SAMPLE_COUNT samples */
    return (u32Sum >> 7);
/* ADC interrupt handler        */
void ADC_IRQHandler(void)
    uint32_t u32Flag;
    /* Get ADC conversion finish interrupt flag */
    u32Flag = ADC_GET_INT_FLAG(ADC, ADC_ADF_INT);
    /* Check ADC conversion finish */
    if(u32Flag & ADC_ADF_INT)
        g_u8ADF = 1;
    ADC_CLR_INT_FLAG(ADC, u32Flag);
/* MAIN function        */
main(void)
    uint32_t u32AVDDVoltage;
    /* Unlock protected registers */
    SYS_UnlockReg();
    /* Init System, IP clock and multi-function I/O */
    SYS_Init();
    /* Lock protected registers */
    SYS_LockReg();
    /* Init UART0 for printf */
    UART0_Init();
    /* SAMPLE CODE        */
    printf("\nSystem clock rate: %d Hz\n", SystemCoreClock);
    printf("+----------------------------------------------------------------------+\n");
    printf("|                 ADC for AVDD Measurement sample code                 |\n");
    printf("\nIn this sample code, software will get voltage value from AVDD.\n");
       The method of measured AVDD voltage is using ADC to get conversion result of band-gap voltage.
       For example, the typical value of band-gap voltage is 1.20 V, and Vref of ADC is from AVDD.
       Through getting ADC conversion result of band-gap voltage, then AVDD voltage can be calculated by below formula:
           ConversionResult = VBG * 1024 / Vref, Vref = AVDD and VBG = 1.20V
           => AVDD = 1.20V * 1024 / ConversionResult
       Note 1 : The measured AVDD has deviation that causes by the band-gap voltage has deviation in different temperature, power voltage and ADC conversion deviation.(4 LSB)
                The deviation of measured AVDD is list as follows:
                The Spec. of band-gap voltage in NUC123 series is as follows:
                |                  | Min.   | Typ.   | Max.   |                                         |
                |                  |--------------------------- VDD = 2.5 V ~ 5.5 V                     |
                | band-gap voltage | 1.18 V | 1.20 V | 1.22 V | temperature = -40 ~ 110 degrees Celsius |
                Deviation range of measured AVDD
                |                | Min. Deviation | Max. Deviation |
                |                | VBG = 1.18 V   | VBG = 1.22 V   |
                |  AVDD = 2.5 V  |   -4.57%       |    4.86%       |
                |  AVDD = 5.5 V  |   -7.85%       |    8.98%       |
       Note 2: The typical value of band-gap voltage can be modified by VBG_VOLTAGE definition.
    /* Measure AVDD */
    u32AVDDVoltage = GetAVDDVoltage();
    printf("AVDD Voltage: %dmV\n", u32AVDDVoltage);
    /* Disable ADC module */
    ADC_Close(ADC);
    /* Disable ADC IP clock */
    CLK_DisableModuleClock(ADC_MODULE);
    /* Disable External Interrupt */
    NVIC_DisableIRQ(ADC_IRQn);
    printf("\nExit ADC sample code\n");
    while(1);
天灵灵地灵灵|  楼主 | 2017-6-25 17:39 | 只看该作者
通过一个通道测量自身电压,作为自检程序,很不错的
aspoke| | 2017-6-25 21:26 | 只看该作者
怎么样保持基准电压?
232321122| | 2017-6-25 21:27 | 只看该作者
这个的效果怎么样?
ghuca| | 2017-6-25 21:27 | 只看该作者
ADC采样数据准确。
xiaoyaozt| | 2017-6-25 21:28 | 只看该作者
这个的参考电源来自哪里?
soodesyt| | 2017-6-25 21:28 | 只看该作者
来个硬件电路参考一下。
plsbackup| | 2017-6-25 21:29 | 只看该作者
这个应该是配合硬件电路使用吧。
eefas| | 2017-6-25 21:30 | 只看该作者
使用外部的参考电压可以实现。
qiufengsd| | 2017-6-25 21:31 | 只看该作者
soodesyt 发表于 2017-6-25 21:28
来个硬件电路参考一下。
硬件电路使用开发板就可以。
jstgotodo| | 2017-6-25 21:31 | 只看该作者
ghuca 发表于 2017-6-25 21:27
ADC采样数据准确。
采样准确是12位ADC分辨率。
aspoke| | 2017-6-25 21:32 | 只看该作者
电压变化之后参考电压没有问题吗?
232321122| | 2017-6-25 21:32 | 只看该作者
想实现一个低电压的保护电路。
ghuca| | 2017-6-25 21:32 | 只看该作者
ST的ADC是12位的ADC采样。
xiaoyaozt| | 2017-6-25 21:32 | 只看该作者
有维持基准电压的芯片吗?
soodesyt| | 2017-6-25 21:32 | 只看该作者
Measure AVDD voltage的ref电压呢?
plsbackup| | 2017-6-25 21:32 | 只看该作者
这个代码就是基本的ADC采样代码。
eefas| | 2017-6-25 21:32 | 只看该作者
锂电池可以稳定为3.3V电压。
qiufengsd| | 2017-6-25 21:32 | 只看该作者
来个硬件电路参考一下。
现在的STM32都有评估板。
jstgotodo| | 2017-6-25 21:32 | 只看该作者
ADC采样数据准确。
还是外部的ADC更精确一些。
