[技术问答] 想在i2c设置一个结束状态,但就不是行
2482|6
 楼主| shen_hao 发表于 2017-7-10 20:34 | 显示全部楼层 |阅读模式
I2c, TE, TI, se
这是master
#include <stdio.h>
#include "M451Series.h"
#define PLLCTL_SETTING  CLK_PLLCTL_72MHz_HXT
#define PLL_CLOCK       72000000
/* Global variables        */
volatile uint8_t g_u8DeviceAddr;
volatile uint8_t g_au8MstTxData[3];
volatile uint8_t g_u8MstRxData;
volatile uint8_t g_u8MstDataLen;
volatile uint8_t g_u8MstEndFlag = 0;
typedef void (*I2C_FUNC)(uint32_t u32Status);
static volatile I2C_FUNC s_I2C0HandlerFn = NULL;
int8_t g_u8RecData[100]  = {0};
volatile uint32_t g_u32comRbytes = 0;
volatile uint32_t g_u32comRhead  = 0;
volatile uint32_t g_u32comRtail  = 0;
volatile int32_t g_bWait         = TRUE;
volatile uint8_t g_u8Flag = 0;
/*  I2C0 IRQ Handler        */
void I2C0_IRQHandler(void)
    uint32_t u32Status;
    u32Status = I2C_GET_STATUS(I2C0);
    if(I2C_GET_TIMEOUT_FLAG(I2C0))
        /* Clear I2C0 Timeout Flag */
        I2C_ClearTimeoutFlag(I2C0);
    else
        if(s_I2C0HandlerFn != NULL)
            s_I2C0HandlerFn(u32Status);
void UART0_IRQHandler(void)
     uint8_t u8InChar = 0xFF;
    uint32_t u32IntSts = UART0->INTSTS;
    if(u32IntSts & UART_INTSTS_RDAINT_Msk)
        /* Get all the input characters */
        while(UART_IS_RX_READY(UART0))
            /* Get the character from UART Buffer */
            u8InChar = UART_READ(UART0);
            if(u8InChar == '0')
                g_bWait = FALSE;
            /* Check if buffer full */
            if(g_u32comRbytes < 100)
                /* Enqueue the character */
                g_u8RecData[g_u32comRtail] = u8InChar;
                g_u32comRtail = (g_u32comRtail == (100 - 1)) ? 0 : (g_u32comRtail + 1);
                g_u32comRbytes++;
/*  I2C Rx Callback Function        */
void I2C_MasterRx(uint32_t u32Status)
    if(u32Status == 0x08)                       /* START has been transmitted and prepare SLA+W */
        I2C_SET_DATA(I2C0, (g_u8DeviceAddr << 1));    /* Write SLA+W to Register I2CDAT */
        I2C_SET_CONTROL_REG(I2C0, I2C_CTL_SI);
    else if(u32Status == 0x18)                  /* SLA+W has been transmitted and ACK has been received */
        I2C_SET_DATA(I2C0, g_au8MstTxData[g_u8MstDataLen++]);
    else if(u32Status == 0x20)                  /* SLA+W has been transmitted and NACK has been received */
        I2C_STOP(I2C0);
        I2C_START(I2C0);
    else if(u32Status == 0x28)                  /* DATA has been transmitted and ACK has been received */
        if(g_u8MstDataLen != 2)
        else
            I2C_SET_CONTROL_REG(I2C0, I2C_CTL_STA_SI);
    else if(u32Status == 0x10)                  /* Repeat START has been transmitted and prepare SLA+R */
        I2C_SET_DATA(I2C0, ((g_u8DeviceAddr << 1) | 0x01));   /* Write SLA+R to Register I2CDAT */
    else if(u32Status == 0x40)                  /* SLA+R has been transmitted and ACK has been received */
    else if(u32Status == 0x58)                  /* DATA has been received and NACK has been returned */
        g_u8MstRxData = (unsigned char) I2C_GET_DATA(I2C0);
        I2C_SET_CONTROL_REG(I2C0, I2C_CTL_STO_SI);
        g_u8MstEndFlag = 1;
    else
        /* TO DO */
        printf("Status 0x%x is NOT processed\n", u32Status);
/*  I2C Tx Callback Function        */
void I2C_MasterTx(uint32_t u32Status)
    if(u32Status == 0x08)                       /* START has been transmitted */
        I2C_SET_DATA(I2C0, g_u8DeviceAddr << 1);    /* Write SLA+W to Register I2CDAT */
        I2C_SET_DATA(I2C0, g_u32comRbytes);
        I2C_STOP(I2C0);
        I2C_START(I2C0);
        if(g_u8MstDataLen < g_u32comRbytes)
            I2C_SET_DATA(I2C0, g_u8RecData[g_u8MstDataLen++]);
