[技术问答] mini58 power down
1365|6
 楼主| [积木] 发表于 2017-8-10 10:11 | 显示全部楼层 |阅读模式
请问一下,关于mini58 在power down模式下如何使用gpio唤醒?
a_ziliu 发表于 2017-8-10 10:28 | 显示全部楼层
#include <stdio.h>
#include "Mini58Series.h"
#include "GPIO.h"
* @brief       Port0/Port1 IRQ
* @param       None
* @return      None
* @Details     The Port0/Port1 default IRQ, declared in startup_Mini58.s.
void GPIO01_IRQHandler(void)
    /* To check if P1.5 interrupt occurred */
    if (P1->INTSRC & BIT5) {
        P1->INTSRC = BIT5;
        P30 = P30 ^ 1;
        printf("P1.5 INT occurred. \n");
    } else {
        /* Un-expected interrupt. Just clear all PORT0, PORT1 interrupts */
        P0->INTSRC = P0->INTSRC;
        P1->INTSRC = P1->INTSRC;
        printf("Un-expected interrupts. \n");
* @brief       Port2/Port3/Port4 IRQ
* @param       None
* @return      None
* @details     The Port2/Port3/Port4 default IRQ, declared in startup_Mini58.s.
void GPIO234_IRQHandler(void)
    /* To check if P2.2 interrupt occurred */
    if (P2->INTSRC & BIT2) {
        P2->INTSRC = BIT2;
        P30 = P30 ^ 1;
        printf("P2.2 INT occurred. \n");
    } else {
        /* Un-expected interrupt. Just clear all PORT2, PORT3 and PORT4 interrupts */
        P2->INTSRC = P2->INTSRC;
        P3->INTSRC = P3->INTSRC;
        P4->INTSRC = P4->INTSRC;
* @brief       External INT0 IRQ
* @param       None
* @return      None
* @details     The External INT0(P3.2) default IRQ, declared in startup_Mini58.s.
void EINT0_IRQHandler(void)
    /* For P3.2, clear the INT flag */
    P3->INTSRC = BIT2;
    P30 = P30 ^ 1;
    printf("P3.2 EINT0 occurred. \n");
* @brief       External INT1 IRQ
* @param       None
* @return      None
* @details     The External INT1(P5.2) default IRQ, declared in startup_Mini58.s.
void EINT1_IRQHandler(void)
    /* For P5.2, clear the INT flag */
    P5->INTSRC = BIT2;
    P30 = P30 ^ 1;
    printf("P5.2 EINT1 occurred. \n");
void SYS_Init(void)
    /* Unlock protected registers */
    SYS_UnlockReg();
    /* Set P5 multi-function pins for XTAL1 and XTAL2 */
    SYS->P5_MFP &= ~(SYS_MFP_P50_Msk | SYS_MFP_P51_Msk);
    SYS->P5_MFP |= (SYS_MFP_P50_XT1_IN | SYS_MFP_P51_XT1_OUT);
    /* Init System Clock        */
    /* Enable external 12MHz XTAL, HIRC */
    CLK->PWRCTL |= CLK_PWRCTL_XTL12M | CLK_PWRCTL_HIRCEN_Msk;
    /* Waiting for clock ready */
    CLK_WaitClockReady(CLK_STATUS_XTLSTB_Msk | CLK_STATUS_HIRCSTB_Msk);
    /* Switch HCLK clock source to XTL */
    CLK_SetHCLK(CLK_CLKSEL0_HCLKSEL_XTAL,CLK_CLKDIV_HCLK(1));
    /* STCLK to XTL STCLK to XTL */
    CLK_SetSysTickClockSrc(CLK_CLKSEL0_STCLKSEL_XTAL);
    /* Enable IP clock */
    CLK_EnableModuleClock(UART0_MODULE);
    /* Select IP clock source */
    CLK_SetModuleClock(UART0_MODULE,CLK_CLKSEL1_UARTSEL_XTAL,CLK_CLKDIV_UART(1));
    /* Init I/O Multi-function        */
    /* Set P1 multi-function pins for UART RXD, TXD */
    SYS->P1_MFP = SYS_MFP_P12_UART0_RXD | SYS_MFP_P13_UART0_TXD;
    /* Set P3 multi-function pins for Clock Output */
    SYS->P3_MFP = SYS_MFP_P36_CLKO;
    /* To update the variable SystemCoreClock */
