[ZLG-ARM] 菜农改造嵌入LPC213xcfg.h的RTX例程
8709|15
 楼主| hotpower 发表于 2010-8-1 16:38 | 显示全部楼层 |阅读模式
压缩包内包括:
LPC213xcfg.h 最新版(LPC2103DEF.H的全面升级版)
RTX_Config.c (RL-ARM V4.12) 菜农改造并嵌入LPC213xcfg.h的操作系统内核。
LPC2103DEF.H 菜农5年前的头文件,和NXP最新的头文件为同级别水平。
菜农近期将对LPC213xcfg.h大规模升级,达到LPC11xxcfg.h的水平。
使菜农的红杏系列继续领先NXP的头文件。
本例程压缩包Traffic:
参见:菜鸟需努力,红杏要出墙
下载 (84.01 KB)
2010-7-4 20:59
C5402CFG.H(父亲节版)
新版c5402cfg.h应用范例及升级说明
DSP54X系列上超级暴力武器艳照
 楼主| hotpower 发表于 2010-8-1 16:41 | 显示全部楼层
RTX_CONFIG.C
*      RL-ARM - RTX
*      Name:    RTX_CONFIG.C
*      Purpose: Configuration of RTX Kernel for NXP LPC21xx
*      Rev.:    V4.12
*      This code is part of the RealView Run-Time Library.
*      Copyright (c) 2004-2010 KEIL - An ARM Company. All rights reserved.
#include <RTL.h>
#include <LPC213xcfg.h>                     /* LPC21xx definitions              */
*      RTX User configuration part BEGIN
//-------- <<< Use Configuration Wizard in Context Menu >>> -----------------
// <h>Task Configuration
//   <o>Number of concurrent running tasks <0-250>
//   <i> Define max. number of tasks that will run at the same time.
//   <i> Default: 6
#ifndef OS_TASKCNT
#define OS_TASKCNT     6
#endif
//   <o>Number of tasks with user-provided stack <0-250>
//   <i> Define the number of tasks that will use a bigger stack.
//   <i> The memory space for the stack is provided by the user.
//   <i> Default: 0
#ifndef OS_PRIVCNT
#define OS_PRIVCNT     1
#endif
//   <o>Task stack size [bytes] <20-4096:8><#/4>
//   <i> Set the stack size for tasks which is assigned by the system.
//   <i> Default: 200
#ifndef OS_STKSIZE
#define OS_STKSIZE     50
#endif
// <q>Check for the stack overflow
// <i> Include the stack checking code for a stack overflow.
// <i> Note that additional code reduces the RTX performance.
#ifndef OS_STKCHECK
#define OS_STKCHECK    1
#endif
// </h>
// <h>Tick Timer Configuration
//   <o>Hardware timer <0=> Timer 0 <1=> Timer 1
//   <i> Define the on-chip timer used as a time-base for RTX.
//   <i> Default: Timer 0
#ifndef OS_TIMER
#define OS_TIMER       1
#endif
//   <o>Timer clock value [Hz] <1-1000000000>
//   <i> Set the timer clock value for selected timer.
//   <i> Default: 15000000  (15MHz at 60MHz CCLK and VPBDIV = 4)
#ifndef OS_CLOCK
#define OS_CLOCK       12000000
#endif
//   <o>Timer tick value [us] <1-1000000>
//   <i> Set the timer tick value for selected timer.
//   <i> Default: 10000  (10ms)
#ifndef OS_TICK
#define OS_TICK        10000
#endif
// </h>
// <h>System Configuration
// <e>Round-Robin Task switching
// <i> Enable Round-Robin Task switching.
#ifndef OS_ROBIN
#define OS_ROBIN       1
#endif
//   <o>Round-Robin Timeout [ticks] <1-1000>
//   <i> Define how long a task will execute before a task switch.
//   <i> Default: 5
#ifndef OS_ROBINTOUT
#define OS_ROBINTOUT   5
#endif
// </e>
//   <o>Number of user timers <0-250>
//   <i> Define max. number of user timers that will run at the same time.
//   <i> Default: 0  (User timers disabled)
#ifndef OS_TIMERCNT
#define OS_TIMERCNT    0
#endif
//   <o>ISR FIFO Queue size<4=>   4 entries  <8=>   8 entries
//                         <12=> 12 entries  <16=> 16 entries
//                         <24=> 24 entries  <32=> 32 entries
//                         <48=> 48 entries  <64=> 64 entries
//                         <96=> 96 entries
//   <i> ISR functions store requests to this buffer,
//   <i> when they are called from the IRQ handler.
//   <i> Default: 16 entries
#ifndef OS_FIFOSZ
#define OS_FIFOSZ      16
#endif
// </h>
//------------- <<< end of configuration section >>> -----------------------
// Standard library system mutexes
//  Define max. number system mutexes that are used to protect
//  the arm standard runtime library. For microlib they are not used.
#ifndef OS_MUTEXCNT
#define OS_MUTEXCNT    8
#endif
*      RTX User configuration part END
#if   (OS_TIMER == 0)                                   /* Timer 0          */
#define OS_TID_        4                               /*  Timer ID        */
#elif (OS_TIMER == 1)                                   /* Timer 1          */
#define OS_TID_        5                               /*  Timer ID        */
#else
#error OS_TIMER invalid
#endif
#define OS_TVAL         T0.TIMER_TC                        /*  Timer Value     */
#define OS_TVAL         T1.TIMER_TC                        /*  Timer Value     */
#endif
#define OS_TOVF         T0.TIMER_IR & 1                  /*  Overflow Flag   */
#define OS_TOVF         T1.TIMER_IR & 1                  /*  Overflow Flag   */
#endif
#define OS_TIACK()      T0.TIMER_IR = 1;                   /*  Interrupt Ack   */ \
                         VIC.SoftIntClr = OS_TIM_;                               \
                         VIC.VectAddr   = 0;
#define OS_TIACK()      T1.TIMER_IR = 1;                   /*  Interrupt Ack   */ \
                         VIC.VectAddr   = 0;
#endif
                         VIC.VectAddr   = 0;
                         VIC.VectAddr   = 0;
#endif
                         VIC.VectAddr   = 0;
                         VIC.VectAddr   = 0;
#endif
                         VIC.VectAddr   = 0;
                         VIC.VectAddr   = 0;
#endif
#define OS_TINIT()      T0.TIMER_MR0 = OS_TRV;             /*  Initialization  */ \
                         T0.TIMER_MCR = 3;                                         \
                         T0.TIMER_TCR = 1;                                         \
                         VIC.DefVectAddr = (U32)os_def_interrupt;                \
                         VIC.VectAddrs[15]  = (U32)os_clock_interrupt;              \
                         VIC.VectCntls[15]  = 0x20 | OS_TID_;
#define OS_TINIT()      T1.TIMER_MR0 = OS_TRV;             /*  Initialization  */ \
                         T1.TIMER_MCR = 3;                                         \
                         T1.TIMER_TCR = 1;                                         \
#endif
#define OS_TIM_         (1 << OS_TID_)                  /*  Interrupt Mask  */
#define OS_TRV          ((U32)(((double)OS_CLOCK*(double)OS_TICK)/1E6)-1)
#define OS_TFIRQ()      VIC.SoftInt    = OS_TIM_;        /*  Force Interrupt */
#define OS_IACK()       VIC.VectAddr   = 0;              /* Interrupt Ack    */
#define OS_LOCK()       VIC.IntEnClr   = OS_TIM_;        /* Task Lock        */
#define OS_UNLOCK()     VIC.IntEnable  = OS_TIM_;        /* Task Unlock      */
/* WARNING: Using IDLE mode might cause you troubles while debugging. */
#define _idle_()        POWER.P_CON = 1;
*      Global Functions
/*--------------------------- os_idle_demon ---------------------------------*/
__task void os_idle_demon (void) {
  /* The idle demon is a system task, running when no other task is ready */
  /* to run. The 'os_xxx' function calls are not allowed from this task.  */
  for (;;) {
  /* HERE: include optional user code to be executed when no task runs.*/
/*--------------------------- os_tmr_call -----------------------------------*/
void os_tmr_call (U16 info) {
  /* This function is called when the user timer has expired. Parameter  */
  /* 'info' holds the value, defined when the timer was created.         */
  /* HERE: include optional user code to be executed on timeout. */
/*--------------------------- os_error --------------------------------------*/
void os_error (U32 err_code) {
  /* This function is called when a runtime error is detected. Parameter */