        else
            g_u8MstEndFlag = 1;
    else
        /* TO DO */
void SYS_Init(void)
    /* Init System Clock        */
    /* Enable Internal RC 22.1184MHz clock */
    CLK_EnableXtalRC(CLK_PWRCTL_HIRCEN_Msk);
    /* Waiting for Internal RC clock ready */
    CLK_WaitClockReady(CLK_STATUS_HIRCSTB_Msk);
    /* Switch HCLK clock source to Internal RC and HCLK source divide 1 */
    CLK_SetHCLK(CLK_CLKSEL0_HCLKSEL_HIRC, CLK_CLKDIV0_HCLK(1));
    /* Enable external XTAL 12MHz clock */
    CLK_EnableXtalRC(CLK_PWRCTL_HXTEN_Msk);
    /* Waiting for external XTAL clock ready */
    CLK_WaitClockReady(CLK_STATUS_HXTSTB_Msk);
    /* Set core clock as PLL_CLOCK from PLL */
    CLK_SetCoreClock(PLL_CLOCK);
    /* Enable UART module clock */
    CLK_EnableModuleClock(UART0_MODULE);
    /* Enable I2C0 module clock */
    CLK_EnableModuleClock(I2C0_MODULE);
    /* Select UART module clock source */
    CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UARTSEL_HXT, CLK_CLKDIV0_UART(1));
    /* Init I/O Multi-function        */
    /* Set PD multi-function pins for UART0 RXD, TXD and */
    SYS->GPD_MFPL &= ~(SYS_GPD_MFPL_PD6MFP_Msk | SYS_GPD_MFPL_PD1MFP_Msk);
    SYS->GPD_MFPL |= (SYS_GPD_MFPL_PD6MFP_UART0_RXD | SYS_GPD_MFPL_PD1MFP_UART0_TXD);
//    /* Set I2C PA multi-function pins */
//    SYS->GPA_MFPL &= ~(SYS_GPA_MFPL_PA2MFP_Msk | SYS_GPA_MFPL_PA3MFP_Msk);
//    SYS->GPA_MFPL |= (SYS_GPA_MFPL_PA2MFP_I2C0_SDA | SYS_GPA_MFPL_PA3MFP_I2C0_SCL);
    SYS->GPD_MFPL &= ~(SYS_GPD_MFPL_PD4MFP_Msk | SYS_GPD_MFPL_PD5MFP_Msk);
    SYS->GPD_MFPL |= (SYS_GPD_MFPL_PD4MFP_I2C0_SDA | SYS_GPD_MFPL_PD5MFP_I2C0_SCL);
void UART0_Init()
    /* Init UART        */
    /* Reset IP */
    SYS_ResetModule(UART0_RST);
    /* Configure UART0 and set UART0 Baudrate */
    UART_Open(UART0, 115200);
void I2C0_Init(void)
    /* Open I2C module and set bus clock */
    I2C_Open(I2C0, 100000);
    /* Get I2C0 Bus Clock */
    printf("I2C clock %d Hz\n", I2C_GetBusClockFreq(I2C0));
    /* Set I2C 4 Slave Addresses */
    I2C_SetSlaveAddr(I2C0, 0, 0x15, 0);   /* Slave Address : 0x15 */
    I2C_SetSlaveAddr(I2C0, 1, 0x35, 0);   /* Slave Address : 0x35 */
    I2C_SetSlaveAddr(I2C0, 2, 0x55, 0);   /* Slave Address : 0x55 */
    I2C_SetSlaveAddr(I2C0, 3, 0x75, 0);   /* Slave Address : 0x75 */
    /* Enable I2C interrupt */
    I2C_EnableInt(I2C0);
    NVIC_EnableIRQ(I2C0_IRQn);
void I2C0_Close(void)
    /* Disable I2C0 interrupt and clear corresponding NVIC bit */
    I2C_DisableInt(I2C0);
    NVIC_DisableIRQ(I2C0_IRQn);
    /* Disable I2C0 and close I2C0 clock */
    I2C_Close(I2C0);
    CLK_DisableModuleClock(I2C0_MODULE);
int32_t I2C0_Read_Write_SLAVE(uint8_t slvaddr)
    uint32_t i;
    g_u8DeviceAddr = slvaddr;
                g_u8MstDataLen = 0;
                g_u8MstEndFlag = 0;
                /* I2C function to write data to slave */
                s_I2C0HandlerFn = (I2C_FUNC)I2C_MasterTx;
                /* I2C as master sends START signal */
                I2C_SET_CONTROL_REG(I2C0, I2C_CTL_STA);
                /* Wait I2C Tx Finish */
                while(g_u8MstEndFlag == 0);
                g_u8MstEndFlag = 0;
    return 0;
/*  Main Function        */
int32_t main(void)
          uint8_t i = 0;
    /* Unlock protected registers */
    SYS_UnlockReg();
    /* Init System, IP clock and multi-function I/O */
    SYS_Init();
    /* Init UART0 for printf */
    UART0_Init();
    /* Lock protected registers */
    SYS_LockReg();
        This sample code sets I2C bus clock to 100kHz. Then, Master accesses Slave with Byte Write
        and Byte Read operations, and check if the read data is equal to the programmed data.
