- /* Copyright(c) 2009 Nuvoton Technology Corp. All rights reserved. */
- #include <stdio.h>
- #include "NUC1xx.h"
- #include "NUC1xxM051Seriescfg.h"
- #include "Driver\DrvGPIO.h"
- #include "Driver\DrvSYS.h"
- uint8_t i;
- uint8_t table[] = {0x00,0x6C,0x92,0x82,0x44,0x28,0x10,0x00};
- uint8_t colum[] = {
- 0x7f,0xbf,0xdf,0xef,
- 0xf7,0xfb,0xfd,0xfe
- ** Function name: DelayMs
- ** Descriptions: 延时1ms子程序
- ** input parameters: 无
- ** output parameters: 无
- ** Returned value: 无
- void DelayMs(uint32_t z)
- uint32_t i,j;
- for(i=z;i>0;i--)
- for(j=2000;j>0;j--);
- void Init_GPIO(void)
- /* PA ------- X */
- DrvGPIO_Open( E_GPA, 0, E_IO_OUTPUT );
- DrvGPIO_Open( E_GPA, 1, E_IO_OUTPUT );
- DrvGPIO_Open( E_GPA, 2, E_IO_OUTPUT );
- DrvGPIO_Open( E_GPA, 3, E_IO_OUTPUT);
- DrvGPIO_Open( E_GPA, 4, E_IO_OUTPUT );
- DrvGPIO_Open( E_GPA, 5, E_IO_OUTPUT );
- DrvGPIO_Open( E_GPA, 6, E_IO_OUTPUT );
- DrvGPIO_Open( E_GPA, 7, E_IO_OUTPUT );
- /* PB ------- Y */
- DrvGPIO_Open( E_GPB, 0, E_IO_OUTPUT );
- DrvGPIO_Open( E_GPB, 1, E_IO_OUTPUT );
- DrvGPIO_Open( E_GPB, 2, E_IO_OUTPUT );
- DrvGPIO_Open( E_GPB, 3, E_IO_OUTPUT );
- DrvGPIO_Open( E_GPB, 4, E_IO_OUTPUT );
- DrvGPIO_Open( E_GPB, 5, E_IO_OUTPUT );
- DrvGPIO_Open( E_GPB, 6, E_IO_OUTPUT );
- DrvGPIO_Open( E_GPB, 7, E_IO_OUTPUT );
- void Init_System(void)
- /* Unlock the locked registers before access */
- UNLOCKREG(x); //寄存器锁定键地址寄存器(RegLockAddr) :有些系统控制寄存器需要被保护起来,以防止误操作而影响芯片运行,
- //这些寄存器在上电复位到用户解锁定之前是锁定的。用户可以连续依次写入“59h”, “16h” “88h”到0x5000_0100解锁定.
- /* Enable the 12MHz oscillator oscillation */
- DrvSYS_SetOscCtrl(E_SYS_XTL12M, 1); //SYSCLK->WRCON.XTL12M_EN = 1;
- /* Waiting for 12M Xtal stable */
- //while (DrvSYS_GetChipClockSourceStatus(E_SYS_XTL12M) != 1); //SYSCLK->CLKSTATUS.XTL12M_STB
- /*eClkSrc - [in] E_SYS_XTL12M / E_SYS_XTL32K / E_SYS_OSC22M / E_SYS_OSC10K / E_SYS_PLL */
- // Note: Only some of NuMicro NUC100 Series support this function.
- DrvSYS_Delay(5000);
- LOCKREG(x);
- //向“0x5000_0100”写入任何值,就可以重锁保护寄存器
- ** Function name: main
- ** Descriptions:
- ** 现 象:
- int main (void)
- Init_System();
- Init_GPIO();
- while(1)
- for(i = 0;i < 8; i++)
- GPIOAs.DOUT.Regs = table;
- GPIOBs.DOUT.Regs = colum;
- DelayMs(2);
