GD32F130C8 RTC闹钟无法进入中断,急!!!
2641|1
 楼主| qzhhr 发表于 2018-5-28 06:06 | 显示全部楼层 |阅读模式
#include "gd32_rtc.h"
//RTC
u8  iRTCSECFlag;
u32 iRTCTmr;
void rtc_nvic_configuration(void)
        //SCB_SCR_SLEEPDEEP
   // nvic_priority_group_set(NVIC_PRIGROUP_PRE1_SUB3);
        exti_flag_clear(EXTI_18);
        exti_init(EXTI_18,EXTI_EVENT, EXTI_TRIG_RISING);//EXTI_INTERRUPT
  exti_interrupt_enable(EXTI_18);
        nvic_irq_enable(RTC_IRQn,0,0);//4
//void rtc_prescaler_set(u16 factorA,u16 factorS)//32767);
//    /* disable the write protection */
//    RTC_WPK = RTC_UNLOCK_KEY1;
//    RTC_WPK = RTC_UNLOCK_KEY2;
//          rtc_init_mode_enter();
//          RTC_PSC&=0x007f00ff;
//                RTC_PSC|=PSC_FACTOR_S(factorS);
//    RTC_PSC|=PSC_FACTOR_A(factorA);
//           rtc_init_mode_exit();
//    /* enable the write protection */
//    RTC_WPK = RTC_LOCK_KEY;
void rtc_alarm_INTEn(void)
    RTC_CTL |= RTC_CTL_ALRM0IE;
void rtc_configuration(void)
//    /* enable PMU and BKPI clocks */
    //rcu_periph_clock_enable(RCU_BKPI);
    rcu_periph_clock_enable(RCU_PMU);
//    /* allow access to BKP domain */
    pmu_backup_write_enable();
//    /* reset backup domain */
   // bkp_deinit();
    /* enable LXTAL */
    rcu_osci_on(RCU_IRC40K);
//    /* wait till LXTAL is ready */
    rcu_osci_stab_wait(RCU_IRC40K);
//    /* select RCU_LXTAL as RTC clock source */
    rcu_rtc_clock_config(RCU_RTC_IRC40K);
//    /* enable RTC Clock */
    rcu_periph_clock_enable(RCU_RTC);
//    /* wait for RTC registers synchronization */
    rtc_register_sync_wait();
//    /* wait until last write operation on RTC registers has finished */
//                                rtc_lwoff_wait();
//    /* enable the RTC second interrupt*/
    rtc_interrupt_enable(RTC_INT_ALARM);
//    /* set RTC prescaler: set RTC period to 1s */
   // rtc_prescaler_set(32767);
void RTC_InitAlarmParam(void)
        rtc_parameter_struct  tRTCparam;
        rtc_alarm_struct  rtc_alarm_time;
         rtc_alarm_disable();
         iRTCSECFlag=0;
   iRTCTmr=0;
          tRTCparam.rtc_am_pm=RTC_AM;
          tRTCparam.rtc_display_format=RTC_24HOUR;
                tRTCparam.rtc_hour=0;
                tRTCparam.rtc_minute=0;
                tRTCparam.rtc_second=0;
                tRTCparam.rtc_year=0x18;
                tRTCparam.rtc_month=RTC_MAY;
                tRTCparam.rtc_day_of_week=RTC_MONDAY;
                tRTCparam.rtc_date=0x21;
                tRTCparam.rtc_factor_asyn=0x63;//0;
                tRTCparam.rtc_factor_syn=0x18f;//32767;        //1S
                rtc_alarm_time.rtc_alarm_day=0x21;
          rtc_alarm_time.rtc_alarm_hour=0;
                rtc_alarm_time.rtc_alarm_mask=RTC_ALARM_DATE_MASK|RTC_ALARM_HOUR_MASK|RTC_ALARM_MINUTE_MASK; //RTC_ALARM_SECOND_MASK;//
                rtc_alarm_time.rtc_alarm_minute=0;
                rtc_alarm_time.rtc_alarm_second=20;
                rtc_alarm_time.rtc_am_pm=RTC_AM;
                rtc_alarm_time.rtc_weekday_or_date=RTC_ALARM_DATE_SELECTED;
                rtc_init(&tRTCparam);
    rtc_alarm_config(&rtc_alarm_time);//1S中断一次
                rtc_flag_clear(RTC_STAT_ALRM0F);
                rtc_alarm_INTEn();
                rtc_alarm_enable();
void RTC_Init(void)
         iRTCSECFlag=0;
   iRTCTmr=0;
         rtc_nvic_configuration();
         rtc_configuration();
        // rtc_deinit();
         RTC_InitAlarmParam();
u32 RTC_getTmr(void)
  return iRTCTmr;
void RTC_SecTmr(void)
         iRTCSECFlag=1;        //1S中断标记.
   iRTCTmr++;
void RTC_IRQHandler(void)
//void RTCAlarm_IRQHandler(void)
        //1S中断一次。
        if(rtc_flag_get(RTC_STAT_ALRM0F))
                RTC_SecTmr();
        //rtc_flag_clear(RTC_STAT_RSYNF);
能否请楼主或其它高手帮帮忙,问题在哪?
 楼主| qzhhr 发表于 2018-5-28 18:03 | 显示全部楼层
解决,中断号是17