    printf("\n");
    printf("+--------------------------------------------------------+\n");
    printf("| M451 I2C Driver Sample Code(Master) for access Slave   |\n");
    printf("|                                                        |\n");
    printf("| I2C Master (I2C0) <---> I2C Slave(I2C0)                |\n");
    printf("Configure I2C0 as a master.\n");
    printf("The I/O connection for I2C0:\n");
    /* Init I2C0 */
                //init uart0
    UART_EnableInt(UART0, (UART_INTEN_RDAIEN_Msk));
    while(g_bWait);
    printf("uart0 close\n");
    UART_DisableInt(UART0, (UART_INTEN_RDAIEN_Msk));
    I2C0_Init();/* Access Slave with no address */
    I2C0_Read_Write_SLAVE(0x15);
    /* Close I2C0 */
    I2C0_Close();
    for(;i<g_u32comRtail;i++)
                         printf("%c\t",g_u8RecData);
    while(1);
 楼主| shen_hao 发表于 2017-7-10 20:35 | 显示全部楼层
这是slave
#include <stdio.h>
uint8_t flag = 0;
uint8_t length  = 0;
uint32_t slave_buff_addr;
uint8_t g_au8SlvData[100] = {0};
uint8_t g_au8SlvRxData[3];
volatile uint8_t g_u8SlvDataLen;
static I2C_FUNC s_I2C0HandlerFn = NULL;
    uint32_t u32Status;
    else
/*  I2C TRx Callback Function        */
void I2C_SlaveTRx(uint32_t u32Status)
    if(u32Status == 0x60)                       /* Own SLA+W has been receive; ACK has been return */
        g_u8SlvDataLen = 0;
        I2C_SET_CONTROL_REG(I2C0, I2C_CTL_SI_AA);
    else if(u32Status == 0x80)                 /* Previously address with own SLA address
                                                   Data has been received; ACK has been returned*/
      if(flag == 0)
                                length = I2C_GET_DATA(I2C0);
                                flag++;
                        if(flag==1)
          if(g_u8SlvDataLen < length)
                                                  g_au8SlvRxData[g_u8SlvDataLen] = (unsigned char) I2C_GET_DATA(I2C0);
                                                        g_u8SlvDataLen++;
                                        else
                                                flag++;
                        if(flag == 2)
    else if(u32Status == 0xA8)                  /* Own SLA+R has been receive; ACK has been return */
        I2C_SET_DATA(I2C0, g_au8SlvData[slave_buff_addr]);
        slave_buff_addr++;
    else if(u32Status == 0xC0)                 /* Data byte or last data in I2CDAT has been transmitted
                                                   Not ACK has been received */
    else if(u32Status == 0x88)                 /* Previously addressed with own SLA address; NOT ACK has
                                                   been returned */
        g_u8SlvDataLen = 0;
    else if(u32Status == 0xA0)                 /* A STOP or repeated START has been received while still
                                                   addressed as Slave/Receiver*/
        g_u8SlvDataLen = 0;
    else
        /* TO DO */
void SYS_Init(void)
void UART0_Init()
    /* Init UART        */
    /* Reset IP */
    I2C_Close(I2C0);
/*  Main Function        */
int32_t main(void)
    uint32_t i,stage;
    SYS_UnlockReg();
    SYS_Init();
    UART0_Init();
    SYS_LockReg();
    printf("|  M451 I2C Driver Sample Code(Slave) for access Slave   |\n");
    printf("|                                                        |\n");
    printf("Configure I2C0 as a slave.\n");
    printf("I2C0_SDA(PA.2), I2C0_SCL(PA.3)\n");
    /* Init I2C0 */
    I2C0_Init();
    /* I2C enter no address SLV mode */
    /* I2C function to Slave receive/transmit data */
    s_I2C0HandlerFn = I2C_SlaveTRx;
    while(flag != 2);
                I2C0_Close();
                for(i= 0;i<g_u8SlvDataLen;i++)
                        printf("%c\t",g_au8SlvRxData);
    while(1);
 楼主| shen_hao 发表于 2017-7-10 20:36 | 显示全部楼层
这是slave
#include
这是一个我想从uart接收,以i2c传给从机的程序,希望大神帮我看看
这是slave
#include
643757107 发表于 2017-7-11 09:16 | 显示全部楼层
你先单独调试这两个接口。看看
 楼主| shen_hao 发表于 2017-7-11 09:35 | 显示全部楼层
你先单独调试这两个接口。看看
在slave文件中,停在对while(flag!=2);
但flag是一定等于2的,我愿意是程序在flag==2处终止,我在flag==2处加printf,我也能查看大数据都接收到了。
所以我猜想两种可能,1,程序一直停在中断中,一直没有机会检查flag的值。2,flag在某个地方呗重新置为0,但这就更匪夷所思了!
643757107 发表于 2017-7-11 12:40 | 显示全部楼层
中断后清理中断标记应该就可以回到主程序线了吧