    SystemCoreClockUpdate();
    /* Lock protected registers */
    SYS_LockReg();
void UART_Init(void)
    /* Init UART        */
    /* Reset IP */
    SYS_ResetModule(SYS_IPRST1_UART0RST_Msk);
    /* Configure UART and set UART Baudrate */
    UART_Open(UART0, 115200);
void PowerDownFunction(void)
    /* Check if all the debug messages are finished */
    UART_WAIT_TX_EMPTY(UART0);
    /* Enable Power-down mode wake-up interrupt */
    CLK->PWRCTL |= CLK_PWRCTL_PDWKIEN_Msk;
    /* Enter to Power-down mode */
    CLK_PowerDown();
/* MAIN function        */
int main (void)
    int32_t i32Err;
    /* Init System, IP clock and multi-function I/O */
    SYS_Init(); //In the end of SYS_Init() will issue SYS_LockReg() to lock protected register. If user want to write protected register, please issue SYS_UnlockReg() to unlock protected register.
    /* Init UART for printf */
    UART_Init();
    printf("\n\nCPU @ %dHz\n", SystemCoreClock);
    printf("+-------------------------------------+ \n");
    printf("|    Mini58 GPIO Driver Sample Code  | \n");
    /* GPIO Basic Mode Test --- Use Pin Data Input/Output to control GPIO pin                              */
    printf("  >> Please connect P1.0 and P3.4 first << \n");
    printf("     Press any key to start test by using [Pin Data Input/Output Control] \n\n");
    getchar();
    /* Configure P1.0 as Output mode and P3.4 as Input mode then close it */
    GPIO_SetMode(P1, BIT0, GPIO_MODE_OUTPUT);
    GPIO_SetMode(P3, BIT4, GPIO_MODE_INPUT);
    i32Err = 0;
    printf("  GPIO Output/Input test ...... \n");
    /* Use Pin Data Input/Output Control to pull specified I/O or get I/O pin status */
    P10 = 0;
    if (P34 != 0) {
        i32Err = 1;
    P10 = 1;
    if (P34 != 1) {
        i32Err = 1;
    if ( i32Err ) {
        printf("  [FAIL] --- Please make sure P1.0 and P3.4 are connected. \n");
    } else {
        printf("  [OK] \n");
    /* Configure P1.0 and P3.4 to default Quasi-bidirectional mode */
    GPIO_SetMode(P1, BIT0, GPIO_MODE_QUASI);
    GPIO_SetMode(P3, BIT4, GPIO_MODE_QUASI);
    /* GPIO Interrupt Function Test        */
    printf("\n  P15, P22, P32(INT0) and P52(INT1) are used to test interrupt\n  and control LEDs(P30)\n");
    /*Configure P30 for LED control */
    GPIO_SetMode(P3, BIT0, GPIO_MODE_OUTPUT);
    /* Configure P1.5 as Input mode and enable interrupt by rising edge trigger */
    GPIO_SetMode(P1, BIT5, GPIO_MODE_INPUT);
    GPIO_EnableInt(P1, 5, GPIO_INT_RISING);
    NVIC_EnableIRQ(GPIO01_IRQn);
    /*  Configure P2.2 as Quasi-bidirection mode and enable interrupt by falling edge trigger */
    GPIO_SetMode(P2, BIT2, GPIO_MODE_QUASI);
    GPIO_EnableInt(P2, 2, GPIO_INT_FALLING);
    NVIC_EnableIRQ(GPIO234_IRQn);
    /* Configure P3.2 as EINT0 pin and enable interrupt by falling edge trigger */
    GPIO_SetMode(P3, BIT2, GPIO_MODE_INPUT);
    GPIO_EnableEINT0(P3, 2, GPIO_INT_FALLING);
    NVIC_EnableIRQ(EINT0_IRQn);
    /* Configure P5.2 as EINT1 pin and enable interrupt by rising and falling edge trigger */
    GPIO_SetMode(P5, BIT2, GPIO_MODE_INPUT);
