终于来了!First-Generation Extensible Processing Platform
1409|0
atua|  楼主 | 2011-3-3 08:40 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
  • Dual ARM Cortex™-A9 MPCore
    • Up to 800MHz
    • Enhanced with NEON Extension and Single & Double Precision Floating point unit
  • 32kB Instruction & 32kB Data L1 Cache + unified 512kB L2 Cache
  • 256kB on-chip Memory
  • DDR2, DDR3 and LPDDR2 Dynamic Memory Controller
  • QSPI, NAND Flash and NOR Flash Memory Controller
  • 2x USB2.0 (OTG), 2x GbE, 2x CAN2,0B 2x SD/SDIO, 2x UART, 2x SPI, 2x I2C, 32b GPIO
  • AES & SHA 256b encryption engine for secure boot and secure configuration
  • Dual channel 12bit 1Msps Analog-to-Digital converter
  • Advanced Programmable Logic:
    • 30k to 235k Logic Cells (approximately 560k to 4.7M of equivalent ASIC Gates)
    • 240kB to 1.86MB of Extensible Block RAM
    • 80 to 760 18x25 DSP Slices (58 to 912 GMACS peak DSP performance)
  • PCI Express® Gen2x8 (in largest devices)
  • 134 to 404 User IOs (Multiplexed + SelectIO™)
  • 4 to 12 10.3Gbps Transceivers (in largest devices)
http://www.xilinx.com/technology/roadmap/processing-platform.htm
个人签名:“能做”与“做好”的关系