  /* 'err_code' holds the runtime error code (defined in RTL.H).         */
  /* HERE: include optional code to be executed on runtime error. */
  for (;;);
*      RTX Configuration Functions
static void os_def_interrupt (void) __irq  {
  /* Default Interrupt Function: may be called when timer ISR is disabled */
  OS_IACK();
#include <RTX_lib.c>
* end of file
LPC213Xcfg.h
文   件   名 :  LPC213Xcfg.h
创   建   人 :  ARM水鸟  HotPower@126.com
创 建 日  期 :  2005.7.23  0:38
最近修改日期 :  2010.7.4   1:18
创 建  地 点 : 西安大雁塔村队部
版   本   号 : V1.00 (世界杯版)
说        明 : 本头文件的前身为LPC213Xdef.h
                经过5年的证明非常稳定
修 改  原 因 : 全面替代LPC213x.h和LPC213Xdef.h
                解决LPC213Xdef.h指针变量占用空间的极大缺点
    在Keil ARM中彻底解决了变量定位问题。
    支持位操作,全面实现用结构符“.”与大众软件接轨
备        注 :
应 用  简 介:
SystemObj::SystemObj(void)
volatile unsigned int start;
  Disable_IRQ();//关中断
  PINSEL.PIN_SEL0.Regs = 0x00000000;  // 设置管脚连接GPIO
  PINSEL.PIN_SEL1.Regs = 0x00000000;  // 设置管脚连接GPIO
  PINSEL.PIN_SEL2.Regs = 0x00000000;  // 设置管脚连接GPIO
  PINSEL.PIN_SEL0.Regs |= (P0_15_EINT2 << P0_15_PINSEL);// P0.15连接到EINT2
  P0.IODIR.Regs  = 0x00000000;  // 设置P0口为输入
  P1.IODIR.Regs  = 0x00000000;  // 设置P1口为输入
  VIC.IntEnable.Regs = 0;
  VIC.SoftIntClr.Regs = 0xffffffff;//清除所有软中断标志
  VIC.IntSelect.Regs   = 0;//全部中断为IRQ中断或默认中断
  for(int i = 0; i <= 15; i ++) {
    VIC.VectAddrs.Regs = i;//刷新向量地址寄存器VICVectAddr0~VICVectAddr15
  for (start = 1; start < 10000; start ++);
  SystemInit();
  Enable_IRQ();//开中断
倒塌应用简介:
  P0.IOSET.Bits.Pin13 = 1;//P0.13=1
  P0.IOCLR.Bits.Pin13 = 1;//P0.13=0
  P0.IOPIN.Bits.Pin13 = 1;//P0.13=1
  if (P0.IOPIN.Bits.Pin13) P0.IOPIN.Bits.Pin12 = 1;
  if (!P0.IOPIN.Bits.Pin18) P0.IOPIN.Bits.Pin22 = 1;
  P0.IODIR.Bits.Pin1 = true;
  P0.IOCLR.Bits.Pin4 = false;
  P0.IOSET.Bits.Pin3 = 1;
#ifndef __LPC213xDEF_H
#define __LPC213xDEF_H
typedef volatile unsigned long LPC_REG;// Hardware register definition
#define __noinit__ __attribute__((zero_init))//变量不初始化为0
typedef unsigned char  uint8; //无符号8位整型变量
typedef signed   char  int8;  //有符号8位整型变量
typedef unsigned short uint16;//无符号16位整型变量
typedef signed   short int16; //有符号16位整型变量
typedef unsigned int   uint32;//无符号32位整型变量
typedef signed   int   int32; //有符号32位整型变量
typedef float          fp32;  //单精度浮点数(32位长度
typedef double         fp64;  //双精度浮点数(64位长度)
应用示例(屏蔽郁闷的警告)
  P0->IODIR |= (__1 << P0_31);//设置P0.31为输出
  P0->IOSET  = (__1 << P0_31);//P0.31输出高电平
  P0->IOCLR  = (__1 << P0_31);//P0.31输出低电平
  P0->IOPIN ^= (__1 << P0_31);//P0.31输出电平翻转
或(屏蔽郁闷的警告)
  P0->IODIR |= (__1 << 31);//设置P0.31为输出
  P0->IOSET  = (__1 << 31);//P0.31输出高电平
  P0->IOCLR  = (__1 << 31);//P0.31输出低电平
  P0->IOPIN ^= (__1 << 31);//P0.31输出电平翻转
#define __0                  (LPC_REG)0
#define __1                  (LPC_REG)1
#define __2                  (LPC_REG)2
#define __3                  (LPC_REG)3
#define __4                  (LPC_REG)4
#define __5                  (LPC_REG)5
#define __6                  (LPC_REG)6
#define __7                  (LPC_REG)7
#define __8                  (LPC_REG)8
#define __9                  (LPC_REG)9
#define __10                 (LPC_REG)10
#define __11                 (LPC_REG)11
#define __12                 (LPC_REG)12
#define __13                 (LPC_REG)13
#define __14                 (LPC_REG)14
#define __15                 (LPC_REG)15
#define __16                 (LPC_REG)16
#define __17                 (LPC_REG)17
#define __18                 (LPC_REG)18
#define __19                 (LPC_REG)19
#define __20                 (LPC_REG)20
#define __21                 (LPC_REG)21
#define __22                 (LPC_REG)22
#define __23                 (LPC_REG)23
#define __24                 (LPC_REG)24
#define __25                 (LPC_REG)25
#define __26                 (LPC_REG)26
#define __27                 (LPC_REG)27
#define __28                 (LPC_REG)28
#define __29                 (LPC_REG)29
#define __30                 (LPC_REG)30
#define __31                 (LPC_REG)31
#define VICIntSel_Watchdog   0//看门狗中断(WDINT)
#define VICIntSel_SoftInt1   1//保留给软件中断
#define VICIntSel_DbgCommRx  2//ARM内核中断
#define VICIntSel_DbgCommTx  3//ARM内核中断
#define VICIntSel_Time0      4//定时器0中断
#define VICIntSel_Time1      5//定时器1中断
#define VICIntSel_UART0      6//UART0中断
#define VICIntSel_UART1      7//UART1中断
#define VICIntSel_PWM0       8//PWM0中断
#define VICIntSel_I2C0       9//I2C0中断
#define VICIntSel_SPI0      10//SPI0中断
#define VICIntSel_SSP       11//SSP中断
#define VICIntSel_SPI1      11//SPI1中断
#define VICIntSel_PLL       12//PLL中断
#define VICIntSel_RTC       13//RTC中断
#define VICIntSel_EINT0     14//系统控制外部中断0
#define VICIntSel_EINT1     15//系统控制外部中断1
#define VICIntSel_EINT2     16//系统控制外部中断2
#define VICIntSel_EINT3     17//系统控制外部中断3
#define VICIntSel_ADC0      18//A/D转换器0中断
#define VICIntSel_I2C1      19//I2C1中断
#define VICIntSel_BOD       20//掉电检测中断
#define VICIntSel_ADC1      21//A/D转换器1中断
#define VICIntSel_SoftInt22 22//保留给软件中断
#define VICIntSel_SoftInt23 23//保留给软件中断
#define VICIntSel_SoftInt24 24//保留给软件中断
#define VICIntSel_SoftInt25 25//保留给软件中断
#define VICIntSel_SoftInt26 26//保留给软件中断
#define VICIntSel_SoftInt27 27//保留给软件中断
#define VICIntSel_SoftInt28 28//保留给软件中断
#define VICIntSel_SoftInt29 29//保留给软件中断
#define VICIntSel_SoftInt30 30//保留给软件中断
#define VICIntSel_SoftInt31 31//保留给软件中断
#define VICIntSel_Enable    32//使能向量中断
应用示例
  VIC->VectCntls[0]   = VICIntSel_Enable//使能IRQ中断
                      | VICIntSel_EINT0;//获取EINT0的IRQ级别
  VIC->VectAddrs[0]   = (long) IRQ_Eint0;//取INT0中断服务地址
  VIC->IntEnable      = (1 << VICIntSel_EINT0); //使能EINT0中断
  VIC->IntEnClr       = (1 << VICIntSel_EINT0); //禁止EINT0中断
                 P0口链接配置位定义
#define P0_0   0//P0.0
  #define TXD0    P0_0//UART0的发送器输出
  #define PWM1    P0_0//脉宽调制器输出1
#define P0_1   1//P0.1
  #define RXD0    P0_1//UART0的接收器输入
  #define PWM3    P0_1//脉宽调制器输出3
#define P0_2   2//P0.2
  #define SCL0    P0_2//I2C0时钟输入/输出。开漏输出(符合I2C规范)
#define P0_3   3//P0.3
  #define SDA0    P0_3//I2C0数据输入/输出。开漏输出(符合I2C规范)
#define P0_4   4//P0.4
  #define SCK0    P0_4//SPI0的串行时钟。SPI时钟从主机输出,从机输入
  #define AD0_6   P0_4//A/D转换器0输入6。该模拟输入总是连接到相应的管脚
#define P0_5   5//P0.5
  #define MISO0   P0_5//SPI0主机输入从机输出端。从机到主机的数据传输
  #define AD0_7   P0_5//A/D转换器0输入7。该模拟输入总是连接到相应的管脚
#define P0_6   6//P0.6
  #define MOSI0   P0_6//SPI0主机输出从机输入端。主机到从机的数据传输
  #define AD1_0   P0_6//A/D转换器1输入0。该模拟输入总是连接到相应的管脚(仅用于 LPC2138)
#define P0_7   7//P0.7
  #define SSEL0   P0_7//SPI0从机选择。选择SPI接口用作从机
  #define PWM2    P0_7//脉宽调制器输出2
#define P0_8   8//P0.8
  #define TXD1    P0_8//UART1的发送器输出
  #define PWM4    P0_8//脉宽调制器输出4
  #define AD1_1   P0_8//A/D转换器1输入1。该模拟输入总是连接到相应的管脚(仅用于 LPC2138)
#define P0_9   9//P0.9
  #define RXD1    P0_9//UART1的接收器输入
  #define PWM6    P0_9//脉宽调制器输出6
#define P0_10 10//P0.10
  #define RTS1    P0_10//UART1请求发送出端(仅用于LP138)
  #define CAP1_0  P0_10//定时器1的捕获输入通道0
  #define AD1_2   P0_10//A/D转换器1输入2。该模拟输入总是连接到相应的管脚(仅用于 LPC2138)
#define P0_11 11//P0.11
  #define CTS1    P0_11//UART1清除发送入端(仅用于LP138)
  #define CAP1_1  P0_11//定时器1的捕获输入通道1
  #define SCL1    P0_11//I2C1时钟输入/输。开漏输出(符合I2C规范)
#define P0_12 12//P0.12
  #define DSR1    P0_12//UART1数据设置就绪端(仅用于 LPC2138)
  #define MAT1_0  P0_12//定时器1的匹配输出通道0
  #define AD1_3   P0_12//A/D转换器1输入3。该模拟输入总是连接到相应的管脚(仅用于 LPC2138)
#define P0_13 13//P0.13
  #define DTR1    P0_13//UART1数据终端就绪
  #define MAT1_1  P0_13//定时器1的匹配输出通道1
  #define AD1_4   P0_13//A/D转换器1输入4。该模拟输入总是连接到相应的管脚(仅用于 LPC2138)
#define P0_14 14//P0.14
  #define DCD1    P0_14//UART1数据载波检测输入(仅用于 LPC2138)