    GPIO_EnableEINT1(P5, 2, GPIO_INT_BOTH_EDGE);
    NVIC_EnableIRQ(EINT1_IRQn);
    /* Enable interrupt de-bounce function and select de-bounce sampling cycle time */
    GPIO_SET_DEBOUNCE_TIME(GPIO_DBCTL_DBCLKSRC_HCLK, GPIO_DBCTL_DBCLKSEL_1);
    GPIO_ENABLE_DEBOUNCE(P1, BIT5);
    GPIO_ENABLE_DEBOUNCE(P2, BIT2);
    GPIO_ENABLE_DEBOUNCE(P3, BIT2);
    GPIO_ENABLE_DEBOUNCE(P5, BIT2);
/* Unlock protected registers before setting Brown-out detector function and Power-down mode */
    SYS_UnlockReg();
    PowerDownFunction();
    /* Waiting for interrupts */
    while (1);
magic2004301 发表于 2017-8-27 14:47 | 显示全部楼层
请问大神,CPU时钟是HIRC,能否进入断电模式?我直接调用CLK_PowerDown函数后发现程序还在运行..........
magic2004301 发表于 2017-8-27 14:51 | 显示全部楼层
#include
#include "GPIO.h"
mintspring 发表于 2017-8-27 16:11 | 显示全部楼层
  1. /**************************************************************************//**
  2. * [url=home.php?mod=space&uid=288409]@file[/url]     main.c
  3. * [url=home.php?mod=space&uid=895143]@version[/url]  V2.10
  4. * $Date: 15/10/12 8:06p $
  5. * [url=home.php?mod=space&uid=247401]@brief[/url]    Show how to wake up system from Power-down mode by GPIO interrupt.
  6. *
  7. * @note
  8. * Copyright (C) 2012 Nuvoton Technology Corp. All rights reserved.
  9. *
  10. ******************************************************************************/
  11. #include <stdio.h>
  12. #include "mini51series.h"
  13. #include "GPIO.h"
  14. /**
  15. * @brief       Port0/Port1 IRQ
  16. *
  17. * @param       None
  18. *
  19. * [url=home.php?mod=space&uid=266161]@return[/url]      None
  20. *
  21. * [url=home.php?mod=space&uid=1543424]@Details[/url]     The Port0/Port1 default IRQ, declared in startup_Mini51.s.
  22. */
  23. void GPIO01_IRQHandler(void)
  24. {
  25.     /* To check if P1.5 interrupt occurred */
  26.     if (P1->ISRC & BIT5) {
  27.         P1->ISRC = BIT5;
  28.         printf("P1.5 INT occurred. \n");
  29.     } else {
  30.         /* Un-expected interrupt. Just clear all PORT0, PORT1 interrupts */
  31.         P0->ISRC = P0->ISRC;
  32.         P1->ISRC = P1->ISRC;
  33.         printf("Un-expected interrupts. \n");
  34.     }
  35. }
  36. void SYS_Init(void)
  37. {
  38.     /* Unlock protected registers */
  39.     SYS_UnlockReg();
  40.     /*---------------------------------------------------------------------------------------------------------*/
  41.     /* Init System Clock        */
  42.     /*---------------------------------------------------------------------------------------------------------*/
  43.     /* Set P5.0 and P5.1 -> XTAL  */
  44.     SYS->P5_MFP &= ~(SYS_MFP_P50_Msk | SYS_MFP_P51_Msk);
  45.     SYS->P5_MFP |= (SYS_MFP_P50_XTAL1 | SYS_MFP_P51_XTAL2);
  46.     /* Enable external 12MHz XTAL, internal 22.1184MHz */
  47.     CLK->PWRCON |= CLK_PWRCON_XTL12M | CLK_PWRCON_IRC22M_EN_Msk;
  48.     /* Waiting for clock ready */
  49.     CLK_WaitClockReady(CLK_CLKSTATUS_XTL_STB_Msk | CLK_CLKSTATUS_IRC22M_STB_Msk);
  50.     /* Switch HCLK clock source to XTL */
