LTE
1779|9
hjjnet|  楼主 | 2011-4-22 15:38 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
hjjnet|  楼主 | 2011-4-22 15:40 | 只看该作者
PC_CFR FPGA top level interface.pdf
129.13 KB
hjjnet|  楼主 | 2011-4-22 15:42 | 只看该作者
Xilinx Virtex-4 TD-SCDMA Digital Front End
Part 1 - Library Overview.pdf
436.22 KB
Xilinx Virtex-4 TD-SCDMA Digital Front End -- 2
Part 2 - Installing the Library.pdf
457.77 KB
hjjnet|  楼主 | 2011-4-22 15:43 | 只看该作者
Xilinx Virtex-4 TD-SCDMA Digital Front End  -- 3
Part 3 - Using the Library.pdf
364.27 KB
Xilinx Virtex-4 TD-SCDMA Digital Front End  -- 4
Part 4 - Using the Demo Models and Hardware Co-simulation.pdf
234.55 KB
Xilinx Virtex-4 TD-SCDMA Digital Front End  -- 5
Part 5 - Using the Full Speed Demo.pdf
309.93 KB
Xilinx Virtex-4 TD-SCDMA Digital Front End  -- 6
Part 6 - Conformance Testing.pdf
181.06 KB
Xilinx Virtex-4 TD-SCDMA Digital Front End  -- 7
Part 7 - Building a Model for Use in a Full Speed Design.pdf
235.97 KB
奔腾2.0| | 2011-4-22 22:47 | 只看该作者
:L
个人签名:Devere Hu E-mail: deverehu@comtech.com.cn Tel: 027-87568667 Mobile  :13545000634 Comtech (Wuhan), Xilinx FAE
170