  #define SDA1    P0_14//I2C1数据输入/输出。开漏输出(符合I2C规范)
#define P0_15 15//P0.15
  #define RI1     P0_15//UART1铃响指示输入(仅用于 LPC2138)
  #define AD1_5   P0_15//A/D转换器1输入5。该模拟输入总是连接到相应的管脚(仅用于 LPC2138)
#define P0_16 16//P0.16
#define P0_17 17//P0.17
  #define SCK1    P0_17//SPI1的串行时钟。SPI时钟从主机输出,从机输入
#define P0_18 18//P0.18
  #define MISO1   P0_18//SPI1主机输入从机输出端。从机到主机的数据传输
#define P0_19 19//P0.19
  #define MOSI1   P0_19//SPI1主机输出从机输入端。主机到从机的数据传输
#define P0_20 20//P0.20
  #define SSEL1   P0_20//SPI1从机选择。选择SPI接口用作从机
#define P0_21 21//P0.21
  #define PWM5    P0_21//脉宽调制器输出5
  #define AD1_6   P0_21//A/D转换器1输入6。该模拟输入总是连接到相应的管脚(仅用于 LPC2138)
#define P0_22 22//P0.22
  #define AD1_7   P0_22//A/D转换器1输入7。该模拟输入总是连接到相应的管脚(仅用于 LPC2138)
#define P0_23 23//P0.23
#define P0_24 24//P0.24
#define P0_25 25//P0.25
  #define AD0_4   P0_25//A/D转换器0输入4。该模拟输入总是连接到相应的管脚.D/A 转换器输出(仅用于 LPC2138)
#define P0_26 26//P0.26
  #define AD0_5   P0_26//A/D转换器0输入5。该模拟输入总是连接到相应的管脚
#define P0_27 27//P0.27
  #define AD0_0   P0_27//A/D转换器0输入0。该模拟输入总是连接到相应的管脚
#define P0_28 28//P0.28
  #define AD0_1   P0_28//A/D转换器0输入1。该模拟输入总是连接到相应的管脚
#define P0_29 29//P0.29
  #define AD0_2   P0_29//A/D转换器0输入2。该模拟输入总是连接到相应的管脚
  #define CAP0_3  P0_29//定时器0的捕获输入通道3
  #define MAT0_3  P0_29//定时器0的匹配输出通道3
#define P0_30 30//P0.30
  #define AD0_3   P0_30//A/D转换器0输入3。该模拟输入总是连接到相应的管脚
#define P0_31 31//P0.31
        P1口GPIO位寻址位定义
#define P1_0   0//P1.0
#define P1_1   1//P1.1
#define P1_2   2//P1.2
#define P1_3   3//P1.3
#define P1_4   4//P1.4
#define P1_5   5//P1.5
#define P1_6   6//P1.6
#define P1_7   7//P1.7
#define P1_8   8//P1.8
#define P1_9   9//P1.9
#define P1_10 10//P1.10
#define P1_11 11//P1.11
#define P1_12 12//P1.12
#define P1_13 13//P1.13
#define P1_14 14//P1.14
#define P1_15 15//P1.15
#define P1_16 16//P1.16
#define P1_17 17//P1.17
#define P1_18 18//P1.18
#define P1_19 19//P1.19
#define P1_20 20//P1.20
#define P1_21 21//P1.21
#define P1_22 22//P1.22
#define P1_23 23//P1.23
#define P1_24 24//P1.24
#define P1_25 25//P1.25
#define P1_26 26//P1.26
#define P1_27 27//P1.27
#define P1_28 28//P1.28
#define P1_29 29//P1.29
#define P1_30 30//P1.30
#define P1_31 31//P1.31
        RTC中断位置寄存器ILR位定义
#define RTCCIF   0//为1时,计数器增量中断模块产生中断。向该位写入1清除计数器增量中断。
#define RTCALF   1//为1时,报警寄存器产生中断。向该位写入1清除报警中断。
        RTC时钟控制寄存器CCR位定义
#define CLKEN    0//时钟使能当该位为1 时,时间计数器使能。
#define CTCRST   1//CTC 复位为1 时,时钟节拍计数器复位。
#define CLKSRC   4//如果该位为1,CTC 计数连接在RTCX1 和RTCX2 两端的32kHz振荡器信号。
        RTC计数器增量中断寄存器CIIR位定义
#define IMSEC    0//为1时,秒值的增加产生一次中断。
#define IMMIN    1//为1时,分值的增加产生一次中断。
#define IMHOUR   2//为1时,小时值的增加产生一次中断。
#define IMDOM    3//为1时,日期(月)值的增加产生一次中断。
#define IMDOW    4//为1时,星期值的增加产生一次中断。
#define IMDOY    5//为1时,日期(年)值的增加产生一次中断。
#define IMMON    6//为1时,月值的增加产生一次中断。
#define IMYEAR   7//为1时,年值的增加产生一次中断。
        RTC报警屏蔽寄存器位AMR位定义
#define AMRSEC   0//为1 时,秒值不与报警寄存器比较。
#define AMRMIN   1//为1 时,分值不与报警寄存器比较。
#define AMRHOUR  2//为1 时,小时值不与报警寄存器比较。
#define AMRDOM   3//为1 时,日期(月)值不与报警寄存器比较。
#define AMRDOW   4//为1 时,星期值不与报警寄存器比较。
#define AMRDOY   5//为1 时,日期(年)值不与报警寄存器比较。
#define AMRMON   6//为1 时,月值不与报警寄存器比较。
#define AMRYEAR  7//为1 时,年值不与报警寄存器比较。
        TX中断寄存器TXIR位定义
#define MR0      0//匹配通道0中断标志
#define MR1      1//匹配通道1中断标志
#define MR2      2//匹配通道2中断标志
#define MR3      3//匹配通道3中断标志
#define CR0      4//捕获通道0事件中断标志
#define CR1      5//捕获通道0事件中断标志
#define CR2      6//捕获通道0事件中断标志
#define CR3      7//捕获通道0事件中断标志
        UARTX标识中断寄存器UXIIR
#define IIR0     0//中断挂起 0:至少有1个中断被挂起(挂起的中断可通过UXIER3:1确定)
#define IIR1     1//中断标识1
#define IIR2     2//中断标识2
#define IIR3     3//中断标识3
        UARTX线状态寄存器UXLSR
#define RDR      0//接收数据就绪
#define OE   1//溢出错误
#define PE   2//奇偶错误
#define FE   3//帧错误
#define BI   4//间隔中断
#define THRE     5//发送保持寄存器空
#define TEMT     6//发送器空
#define RXFE     7//Rx FIFO错误
        I2C控制置位寄存器I2CONSET位定义
#define AA       2//应答标志。
#define SI       3//I2C中断标志。
#define STO      4//停止标志。
#define STA      5//起始标志。
#define I2EN     6//I2C接口使能。
        I2C控制清零寄存器I2CONCLR位定义
#define AAC      2//应答标志。
#define SIC      3//I2C中断标志。
#define STAC     5//起始标志。
#define I2ENC    6//I2C接口使能。
        I2C运行状态代码定义
#define I2C_START            0x08 //已发送起始条件
#define I2C_REP_START        0x10 //已发送重复起始条件
/* Master Transmitter */      //主发送器模式
#define I2C_MT_SLA_ACK        0x18 //已发送SLA+W,且已接收ACK
#define I2C_MT_SLA_NACK        0x20 //已发送SLA+W,且未接收ACK
#define I2C_MT_DATA_ACK        0x28 //已发送I2DAT 中的数据字节,且已接收ACK
#define I2C_MT_DATA_NACK       0x30 //已发送I2DAT 中的数据字节,且未接收ACK
#define I2C_MT_ARB_LOST        0x38
/* Master Receiver */       //主接收器模式
#define I2C_MR_ARB_LOST        0x38
#define I2C_MR_SLA_ACK        0x40 //已发送SLA+R,且已接收ACK
#define I2C_MR_SLA_NACK        0x48 //已发送SLA+R,且未接收ACK
#define I2C_MR_DATA_ACK        0x50
#define I2C_MR_DATA_NACK       0x58
/* Slave Transmitter */
#define I2C_ST_SLA_ACK         0xA8
#define I2C_ST_ARB_LOST_SLA_ACK   0xB0
#define I2C_ST_DATA_ACK        0xB8
#define I2C_ST_DATA_NACK       0xC0
#define I2C_ST_LAST_DATA       0xC8
/* Slave Receiver */
#define I2C_SR_SLA_ACK        0x60
#define I2C_SR_ARB_LOST_SLA_ACK   0x68
#define I2C_SR_GCALL_ACK      0x70
#define I2C_SR_ARB_LOST_GCALL_ACK 0x78
#define I2C_SR_DATA_ACK        0x80
#define I2C_SR_DATA_NACK    0x88
#define I2C_SR_GCALL_DATA_ACK   0x90
#define I2C_SR_GCALL_DATA_NACK   0x98
#define I2C_SR_STOP            0xA0
/* Misc */
#define I2C_NO_INFO            0xF8
#define I2C_BUS_ERROR        0x00
        PWMMCR位定义
#define PWMMCRI0 0
#define PWMMCRR0 1
#define PWMMCRS0 2
#define PWMMCRI1 3
#define PWMMCRR1 4
#define PWMMCRS1 5
#define PWMMCRI2 6
#define PWMMCRR2 7
#define PWMMCRS2 8
#define PWMMCRI3 9
#define PWMMCRR3 10
#define PWMMCRS3 11
#define PWMMCRI4 12
#define PWMMCRR4 13
#define PWMMCRS4 14
#define PWMMCRI5 15
#define PWMMCRR5 16
#define PWMMCRS5 17
#define PWMMCRI6 18
#define PWMMCRR6 19
#define PWMMCRS6 20
        PWMPCR位定义
#define PWMSEL1 1
#define PWMSEL2 2
#define PWMSEL3 3
#define PWMSEL4 4
#define PWMSEL5 5
#define PWMSEL6 6
#define PWMENA1 9
#define PWMENA2 10
#define PWMENA3 11
#define PWMENA4 12
#define PWMENA5 13
#define PWMENA6 14
        PWMLER位定义
#define PWMLER0 0
#define PWMLER1 1
#define PWMLER2 2
#define PWMLER3 3
#define PWMLER4 4
#define PWMLER5 5
#define PWMLER6 6
        ADCR位定义
#define BURST   16
#define PDN     21
#define START   24//26:24=000
#define EDGE    27
        A/D 数据寄存器ADDR位定义
#define OVERUN      30
#define DONE        31//A/D转换结束时该位置位。该位在ADDR被读出和ADCR被写入时清零。
        复位源识别寄存器RSID位定义
#define POR          0//RSID.0//POR信号有效时该位置位,并清除RSID寄存器的其它位
#define EXTR         1//RSID.1//RESET信号有效时该位置位
#define WDTR         2//RSID.2//当看门狗定时器溢出和看门狗方式寄存器的WDTRESET位为1时,该位置位。
                              //该位可被其它任何一个复位源清除。
#define BODR         3//RSID.3//当3.3V的电源降到低于2.6V时该位置位
        SSP状态寄存器SSPSR位定义
#define TFE          0//发送FIFO 空。发送FIFO 为空时该位为1,反之为0。
#define TNF          1//发送FIFO 未满。Tx FIFO 满时该位为0,反之为1。
#define RNE          2//接收FIFO 不为空。接收FIFO 为空时该位为0,反之为1。
#define RFF          3//接收FIFO 满。接收FIFO 满时该位为1,反之为0。
#define BSY          4//忙。SSP 控制器空闲、
        S0SPCR位定义
#define CPHA         3//时钟相位控制
#define CPOL         4//时钟极性控制
#define MSTR         5//主模式选择。为1时,SPI处于主模式。为0时,SPI处于从模式。
#define LSBF         6//传输的每个字节的移动方向.为0 时,SPI数据传输MSB(位7)在先
#define SPIE         7//中断使能。为1时,每次SPIF或MODF置位时都会产生硬件中断
        SPI 状态寄存器S0SPSR位定义
#define ABRT        3//从机中止。该位为1 时表示发生了从机中止。当读取该寄存器时,该位清零
#define MODF        4//模式错误。为1 时表示发生了模式错误。
#define ROVR        5//读溢出。为1 时表示发生了读溢出。当读取该寄存器时,该位清零。