  51.     CLK_SetHCLK(CLK_CLKSEL0_HCLK_S_XTAL,CLK_CLKDIV_HCLK(1));
  52.     /* STCLK to XTL STCLK to XTL */
  53.     CLK_SetSysTickClockSrc(CLK_CLKSEL0_STCLK_S_XTAL);
  54.     /* Enable IP clock */
  55.     CLK_EnableModuleClock(UART_MODULE);
  56.     /* Select IP clock source */
  57.     CLK_SetModuleClock(UART_MODULE,CLK_CLKSEL1_UART_S_XTAL,CLK_CLKDIV_UART(1));
  58.     /*---------------------------------------------------------------------------------------------------------*/
  59.     /* Init I/O Multi-function        */
  60.     /*---------------------------------------------------------------------------------------------------------*/
  61.     /* Set P0 multi-function pins for UART RXD and TXD */
  62.     SYS->P0_MFP &= ~(SYS_MFP_P01_Msk | SYS_MFP_P00_Msk);
  63.     SYS->P0_MFP |= (SYS_MFP_P01_RXD | SYS_MFP_P00_TXD);
  64.     /* Set P3 multi-function pins for Clock Output */
  65.     SYS->P3_MFP = SYS_MFP_P36_CKO;
  66.     /* To update the variable SystemCoreClock */
  67.     SystemCoreClockUpdate();
  68.     /* Lock protected registers */
  69.     SYS_LockReg();
  70. }
  71. void UART_Init(void)
  72. {
  73.     /*---------------------------------------------------------------------------------------------------------*/
  74.     /* Init UART        */
  75.     /*---------------------------------------------------------------------------------------------------------*/
  76.     /* Reset IP */
  77.     SYS_ResetModule(SYS_IPRSTC2_UART_RST_Msk);
  78.     /* Configure UART and set UART Baudrate */
  79.     UART_Open(UART, 115200);
  80. }
  81. /*---------------------------------------------------------------------------------------------------------*/
  82. /* MAIN function        */
  83. /*---------------------------------------------------------------------------------------------------------*/
  84. int main (void)
  85. {
  86.     /* Init System, IP clock and multi-function I/O */
  87.     SYS_Init(); //In the end of SYS_Init() will issue SYS_LockReg() to lock protected register. If user want to write protected register, please issue SYS_UnlockReg() to unlock protected register.
  88.     /* Init UART for printf */
  89.     UART_Init();
  90.     printf("\n\nCPU [url=home.php?mod=space&uid=72445]@[/url] %dHz\n", SystemCoreClock);
  91.     printf("+--------------------------------------+ \n");
  92.     printf("|    MINI51 GPIO Wake-up Sample Code   | \n");
  93.     printf("+--------------------------------------+ \n");
  94.     /* Configure P1.5 as Input mode and enable interrupt by rising edge trigger */
  95.     GPIO_SetMode(P1, BIT5, GPIO_PMD_INPUT);
  96.     GPIO_EnableInt(P1, 5, GPIO_INT_RISING);
  97.     NVIC_EnableIRQ(GPIO01_IRQn);
  98.     /* Waiting for interrupts */
  99.     while (1) {
  100.         printf("Enter to Power-Down ......\n");
  101.         while(!UART_IS_TX_EMPTY(UART0));
  102.         CLK_PowerDown();
  103.         printf("System waken-up done.\n\n");
  104.     }
  105. }
去下载官方的BSP,里面有这个例子。还有非常多,你不要自己摸索了,慢,参考参考,快。
天灵灵地灵灵 发表于 2017-8-27 16:26 | 显示全部楼层
看来这个是时钟很关键啊。