#define WCOL        6//写冲突。为1 时表示发生了写冲突
#define SPIF        7//SPI 传输完成标志。为1 时表示一次SPI 数据传输完成。
        功率控制寄存器PCON位定义
#define IDL         0//空闲模式
#define PD          1//掉电模式
#define PDBOD       2//空闲模式
        外设功率控制寄存器PCONP位定义
#define PCTIM0      1//定时器0使能
#define PCTIM1      2//定时器1使能
#define PCURT0      3//UART0使能
#define PCURT1      4//UART1使能
#define PCPWM0      5//PWM0使能
#define PCI2C0      7//I2C0接口使能
#define PCSPI0      8//SPI接口使能
#define PCRTC       9//RTC使能
#define PCSPI1     10//SSP接口使能
#define PCAD0      12//A/D转换器0使能
#define PCI2C1     19//I2C1接口使能
#define PCAD1      20//A/D转换器1使能
        WDMOD位定义
#define WDEN        0//
#define WDRESET     1//
#define WDTOF       2//
#define WDINT       3//
        PLL 控制寄存器位定义
#define PLLEN       0//PLL 使能
#define PLLLK       1//PLL 连接
        PLL 状态寄存器位定义
#define PLLE        8//PLL 使能位
#define PLLC        9//PLL 连接位
#define PLOCK      10//PLL 锁定状态
        外部中断标志寄存器EXTINT位定义
#define EINT0  0//EXTINT.0//写'1'清除EINT0中断标志
#define EINT1  1//EXTINT.1//写'1'清除EINT1中断标志
#define EINT2  2//EXTINT.2//写'1'清除EINT2中断标志
#define EINT3  3//EXTINT.3//写'1'清除EINT3中断标志
        外部中断方式寄存器EXTMODE位定义
#define EXTMODE0 0//EXTMODE.0//该位为0时,EINT0使用电平激活;该位为1时,EINT0使用边沿激活。
#define EXTMODE1 1//EXTMODE.1//该位为0时,EINT1使用电平激活;该位为1时,EINT1使用边沿激活。
#define EXTMODE2 2//EXTMODE.2//该位为0时,EINT2使用电平激活;该位为1时,EINT2使用边沿激活。
#define EXTMODE3 3//EXTMODE.3//该位为0时,EINT3使用电平激活;该位为1时,EINT3使用边沿激活。
        外部中断极性寄存器EXTPOLAR位定义
#define EXTPOLAR0 0//EXTPOLAR.0//该位为0时,EINT0低电平或下降沿有效(由EXTMODE0决定)。
                   //该位为1时,EINT0高电平或上升沿有效(由EXTMODE0决定)。
#define EXTPOLAR1 1//EXTPOLAR.1//该位为0时,EINT1低电平或下降沿有效(由EXTMODE1决定)。
                   //该位为1时,EINT1高电平或上升沿有效(由EXTMODE1决定)。
#define EXTPOLAR2 2//EXTPOLAR.2//该位为0时,EINT2低电平或下降沿有效(由EXTMODE2决定)。
                   //该位为1时,EINT2高电平或上升沿有效(由EXTMODE2决定)。
#define EXTPOLAR3 3//EXTPOLAR.3//该位为0时,EINT3低电平或下降沿有效(由EXTMODE3决定)。
                   //该位为1时,EINT3高电平或上升沿有效(由EXTMODE3决定)。
        外部中断唤醒寄存器EXTWAKE位定义
#define EXTWAKE0  0//EXTWAKE.0//该位为1时,使能EINT0将处理器从掉电模式唤醒。
#define EXTWAKE1  1//EXTWAKE.1//该位为1时,使能EINT1将处理器从掉电模式唤醒。
#define EXTWAKE2  2//EXTWAKE.2//该位为1时,使能EINT2将处理器从掉电模式唤醒。
#define EXTWAKE3  3//EXTWAKE.3//该位为1时,使能EINT3将处理器从掉电模式唤醒。
#define BODWAKE  14//EXTWAKE.14//该位为1时,BOD中断产生时可将处理器从掉电模式唤醒。
#define RTCWAKE  15//EXTWAKE.15//该位为1时,RTC中断产生时可将处理器从掉电模式唤醒。
  GPIO管脚功能配置
应用示例:
  PINSEL->PIN_SEL0  |= (P0_0_TXD0 << P0_0_PINSEL) | (P0_1_RXD0 << P0_1_PINSEL);
                   //选择P0.0和P0.1为UART0的输出输入引脚
  PINSEL->PIN_SEL0  |= (P0_3_EINT1 << P0_3_PINSEL); //选择P0.3为INT1外部中断引脚
  PINSEL->PIN_SEL0  |= (P0_14_EINT1 << P0_14_PINSEL); //选择P0.14也可为INT1外部中断引脚
  PINSEL->PIN_SEL0  |= (P0_1_EINT0 << P0_1_PINSEL)   //选择P0.1为INT0外部中断引脚
  PINSEL->PIN_SEL1  |= (P0_16_EINT0 << P0_16_PINSEL); //选择P0.16也可为INT0外部中断引脚
#define P0_0_GPIO      __0//通用数字输入输出管脚
  #define P0_0_TXD0    __1//UART0的发送器输出
  #define P0_0_PWM1    __2//脉宽调制器输出1
#define P0_0_PINSEL    2 * P0_0
#define P0_1_GPIO      __0//通用数字输入输出管脚
  #define P0_1_RXD0    __1//UART0的接收器输入
  #define P0_1_PWM3    __2//脉宽调制器输出3
  #define P0_1_EINT0   __3//**外部中断0输入
#define P0_1_PINSEL    2 * P0_1
#define P0_2_GPIO      __0//通用数字输入输出管脚
  #define P0_2_SCL0    __1//I2C0时钟输入/输出。开漏输出(符合I2C规范)
  #define P0_2_CAP0_0  __2//***定时器0的捕获输入通道0
#define P0_2_PINSEL    2 * P0_2
#define P0_3_GPIO      __0//通用数字输入输出管脚
  #define P0_3_SDA0    __1//I2C0数据输入/输出。开漏输出(符合I2C规范)
  #define P0_3_MAT0_0  __2//**定时器0的匹配输出通道0
  #define P0_3_EINT1   __3//**外部中断1输入
#define P0_3_PINSEL    2 * P0_3
#define P0_4_GPIO      __0//通用数字输入输出管脚
  #define P0_4_SCK0    __1//SPI0的串行时钟。SPI时钟从主机输出,从机输入
  #define P0_4_CAP0_1  __2//**定时器0的捕获输入通道1
  #define P0_4_AD0_6   __3//A/D转换器0输入6。该模拟输入总是连接到相应的管脚
#define P0_4_PINSEL  2 * P0_4
#define P0_5_GPIO      __0//通用数字输入输出管脚
  #define P0_5_MISO0   __1//SPI0主机输入从机输出端。从机到主机的数据传输
  #define P0_5_MAT0_1  __2//**定时器0的匹配输出通道1
  #define P0_5_AD0_7   __3//A/D转换器0输入7。该模拟输入总是连接到相应的管脚
#define P0_5_PINSEL    2 * P0_5
#define P0_6_GPIO      __0//通用数字输入输出管脚
  #define P0_6_MOSI0   __1//SPI0主机输出从机输入端。主机到从机的数据传输
  #define P0_6_CAP0_2  __2//***定时器0的捕获输入通道2
  #define P0_6_AD1_0   __3//A/D转换器1输入0。该模拟输入总是连接到相应的管脚(仅用于 LPC2138)
#define P0_6_PINSEL    2 * P0_6
#define P0_7_GPIO      __0//通用数字输入输出管脚
  #define P0_7_SSEL0   __1//SPI0从机选择。选择SPI接口用作从机
  #define P0_7_PWM2    __2//脉宽调制器输出2
  #define P0_7_EINT2   __3//**外部中断2输入
#define P0_7_PINSEL    2 * P0_7
#define P0_8_GPIO      __0//通用数字输入输出管脚
  #define P0_8_TXD1    __1//UART1的发送器输出
  #define P0_8_PWM4    __2//脉宽调制器输出4
  #define P0_8_AD1_1   __3//A/D转换器1输入1。该模拟输入总是连接到相应的管脚(仅用于 LPC2138)
#define P0_8_PINSEL    2 * P0_8
#define P0_9_GPIO      __0//通用数字输入输出管脚
  #define P0_9_RXD1    __1//UART1的接收器输入
  #define P0_9_PWM6    __2//脉宽调制器输出6
  #define P0_9_EINT3   __3//***外部中断3输入
#define P0_9_PINSEL    2 * P0_9
#define P0_10_GPIO     __0//通用数字输入输出管脚
  #define P0_10_RTS1   __1//UART1请求发送出端(仅用于LP138)
  #define P0_10_CAP1_0 __2//定时器1的捕获输入通道0
  #define P0_10_AD1_2  __3//A/D转换器1输入2。该模拟输入总是连接到相应的管脚(仅用于 LPC2138)
#define P0_10_PINSEL   2 * P0_10
#define P0_11_GPIO     __0//通用数字输入输出管脚
  #define P0_11_CTS1   __1//UART1清除发送入端(仅用于LP138)
  #define P0_11_CAP1_1 __2//定时器1的捕获输入通道1
  #define P0_11_SCL1   __3//I2C1时钟输入/输。开漏输出(符合I2C规范)
#define P0_11_PINSEL   2 * P0_11
#define P0_12_GPIO     __0//通用数字输入输出管脚
  #define P0_12_DSR1   __1//UART1数据设置就绪端(仅用于 LPC2138)
  #define P0_12_MAT1_0 __2//定时器1的匹配输出通道0
  #define P0_12_AD1_3  __3//A/D转换器1输入3。该模拟输入总是连接到相应的管脚(仅用于 LPC2138)
#define P0_12_PINSEL   2 * P0_12
#define P0_13_GPIO     __0//通用数字输入输出管脚
  #define P0_13_DTR1   __1//UART1数据终端就绪
  #define P0_13_MAT1_1 __2//定时器1的匹配输出通道1
  #define P0_13_AD1_4  __3//A/D转换器1输入4。该模拟输入总是连接到相应的管脚(仅用于 LPC2138)
#define P0_13_PINSEL   2 * P0_13
#define P0_14_GPIO     __0//通用数字输入输出管脚
  #define P0_14_DCD1   __1//UART1数据载波检测输入(仅用于 LPC2138)
  #define P0_14_EINT1  __2//**外部中断1输入
  #define P0_14_SDA1   __3//I2C1数据输入/输出。开漏输出(符合I2C规范)
#define P0_14_PINSEL   2 * P0_14
#define P0_15_GPIO     __0//通用数字输入输出管脚
  #define P0_15_RI1    __1//UART1铃响指示输入(仅用于 LPC2138)
  #define P0_15_EINT2  __2//**外部中断2输入
  #define P0_15_AD1_5  __3//A/D转换器1输入5。该模拟输入总是连接到相应的管脚(仅用于 LPC2138)
#define P0_15_PINSEL   2 * P0_15
#define P0_16_GPIO     __0//通用数字输入输出管脚
  #define P0_16_EINT0  __1//**外部中断0输入
  #define P0_16_MAT0_2 __2//**定时器0的匹配输出通道2
  #define P0_16_CAP0_2 __3//***定时器0的捕获输入通道2
#define P0_16_PINSEL   2 * P0_0
#define P0_17_GPIO     __0//通用数字输入输出管脚
  #define P0_17_CAP1_2 __1//**定时器1的捕获输入通道2
  #define P0_17_SCK1   __2//SPI1的串行时钟。SPI时钟从主机输出,从机输入
  #define P0_17_MAT1_2 __3//**定时器1的匹配输出通道2
#define P0_17_PINSEL   2 * P0_1
#define P0_18_GPIO     __0//通用数字输入输出管脚
  #define P0_18_CAP1_3 __1//**定时器1的捕获输入通道3
  #define P0_18_MISO1  __2//SPI1主机输入从机输出端。从机到主机的数据传输
  #define P0_18_MAT1_3 __3//**定时器1的匹配输出通道3
#define P0_18_PINSEL   2 * P0_2
#define P0_19_GPIO     __0//通用数字输入输出管脚
  #define P0_19_MAT1_2 __1//**定时器1的匹配输出通道2
  #define P0_19_MOSI1  __2//SPI1主机输出从机输入端。主机到从机的数据传输
  #define P0_19_CAP1_2 __3//**定时器1的捕获输入通道2
#define P0_19_PINSEL   2 * P0_3
#define P0_20_GPIO     __0//通用数字输入输出管脚
  #define P0_20_MAT1_3 __1//**定时器1的匹配输出通道3
  #define P0_20_SSEL1  __2//SPI1从机选择。选择SPI接口用作从机
  #define P0_20_EINT3  __3//***外部中断3输入
#define P0_20_PINSEL   2 * P0_4
#define P0_21_GPIO     __0//通用数字输入输出管脚
  #define P0_21_PWM5   __1//脉宽调制器输出5
  #define P0_21_AD1_6  __2//A/D转换器1输入6。该模拟输入总是连接到相应的管脚(仅用于 LPC2138)
  #define P0_21_CAP1_3 __3//**定时器1的捕获输入通道3
#define P0_21_PINSEL   2 * P0_5
#define P0_22_GPIO     __0//通用数字输入输出管脚
  #define P0_22_AD1_7  __1//A/D转换器1输入7。该模拟输入总是连接到相应的管脚(仅用于 LPC2138)
  #define P0_22_CAP0_0 __2//***定时器0的捕获输入通道0
  #define P0_22_MAT0_0 __3//**定时器0的匹配输出通道0
#define P0_22_PINSEL   2 * P0_6
#define P0_23_GPIO     __0//通用数字输入输出管脚
#define P0_23_PINSEL   2 * P0_7
#define P0_24_GPIO     0//P0.24 脚未用
#define P0_24_PINSEL 2 * P0_8
#define P0_25_GPIO     __0//通用数字输入输出管脚
  #define P0_25_AD0_4  __1//A/D转换器0输入4。该模拟输入总是连接到相应的管脚.
  #define P0_25_DAC    __2//D/A 转换器输出(仅用于 LPC2138)
#define P0_25_PINSEL   2 * P0_9
#define P0_26_GPIO     __0//通用数字输入输出管脚
  #define P0_26_AD0_5  __1//A/D转换器0输入5。该模拟输入总是连接到相应的管脚
#define P0_26_PINSEL   2 * P0_10
#define P0_27_GPIO     __0//通用数字输入输出管脚
  #define P0_27_AD0_0  __1//A/D转换器0输入0。该模拟输入总是连接到相应的管脚
  #define P0_27_CAP0_1 __2//**定时器0的捕获输入通道1
  #define P0_27_MAT0_1 __3//**定时器0的捕获输入通道1
#define P0_27_PINSEL   2 * P0_11
#define P0_28_GPIO     __0//通用数字输入输出管脚
  #define P0_28_AD0_1  __1//A/D转换器0输入1。该模拟输入总是连接到相应的管脚
  #define P0_28_CAP0_2 __2//***定时器0的捕获输入通道2
  #define P0_28_MAT0_2 __3//**定时器0的匹配输出通道2
#define P0_28_PINSEL   2 * P0_12
#define P0_29_GPIO     __0//通用数字输入输出管脚
  #define P0_29_AD0_2  __1//A/D转换器0输入2。该模拟输入总是连接到相应的管脚
  #define P0_29_CAP0_3 __2//定时器0的捕获输入通道3
  #define P0_29_MAT0_3 __3//定时器0的匹配输出通道3
#define P0_29_PINSEL   2 * P0_13
#define P0_30_GPIO     __0//通用数字输入输出管脚
  #define P0_30_AD0_3  __1//A/D转换器0输入3。该模拟输入总是连接到相应的管脚
  #define P0_30_EINT3  __2//***外部中断3输入
  #define P0_30_CAP0_0 __3//***定时器0的捕获输入通道0
#define P0_30_PINSEL   2 * P0_14
#define P0_31_GPO      __0//通用数字输出管脚(注意:此管脚仅为输出)
#define P0_31_PINSEL   2 * P0_15
        结构指针在ARM之应用(愚人节版)
typedef struct _LPCS_VIC {
  LPC_REG IRQStatus;//IRQ 状态寄存器
  LPC_REG FIQStatus;//FIQ 状态请求
  LPC_REG RawIntr;//所有中断的状态寄存器
  LPC_REG IntSelect;//中断选择寄存器
  LPC_REG IntEnable;//中断使能寄存器
  LPC_REG IntEnClr;//中断使能清零寄存器
  LPC_REG SoftInt;//软件中断寄存器
  LPC_REG SoftIntClr;//软件中断清零寄存器
  LPC_REG Protection;//保护使能寄存器
  LPC_REG Reserved1[3]; //保留3个空位
  LPC_REG VectAddr;//向量地址寄存器
  LPC_REG DefVectAddr;//默认向量地址寄存器
  LPC_REG Reserved2[2]; //保留2个空位
  LPC_REG Reserved3[48];//保留48个空位
  LPC_REG VectAddrs[16];//向量地址寄存器,VICVectAddr0~VICVectAddr15
  LPC_REG Reserved4[48];//保留48个空位
  LPC_REG VectCntls[16];//向量控制寄存器,VICVectCntl0~VICVectCntl15
}LPCS_VIC, *LPCPS_VIC;
#define LPC_BASE_VIC  ((LPCPS_VIC)  0xFFFFF000)//定义硬件结构指针(硬件地址)
#define VIC (*LPC_BASE_VIC)//定位全局结构变量VIC
typedef struct _LPCS_PINSEL {
  LPC_REG PIN_SEL0;//管脚功能选择寄存器0
  LPC_REG PIN_SEL1;//管脚功能选择寄存器1
  LPC_REG Reserved[4]; //保留4个空位
  LPC_REG PIN_SEL2;//管脚功能选择寄存器2
}LPCS_PINSEL, *LPCPS_PINSEL;
#define LPC_BASE_PINSEL  ((LPCPS_PINSEL)  0xE002C000)//定义硬件结构指针(硬件地址)
#define PINSEL (*LPC_BASE_PINSEL)//定位全局结构变量PINSEL
typedef struct _LPCS_MAM {
  LPC_REG MAM_CR;//存储器加速器模块控制寄存器
  LPC_REG MAM_TIM;//存储器加速器定时控制
}LPCS_MAM, *LPCPS_MAM;
#define LPC_BASE_MAM  ((LPCPS_MAM)  0xE01FC000)//定义硬件结构指针(硬件地址)
#define MAM (*LPC_BASE_MAM)//定位全局结构变量MAM
typedef struct _LPCS_PLL {//锁相环
  LPC_REG PLL_CON;//PLL 控制寄存器
  LPC_REG PLL_CFG;//PLL 配置寄存器
  LPC_REG PLL_STAT;//PLL 状态寄存器
  LPC_REG PLL_FEED;//PLL 愦送寄存器
}LPCS_PLL, *LPCPS_PLL;
#define LPC_BASE_PLL  ((LPCPS_PLL)  0xE01FC080)//定义硬件结构指针(硬件地址)
#define PLL (*LPC_BASE_PLL)//定位全局结构变量PLL
//P0和P1定义开始
//1-定义统一的位域结构,访问统一为Bits.PinX
typedef volatile struct
  LPC_REG Pin0:  1;
  LPC_REG Pin1:  1;
  LPC_REG Pin2:  1;
  LPC_REG Pin3:  1;
  LPC_REG Pin4:  1;
  LPC_REG Pin5:  1;
  LPC_REG Pin6:  1;
  LPC_REG Pin7:  1;
  LPC_REG Pin8:  1;
  LPC_REG Pin9:  1;
  LPC_REG Pin10:  1;
  LPC_REG Pin11:  1;
  LPC_REG Pin12:  1;
  LPC_REG Pin13:  1;
  LPC_REG Pin14:  1;
  LPC_REG Pin15:  1;
  LPC_REG Pin16:  1;
  LPC_REG Pin17:  1;
  LPC_REG Pin18:  1;
  LPC_REG Pin19:  1;
  LPC_REG Pin20:  1;
  LPC_REG Pin21:  1;
  LPC_REG Pin22:  1;
  LPC_REG Pin23:  1;
  LPC_REG Pin24:  1;
  LPC_REG Pin25:  1;
  LPC_REG Pin26:  1;
  LPC_REG Pin27:  1;
  LPC_REG Pin28:  1;
  LPC_REG Pin29:  1;
  LPC_REG Pin30:  1;
  LPC_REG Pin31:  1;
}LPC_BIT_GPIO;
//2-定义统一的联合,访问统一为Regs或Bits.PinX
typedef volatile union
  LPC_REG      Regs;
  LPC_BIT_GPIO Bits;
}LPC_REG_GPIO;
//3-定义统一的结构实体,访问统一为PIN.Regs或SET.Bits.PinX
typedef volatile struct _LPCS_GPIO {//通用I/O口
  LPC_REG_GPIO PIN;//GPIO管脚值寄存器
  LPC_REG_GPIO SET;//GPIO输出置位寄存器
  LPC_REG_GPIO DIR;//GPIO方向寄存器
  LPC_REG_GPIO CLR;//GPIO输出清零寄存器
}LPCS_GPIO, *LPCPS_GPIO;
//4-定义P0和P1,访问分别为P0.PIN.Regs或P1.SET.Bits.PinX
#define LPC_BASE_GPIO0  ((LPCPS_GPIO)  0xE0028000)//定义硬件结构指针(硬件地址)
#define LPC_BASE_GPIO1  ((LPCPS_GPIO)  0xE0028010)//定义硬件结构指针(硬件地址)
#define P0 (*LPC_BASE_GPIO0)//定位全局结构变量P0
#define P1 (*LPC_BASE_GPIO1)//定位全局结构变量P1
//5-定义可变的PX,访问分别为P(0).PIN.Regs或P(1).SET.Bits.PinX
#define LPC_BASE_GPIOx(i) ((LPCPS_GPIO) (0xE0028000 + (i << 4)))//定义硬件结构指针(硬件地址)
#define Px(i) (*(LPC_BASE_GPIOx(i)))//定位全局结构变量PX
应用示例
  P0.IODIR.Bits.P0_8 = 1;//设置P0.8为输出
  P0.IOSET.Bits.P0_8 = 1;//P0.8输出高电平
  P0.IOCLR.Bits.P0_8 = 1;//P0.8输出低电平
  P0.IOPIN.Bits.P0_8) ^= 1//P0.8输出电平翻转
//P0和P1定义结束
typedef struct _LPCS_UART {
  union {//地址冲突处理
    LPC_REG _RBR;//接收缓冲
    LPC_REG _THR;//发送保持
    LPC_REG _DLL;//除数锁存低位
  }RBR_THR_DLL;//收发数据
  union {//地址冲突处理
    LPC_REG _IER;//中断使能
    LPC_REG _DLM;//除数锁存高位
  }IER_DLM;
  union {//地址冲突处理
    LPC_REG _IIR;//中断ID
    LPC_REG _FCR;//FIFO控制
  }IIR_FCR;//(8)
  LPC_REG LCR;//线控制
  LPC_REG MCR;//Modem控制(只有UART1)
  LPC_REG LSR;//线状态)
  LPC_REG MSR;//Modem状态(只有UART1)
  LPC_REG SCR;//高速缓存
  LPC_REG TER;//发送使能
}LPCS_UART, *LPCPS_UART;
#define RBR RBR_THR_DLL._RBR
#define THR RBR_THR_DLL._THR
#define DLL RBR_THR_DLL._DLL
#define IER IER_DLM._IER
#define DLM IER_DLM._DLM
#define IIR IIR_FCR._IIR
#define FCR IIR_FCR._FCR
#define LPC_BASE_UART0  ((LPCPS_UART)  0xE000C000)//定义硬件结构指针(硬件地址)
#define U0 (*LPC_BASE_UART0)//定位全局结构变量U0
#define LPC_BASE_UART1  ((LPCPS_UART)  0xE0010000)//定义硬件结构指针(硬件地址)
#define U1 (*LPC_BASE_UART1)//定位全局结构变量U1
typedef struct _LPCS_TIMER {//定时器
  LPC_REG TIMER_IR;//中断寄存器
  LPC_REG TIMER_TCR;//定时器控制寄存器
  LPC_REG TIMER_TC;//定时器计数器
  LPC_REG TIMER_PR;//预分频寄存器
  LPC_REG TIMER_PC;//预分频计数器
  LPC_REG TIMER_MCR;
  LPC_REG TIMER_MR0;
  LPC_REG TIMER_MR1;
  LPC_REG TIMER_MR2;
  LPC_REG TIMER_MR3;
  LPC_REG TIMER_CCR;
  LPC_REG TIMER_CR0;
  LPC_REG TIMER_CR1;
  LPC_REG TIMER_CR2;
  LPC_REG TIMER_CR3;
  LPC_REG TIMER_EMR;
  LPC_REG Reserved[12]; //保留12个空位
  LPC_REG TIMER_CTCR;
}LPCS_TIMER, *LPCPS_TIMER;
#define LPC_BASE_TIMER0  ((LPCPS_TIMER)  0xE0004000)//定义硬件结构指针(硬件地址)
#define LPC_BASE_TIMER1  ((LPCPS_TIMER)  0xE0008000)//定义硬件结构指针(硬件地址)
#define T0 (*LPC_BASE_TIMER0)//定位全局结构变量T0
#define T1 (*LPC_BASE_TIMER1)//定位全局结构变量T1
typedef struct _LPCS_PWM {
  LPC_REG PWM_IR; //中断寄存器
  LPC_REG PWM_TCR;//PWM定时器控制寄存器
  LPC_REG PWM_TC; //PWM定时器计数器
  LPC_REG PWM_PR; //PWM预分频寄存器
  LPC_REG PWM_PC; //PWM预分频计数器寄存器
  LPC_REG PWM_MCR;//PWM匹配控制寄存器
  LPC_REG PWM_MR0;//PWM匹配寄存器0
  LPC_REG PWM_MR1;//PWM匹配寄存器1
  LPC_REG PWM_MR2;//PWM匹配寄存器2
  LPC_REG PWM_MR3;//PWM匹配寄存器3
  LPC_REG Reserved[6]; //保留6个空位
  LPC_REG PWM_MR4;//PWM匹配寄存器4
  LPC_REG PWM_MR5;//PWM匹配寄存器5
  LPC_REG PWM_MR6;//PWM匹配寄存器6
  LPC_REG PWM_PCR;//PWM控制寄存器
  LPC_REG PWM_LER;//PWM锁存使能寄存器
}LPCS_PWM, *LPCPS_PWM;
#define LPC_BASE_PWM  ((LPCPS_PWM)  0xE0014000)//定义硬件结构指针(硬件地址)
#define PWM (*LPC_BASE_PWM)//定位全局结构变量PWM
typedef struct _LPCS_I2C {
  LPC_REG I2C_CONSET; //I2C控制置位寄存器
  LPC_REG I2C_STAT;   //I2C状态寄存器
  LPC_REG I2C_DAT;   //I2C数据寄存器
  LPC_REG I2C_ADR;   //I2C从地址寄存器
  LPC_REG I2C_SCLH;   //SCH占空比寄存器高半字
  LPC_REG I2C_SCLL;   //SCL占空比寄存器低半字
  LPC_REG I2C_CONCLR; //I2C控制清零寄存器
}LPCS_I2C, *LPCPS_I2C;//
#define LPC_BASE_I2C0  ((LPCPS_I2C)  0xE001C000)//定义硬件结构指针(硬件地址)
#define LPC_BASE_I2C1  ((LPCPS_I2C)  0xE005C000)//定义硬件结构指针(硬件地址)
#define I2C0 (*LPC_BASE_I2C0)//定位全局结构变量I2C0
#define I2C1 (*LPC_BASE_I2C1)//定位全局结构变量I2C1
typedef struct _LPCS_SPI {
  LPC_REG SPI_SPCR;
  LPC_REG SPI_SPSR;
  LPC_REG SPI_SPDR;
  LPC_REG SPI_SPCCR;
  LPC_REG SPI_SPINT;
}LPCS_SPI, *LPCPS_SPI;
#define LPC_BASE_SPI  ((LPCPS_SPI)  0xE0020000)//定义硬件结构指针(硬件地址)
#define SPI (*LPC_BASE_SPI)//定位全局结构变量SPI
typedef struct _LPCS_SSP {
  LPC_REG SSP_CR0;
  LPC_REG SSP_CR1;
  LPC_REG SSP_DR;
  LPC_REG SSP_SR;   //SSP状态寄存器
  LPC_REG SSP_CPSR;
  LPC_REG SSP_IMSC;
  LPC_REG SSP_RIS;
  LPC_REG SSP_MIS;
  LPC_REG SSP_ICR;
}LPCS_SSP, *LPCPS_SSP;
#define LPC_BASE_SSP  ((LPCPS_SSP)  0xE0068000)//定义硬件结构指针(硬件地址)
#define SSP (*LPC_BASE_SSP)//定位全局结构变量SSP
typedef struct _LPCS_RTC {
  LPC_REG RTC_ILR;//中断位置寄存器
  LPC_REG RTC_CTC;//时钟节拍计数器
  LPC_REG RTC_CCR;//时钟控制寄存器
  LPC_REG RTC_CIIR;//计数器递增中断寄存器
  LPC_REG RTC_AMR;//报警屏蔽寄存器
  LPC_REG RTC_CTIME0;//完整时间寄存器0
  LPC_REG RTC_CTIME1;//完整时间寄存器1
  LPC_REG RTC_CTIME2;//完整时间寄存器2
  LPC_REG RTC_SEC;//秒寄存器
  LPC_REG RTC_MIN;//分寄存器
  LPC_REG RTC_HOUR;//小时寄存器
  LPC_REG RTC_DOM;//日期(月)寄存器
  LPC_REG RTC_DOW;//星期寄存器
  LPC_REG RTC_DOY;//日期(年)寄存器
  LPC_REG RTC_MONTH;//月寄存器
  LPC_REG RTC_YEAR;//年寄存器
  LPC_REG Reserved[8]; //保留8个空位
  LPC_REG RTC_ALSEC;//秒报警值
  LPC_REG RTC_ALMIN;//分报警值
  LPC_REG RTC_ALHOUR;//小时报警值
  LPC_REG RTC_ALDOM;//日期(月)报警值
  LPC_REG RTC_ALDOW;//星期报警值
  LPC_REG RTC_ALDOY;//日期(年)报警值
  LPC_REG RTC_ALMONTH;//月报警值
  LPC_REG RTC_ALYEAR;//年报警值
  LPC_REG RTC_PREINT;//预分频值,整数部分
  LPC_REG RTC_PREFRAC;//预分频值,小数部分
}LPCS_RTC, *LPCPS_RTC;
#define LPC_BASE_RTC  ((LPCPS_RTC)  0xE0024000)//定义硬件结构指针(硬件地址)
#define RTC (*LPC_BASE_RTC)//定位全局结构变量RTC
typedef struct _LPCS_WDT {
  LPC_REG WDT_WDMOD;//狗模式寄
  LPC_REG WDT_WDTC;//看门狗定时器常数寄存器
  LPC_REG WDT_WDFEED;//看门狗喂狗寄存器
  LPC_REG WDT_WDTV;//看门狗定时器值寄存器
}LPCS_WDT, *LPCPS_WDT;
#define LPC_BASE_WDT  ((LPCPS_WDT)  0xE0000000)//定义硬件结构指针(硬件地址)
#define WDT (*LPC_BASE_WDT)//定位全局结构变量WDT
typedef struct _LPCS_ADC {
  LPC_REG ADCR; //A/D 控制寄存器
  LPC_REG ADDR; //A/D 数据寄存器
  LPC_REG AD_GSR;//A/D 全局启动寄存器
}LPCS_ADC, *LPCPS_ADC;
#define LPC_BASE_ADC0  ((LPCPS_ADC)  0xE0034000)//定义硬件结构指针(硬件地址)
#define LPC_BASE_ADC1  ((LPCPS_ADC)  0xE0060000)//定义硬件结构指针(硬件地址)
#define ADC0 (*LPC_BASE_ADC0)//定位全局结构变量ADC0
#define ADC1 (*LPC_BASE_ADC1)//定位全局结构变量ADC1
typedef struct _LPCS_INTCON {
  LPC_REG EXT_INT;//外部中断标志寄存器
  LPC_REG INT_WAKE;//外部中断唤醒寄存器
  LPC_REG EXT_MODE;//外部中断方式寄存器
  LPC_REG EXT_POLAR;//外部中断极性寄存器
}LPCS_INTCON, *LPCPS_INTCON;
#define LPC_BASE_INTCON  ((LPCPS_INTCON)  0xE01FC140)//定义硬件结构指针(硬件地址)
#define INTCON (*LPC_BASE_INTCON)//定位全局结构变量INTCON
typedef struct _LPCS_POWER {
  LPC_REG P_CON;//功率控制寄存器
  LPC_REG P_CONP;//外部功率控制寄存器
}LPCS_POWER, *LPCPS_POWER;
#define LPC_BASE_POWER  ((LPCPS_POWER)  0xE01FC0C0)//定义硬件结构指针(硬件地址)
#define POWER (*LPC_BASE_POWER)//定位全局结构变量INTCON
typedef struct _LPCS_SYSCON {
  LPC_REG MEM_MAP;//存储器映射控制     //0xE01FC040
  LPC_REG Reserved0[15]; //保留16个空位 //0xE01FC044
  LPC_REG PLL_CON;//PLL 控制寄存器  //0xE01FC080
  LPC_REG PLL_CFG;//PLL 配置寄存器  //0xE01FC084
  LPC_REG PLL_STAT;//PLL 状态寄存器  //0xE01FC088
  LPC_REG PLL_FEED;//PLL 愦送寄存器  //0xE01FC08C
  LPC_REG Reserved1[12]; //保留4个空位 //0xE01FC090
  LPC_REG P_CON;//功率控制寄存器  //0xE01FC0C0
  LPC_REG P_CONP;//外部功率控制寄存器 //0xE01FC0C4
  LPC_REG Reserved2[14]; //保留14个空位 //0xE01FC0C8
  LPC_REG VPB_DIV;//VPB 分频器控制寄存器//0xE01FC100
  LPC_REG Reserved3[15]; //保留15个空位 //0xE01FC104
  LPC_REG EXT_INT;//外部中断标志寄存器 //0xE01FC140
  LPC_REG INT_WAKE;//外部中断唤醒寄存器 //0xE01FC144
  LPC_REG EXT_MODE;//外部中断方式寄存器 //0xE01FC148
  LPC_REG EXT_POLAR;//外部中断极性寄存器//0xE01FC14C
  LPC_REG Reserved4[12]; //保留12个空位 //0xE01FC150
  LPC_REG RS_ID;//复位源识别寄存器  //0xE01FC180
  LPC_REG CS_PR;//代码安全保护寄存器 //0xE01FC184
}LPCS_SYSCON, *LPCPS_SYSCON;
#define LPC_BASE_SYSCON  ((LPCPS_SYSCON)  0xE01FC040)//定义硬件结构指针(硬件地址)
#define SYSCON (*LPC_BASE_SYSCON)//定位全局结构变量SYSCON
#define IAP_FCCLK            11059
/* 定义IAP命令字 */
                                    //   命令           参数
#define     IAP_SELECTOR        50  // 选择扇区     【起始扇区号、结束扇区号】
#define     IAP_RAMTOFLASH      51  // 拷贝数据     【FLASH目标地址、RAM源地址、写入字节数、系统时钟频率】
#define     IAP_ERASESECTOR     52  // 擦除扇区     【起始扇区号、结束扇区号、系统时钟频率】
#define     IAP_BLANKCHK        53  // 查空扇区     【起始扇区号、结束扇区号】
#define     IAP_READPARTID      54  // 读器件ID     【无】
#define     IAP_BOOTCODEID      55  // 读Boot版本号 【无】
#define     IAP_COMPARE         56  // 比较命令     【Flash起始地址、RAM起始地址、需要比较的字节数】
/* 定义IAP返回状态字 */
#define     CMD_SUCCESS          __0
#define     INVALID_COMMAND      __1
#define     SRC_ADDR_ERROR       __2
#define     DST_ADDR_ERROR       __3
#define     SRC_ADDR_NOT_MAPPED  __4
#define     DST_ADDR_NOT_MAPPED  __5
#define     COUNT_ERROR          __6
#define     INVALID_SECTOR       __7
#define     SECTOR_NOT_BLANK     __8
#define     SECTOR_NOT_PREPARED_FOR_WRITE_OPERATION __9
#define     COMPARE_ERROR        __10
#define     IAP_BUSY             __11
typedef struct _LPCS_IAPDATA {// IAP Structure
  unsigned int cmd;           // Command
  unsigned int par[4];        // Parameters
  unsigned int stat;          // Status
}LPCS_IAPDATA, *LPCPS_IAPDATA;
#endif  // __LPC213xDEF_H
 楼主| hotpower 发表于 2010-8-1 16:44 | 显示全部楼层
SERIAL.C
*      RL-ARM - RTX
*      Name:    SERIAL.C
*      Purpose: Interrupt controlled and event driven serial IO
#include <RTL.h>                     /* RTX kernel functions & defines       */
#include <stdio.h>
#define  CTRL_Q  0x11                /* Control+Q character code             */
#define  CTRL_S  0x13                /* Control+S character code             */
static BIT sendstop;                 /* flag: marks XOFF character           */
static char recbuf[256];
static U8 ridx;
static U8 widx;
OS_TID wr_task;
OS_TID rd_task;
*       fputc:  event driven putchar function
int fputc (int c, FILE *f) {
  wr_task = os_tsk_self ();          /* identify task for serial interrupt   */
  os_evt_clr (0x0100, wr_task);
  if (c == '\n') {                   /* expand new line character:           */
    U1.THR = (char)'\r';
    os_evt_wait_or (0x0100, 0xffff); /* wait till character transmited       */
  U1.THR = (char)c;                   /* transmit a character                 */
  return (c);                        /* return character: ANSI requirement   */
*       getkey:  event driven getkey function
int getkey (void) {
  if (ridx == widx) {
    rd_task = os_tsk_self ();
    os_evt_clr (0x0100, rd_task);
    os_evt_wait_or (0x0100, 0xffff); /* wait till character received         */
  return (recbuf[ridx++]);
*       serial:  serial receive and transmit interrupt
void int_serial (void) __irq {
  U8 c;
  if ((U1.IIR & 0x0E) == 0x04) {       /* Receive interrupt                   */
    c = (char) U1.RBR;                 /* read character                      */
    switch (c)  {                     /* process character                   */
      case CTRL_S:
        sendstop = __TRUE;            /* if Control+S stop transmission      */
        goto ack;
      case CTRL_Q:
        sendstop = __FALSE;           /* if Control+Q start transmission     */
        break;
      default:                        /* send character to a mailbox         */
        recbuf[widx++] = c;
        isr_evt_set (0x0100, rd_task);/* set event character received        */
        goto ack;
                                      /* Transmit interrupt                  */
  if (!sendstop)  {                   /* if not Control+S received           */
    isr_evt_set (0x0100, wr_task);    /* Go on, set event transmit ready     */
ack:
  VIC.VectAddr = 0;                    /* Acknowledge Interrupt               */
*       serial_init: initialize serial interface
void serial_init (void) {
  PINSEL.PIN_SEL0 = 0x00050000;               /* Enable RxD1 and TxD1                */
  U1.LCR = 0x83;                       /* 8 bits, no Parity, 1 Stop bit       */
  U1.DLL = 78;                         /* 9600 Baud Rate @ 12MHz VPB Clock    */
  U1.LCR = 0x03;                       /* DLAB = 0                            */
  U1.IER = 0x03;                       /* Enable RDA and THRE interrupts      */
  VIC.VectAddrs[14]  = (U32)int_serial;
  VIC.VectCntls[14]  = 0x27;
  VIC.IntEnable  |= 0x80;
  sendstop = __FALSE;                 /* CtrlQ not received                  */
  ridx = widx = 0;                    /* clear buffer indexes                */
* end of file
 楼主| hotpower 发表于 2010-8-1 16:46 | 显示全部楼层
TRAFFIC.C
*      RL-ARM - RTX
*      Name:    TRAFFIC.C
*      Purpose: Traffic Light Controller example program
#include <stdio.h>                    /* standard I/O .h-file                */
#include <ctype.h>                    /* character functions                 */
#include <string.h>                   /* string and memory functions         */
const char menu[] =
  "\n"
  "+***** TRAFFIC LIGHT CONTROLLER using MDK and RTX kernel *****+\n"
  "| This program is a simple Traffic Light Controller. Between  |\n"
  "| start time and end time the system controls a traffic light |\n"
  "| with pedestrian self-service.  Outside of this time range   |\n"
  "| the yellow caution lamp is blinking.                        |\n"
  "+ command -+ syntax -----+ function --------------------------+\n"
  "| Display  | D           | display times                      |\n"
  "| Time     | T hh:mm:ss  | set clock time                     |\n"
  "| Start    | S hh:mm:ss  | set start time                     |\n"
  "| End      | E hh:mm:ss  | set end time                       |\n"
  "+----------+-------------+------------------------------------+\n";
extern void getline (char *, int);
                                      /* external function:  input line      */
extern void serial_init (void);       /* external function:  init serial UART*/
extern int  getkey (void);            /* external function:  input character */
OS_TID t_command;                     /* assigned task id of task: command   */
OS_TID t_clock;                       /* assigned task id of task: clock     */
OS_TID t_lights;                      /* assigned task id of task: lights    */
OS_TID t_keyread;                     /* assigned task id of task: keyread   */
OS_TID t_getesc;                      /* assigned task id of task: get_esc   */
struct time  {                        /* structure of the time record        */
  U8 hour;                            /* hour                                */
  U8 min;                             /* minute                              */
  U8 sec;                             /* second                              */
struct time ctime = { 12,  0,  0 };   /* storage for clock time values       */
struct time start = {  7, 30,  0 };   /* storage for start time values       */
struct time end   = { 18, 30,  0 };   /* storage for end   time values       */
#define red     0x010000              // I/O Pin:  red    lamp output        //
#define yellow  0x020000              // I/O Pin:  yellow lamp output        //
#define green   0x040000              // I/O Pin:  green  lamp output        //
#define stop    0x100000              // I/O Pin:  stop   lamp output        //
#define walk    0x200000              // I/O Pin:  walk   lamp output        //
#define key     0x004000              // I/O Pin:  self-service key input    //
#define red     P1_16//0x010000              /* I/O Pin:  red    lamp output        */
#define yellow  P1_17//0x020000              /* I/O Pin:  yellow lamp output        */
#define green   P1_18//0x040000              /* I/O Pin:  green  lamp output        */
#define stop    P1_20//0x100000              /* I/O Pin:  stop   lamp output        */
#define walk    P1_21//0x200000              /* I/O Pin:  walk   lamp output        */
#define key     P0_14//0x004000              /* I/O Pin:  self-service key input    */
#define SET(o,s) {        \
  if (s==0) P1.CLR.Regs = (__1 << o);   \
  else      P1.SET.Regs = (__1 << o);   \
char cmdline[16];                     /* storage for command input line      */
struct time rtime;                    /* temporary storage for entry time    */
BIT display_time = __FALSE;           /* flag signal cmd state display_time  */
BIT escape;                           /* flag: mark ESCAPE character entered */
#define ESC  0x1B                     /* ESCAPE character code               */
static U64 cmd_stack[800/8];          /* A bigger stack for command task     */
__task void init (void);              /* Function prototypes                 */
__task void clock (void);
__task void get_escape (void);
__task void command (void);
__task void blinking (void);
__task void lights (void);
__task void keyread (void);
*        Main: Initialize and start RTX Kernel
int main (void) {                     /* program execution starts here       */
  os_sys_init (init);                 /* init and start with task 'INIT'     */
*        Task 1 'init': Initialize
__task void init (void) {
  P1.DIR.Regs = 0xFF0000;                   /* P1.16..22 defined as Outputs       */
  serial_init ();                      /* initialize the serial interface    */
  t_clock   = os_tsk_create (clock,  0); /* start clock task                 */
                                       /* start command task               */
  t_command = os_tsk_create_user (command,0,&cmd_stack,sizeof(cmd_stack));
  t_lights  = os_tsk_create (lights, 0); /* start lights task                */
  t_keyread = os_tsk_create (keyread,0); /* start keyread task               */
  os_tsk_delete_self ();               /* stop init task (no longer needed)  */
*        Task 3 'clock'
__task void clock (void) {
  os_itv_set (100);                    /* set wait interval:  1 second       */
  while (1) {                          /* clock is an endless loop           */
    if (++ctime.sec == 60) {           /* calculate the second               */
      ctime.sec = 0;
      if (++ctime.min == 60) {         /* calculate the minute               */
        ctime.min = 0;
        if (++ctime.hour == 24) {      /* calculate the hour                 */
          ctime.hour = 0;
    if (display_time) {                /* if command_status == display_time  */
      os_evt_set (0x0001,t_command);   /* signal to task command time changed*/
    os_itv_wait ();                    /* wait interval (already set to 1s ) */
*        readtime: convert line input to time values & store in rtime
char readtime (char *buffer) {
  int args;                                    /* number of arguments        */
  int hour,min,sec;
  rtime.sec = 0;                               /* preset second              */
  args = sscanf (buffer, "%d:%d:%d",           /* scan input line for        */
                         &hour, &min, &sec);   /* hour, minute and second    */
  if (hour > 23  ||  min > 59  ||              /* check for valid inputs     */
      sec > 59   ||  args < 2        ) {
     printf ("\n*** ERROR: INVALID TIME FORMAT\n");
     return (0);
  rtime.hour = hour;                           /* setting a new time: hour   */
  rtime.min  = min;                            /* setting a new time: min    */
  rtime.sec  = sec;                            /* setting a new time: sec    */
  return (1);
*        Task 7 'get_escape': check if ESC (escape character) was entered
__task void get_escape (void) {
  while (1)  {                                /* endless loop                */
    if (getkey () == ESC) {                   /* If ESC entered, set flag    */
      escape = __TRUE;                        /* 'escape', set event flag of */
      os_evt_set (0x0002, t_command);         /* task 'command' and          */
*        Task 2 'command': command processor
__task void command (void) {
  U32 i;
  printf (menu);                              /* display command menu        */
    printf ("\nCommand: ");                   /* display prompt              */
    getline (cmdline, sizeof (cmdline));      /* get command line input      */
    for (i = 0; cmdline[i] != 0; i++) {       /* convert to uppercase        */
      cmdline[i] = (char) toupper(cmdline[i]);
    for (i = 0; cmdline[i] == ' '; i++);      /* skip blanks                 */
    switch (cmdline[i]) {                     /* proceed to command function */
      case 'D':                               /* Display Time Command        */
        printf ("Start Time: %02d:%02d:%02d    "
                "End Time: %02d:%02d:%02d\n",
                 start.hour, start.min, start.sec,
                 end.hour,   end.min,   end.sec);
        printf ("                        type ESC to abort\r");
        t_getesc = os_tsk_create (get_escape, 0);/* ESC check in display loop*/
        escape = __FALSE;                     /* clear escape flag           */
        display_time = __TRUE;                /* set display time flag       */
        os_evt_clr (0x0003, t_command);       /* clear pending signals       */
        while (!escape) {                     /* while no ESC entered        */
          printf ("Clock Time: %02d:%02d:%02d\r",   /* display time          */
                   ctime.hour, ctime.min, ctime.sec);
          os_evt_wait_or (0x0003, 0xffff);     /* wait for time change or ESC*/
        os_tsk_delete (t_getesc);             /* terminate 'get_escape' task.*/
        display_time = __FALSE;               /* clear display time flag     */
        printf ("\n\n");
        break;
      case 'T':                               /* Set Time Command            */
        if (readtime (&cmdline[i+1])) {       /* read time input and         */
          ctime.hour = rtime.hour;            /* store in 'ctime'            */
          ctime.min  = rtime.min;
          ctime.sec  = rtime.sec;
        break;
      case 'E':                               /* Set End Time Command        */
          end.hour = rtime.hour;              /* store in 'end'              */
          end.min  = rtime.min;
          end.sec  = rtime.sec;
        break;
      case 'S':                               /* Set Start Time Command      */
          start.hour = rtime.hour;            /* store in 'start'            */
          start.min  = rtime.min;
          start.sec  = rtime.sec;
        break;
      default:                                /* Error Handling              */
        break;
*        signalon: check if clock time is between start and end
char signalon (void) {
  if (memcmp (&start, &end, sizeof (struct time)) < 0)  {
    if (memcmp (&start, &ctime, sizeof (struct time)) < 0  &&
        memcmp (&ctime, &end,   sizeof (struct time)) < 0) {
      return (1);
  else {
    if (memcmp (&end,   &ctime, sizeof (start)) > 0  &&
        memcmp (&ctime, &start, sizeof (start)) > 0) {
      return (1);
  return (0);                                 /* signal off, blinking on     */
*        Task 4 'blinking': runs if current time is outside start & end time
__task void blinking (void) {                 /* blink yellow light          */
  SET (red|yellow|green|stop|walk, 0);        /* all lights off              */
    SET (yellow, 1);                          /* yellow light on             */
    os_dly_wait (30);                         /* wait for timeout: 30 ticks  */
    SET (yellow, 0);                          /* yellow light off            */
    if (signalon ()) {                        /* if blinking time over       */
      os_tsk_create (lights, 0);              /* start lights                */
      os_tsk_delete_self ();                  /* and stop blinking           */
*      Task 5 'lights': executes if current time is between start & end time
__task void lights (void) {                   /* traffic light operation     */
  SET (red|stop, 1);                          /* red & stop lights on        */
  SET (yellow|green|walk, 0);
    os_dly_wait (50);                         /* wait for timeout: 50 ticks  */
    if (!signalon ()) {                       /* if traffic signal time over */
      os_tsk_create (blinking, 0);            /* start blinking              */
      os_tsk_delete_self ();                  /* stop lights                 */
    SET (yellow, 1);
    SET (red|yellow, 0);                      /* green light for cars        */
    SET (green, 1);
    os_evt_clr (0x0010, t_lights);
    os_evt_wait_and (0x0010, 750);            /* wait for event with timeout */
    SET (yellow, 1);                          /* timeout value: 750 ticks    */
    SET (green, 0);
    SET (red, 1);                             /* red light for cars          */
    SET (yellow, 0);
    SET (stop, 0);                            /* green light for walkers     */
    SET (walk, 1);
    os_dly_wait (250);                        /* wait for timeout: 250 ticks */
    SET (stop, 1);                            /* red light for walkers       */
    SET (walk, 0);
*        Task 6 'keyread': process key stroke from pedestrian push button
__task void keyread (void) {
//#define walk    P1_21//0x200000              /* I/O Pin:  walk   lamp output        */
//#define key     P0_14//0x004000              /* I/O Pin:  self-service key input    */
Px(0).DIR.Bits.Pin14 = 1;//设置P0.14为输出
__nop();
Px(0).SET.Bits.Pin14 = 1;//P0.14=1即key =1
__nop();
Px(1).SET.Bits.Pin21 = 1;//P1.21=1即walk=1
__nop();
P0.CLR.Bits.Pin14 = 1;//P0.14=0即key =0
__nop();
P1.SET.Bits.Pin21 = 1;//P1.21=1即walk=1
__nop();
P0.DIR.Bits.Pin14 = 0;//设置P0.14为输入
__nop();
    if (!Px(0).PIN.Bits.Pin14) {//P0.14==0    /* if key pressed              */
      os_evt_set (0x0010, t_lights);          /* send signal to task lights  */
    os_dly_wait (5);                          /* wait for timeout: 5 ticks   */
* end of file
lpcfans 发表于 2010-8-2 12:25 | 显示全部楼层
zh525251 发表于 2010-8-2 13:49 | 显示全部楼层
支持!!!!!!!!
chenxu_1 发表于 2010-8-14 09:29 | 显示全部楼层
hot大叔出过书吗?
 楼主| hotpower 发表于 2010-8-22 11:30 | 显示全部楼层
准备了。半年内吧。
这次当回正事…以前都不以为然…
金鱼木鱼 发表于 2010-9-18 14:34 | 显示全部楼层
hot大叔加油,期待你的处女作
yulri 发表于 2010-10-28 15:11 | 显示全部楼层
加油了……
bairan168 发表于 2010-11-4 16:29 | 显示全部楼层
diny 发表于 2010-12-20 21:35 | 显示全部楼层
加油。
pingting_2005 发表于 2011-1-15 13:43 | 显示全部楼层
看你的设置最大是6个任务 #define OS_TASKCNT     6
但是工程有7个任务(虽然有一个是初始化)
会不会有问题?
米其林r 发表于 2011-1-15 21:55 | 显示全部楼层
ladygaga 发表于 2011-1-30 12:54 | 显示全部楼层
不太懂,也要支持。
