串口超时设置失败
1060|1
 楼主| wanghua8866 发表于 2018-7-9 12:02 | 显示全部楼层 |阅读模式
#define   _CRT_SECURE_NO_WARNINGS  //关闭安全检查
#include <windows.h>
#include "iostream"
#include <string.h>
#include <stdlib.h>
#include <stdio.h>
#define   FC_DTRDSR                0x01
#define   FC_RTSCTS                0x02
#define   FC_XONXOFF               0x04
#define   ASCII_BEL                0x07
#define   ASCII_BS                 0x08
#define   ASCII_LF                 0x0A
#define   ASCII_CR                 0x0D
#define   ASCII_XON                0x11
#define   ASCII_XOFF               0x13
HANDLE  OpenCom(DWORD nPort, DWORD nBaud)
        HANDLE m_hIDComDev;
        OVERLAPPED m_OverlappedRead, m_OverlappedWrite;
        char   szPort[15];
        char   szComParams[50];
        DCB   dcb;
        m_hIDComDev = NULL;
        if (nPort>10)
                return NULL;
        wsprintf(szPort, "COM%d", nPort);
        m_hIDComDev = CreateFile(szPort,
                GENERIC_READ | GENERIC_WRITE,
                0,
                NULL,
                OPEN_EXISTING,
        FILE_ATTRIBUTE_NORMAL | FILE_FLAG_OVERLAPPED,
                NULL);
        if (m_hIDComDev == NULL)
                return NULL;
        memset(&m_OverlappedRead, 0, sizeof(OVERLAPPED));
        memset(&m_OverlappedWrite, 0, sizeof(OVERLAPPED));
        COMMTIMEOUTS   CommTimeOuts;
        CommTimeOuts.ReadIntervalTimeout = 0xFFFFFFFF;
        CommTimeOuts.ReadTotalTimeoutMultiplier = 0;
        CommTimeOuts.ReadTotalTimeoutConstant = 0;
        CommTimeOuts.WriteTotalTimeoutMultiplier = 0;
        CommTimeOuts.WriteTotalTimeoutConstant = 5000;
        CommTimeOuts.ReadIntervalTimeout = 1000;
        CommTimeOuts.ReadTotalTimeoutMultiplier = 500;
        CommTimeOuts.ReadTotalTimeoutConstant = 5000;
        CommTimeOuts.WriteTotalTimeoutMultiplier = 500;
        CommTimeOuts.WriteTotalTimeoutConstant = 20000;
        int x =SetCommTimeouts(m_hIDComDev, &CommTimeOuts);
         if (!(x>0))
            return NULL;
        wsprintf(szComParams, "COM\\\\.\\%d:%d,n,8,1", nPort, nBaud);
        m_OverlappedRead.hEvent = CreateEvent(NULL, TRUE, FALSE, NULL);
        m_OverlappedWrite.hEvent = CreateEvent(NULL, TRUE, FALSE, NULL);
        dcb.DCBlength = sizeof(DCB);
        GetCommState(m_hIDComDev, &dcb);
        dcb.BaudRate = nBaud;
        dcb.ByteSize = 8;
        dcb.Parity = NOPARITY; //无 奇 偶 校 验 位
        dcb.StopBits = TWOSTOPBITS; //两 个 停 止 位
        unsigned   char   ucSet;
        ucSet = (unsigned   char)((FC_RTSCTS   &   FC_DTRDSR) != 0);
        ucSet = (unsigned   char)((FC_RTSCTS   &   FC_RTSCTS) != 0);
        ucSet = (unsigned   char)((FC_RTSCTS   &   FC_XONXOFF) != 0);
        if (!SetCommState(m_hIDComDev, &dcb) ||
                !SetupComm(m_hIDComDev, 10000, 10000) ||
                m_OverlappedRead.hEvent == NULL ||
                m_OverlappedWrite.hEvent == NULL)
                DWORD   dwError = GetLastError();
                if (m_OverlappedRead.hEvent != NULL)
                        CloseHandle(m_OverlappedRead.hEvent);
                if (m_OverlappedWrite.hEvent != NULL)
                        CloseHandle(m_OverlappedWrite.hEvent);
                CloseHandle(m_hIDComDev);
                return NULL;
        //PurgeComm(m_hIDComDev, PURGE_TXABORT | PURGE_RXABORT | PURGE_TXCLEAR | PURGE_RXCLEAR);
        PurgeComm(m_hIDComDev,  PURGE_TXCLEAR | PURGE_RXCLEAR);
        return m_hIDComDev;
BOOL   CloseCom(HANDLE m_hIDComDev)
                return false;
        m_hIDComDev = NULL;
        return true;
DWORD  SendHexStr(HANDLE m_hIDComDev, const char *buffer)
        BOOL  bWriteStat;
        DWORD dwBytesWritten = 0;
        OVERLAPPED m_OverlappedWrite;
        BYTE Hbyte;
        BYTE Lbyte;
        int   i;
        int len;
        len = strlen(buffer) / 2;
        BYTE * SendByte = new BYTE[len];
        for (i = 0; i<len; i++)
                switch (buffer[i * 2])
                case 'a':
                case 'A':Hbyte = 10;
                        break;
                case 'b':
                case 'B':Hbyte = 11;
                        break;
                case 'c':
                case 'C':Hbyte = 12;
                        break;
                case 'd':
                case 'D':Hbyte = 13;
                        break;
                case 'e':
                case 'E':Hbyte = 14;
                        break;
                case 'f':
                case 'F':Hbyte = 15;
                        break;
                case '0':Hbyte = 0;
                        break;
                case '1':Hbyte = 1;
                        break;
                case '2':Hbyte = 2;
                        break;
                case '3':Hbyte = 3;
                        break;
                case '4':Hbyte = 4;
                        break;
                case '5':Hbyte = 5;
                        break;
                case '6':Hbyte = 6;
                        break;
                case '7':Hbyte = 7;
                        break;
                case '8':Hbyte = 8;
                        break;
                case '9': Hbyte = 9;
                        break;
                default:  Hbyte = 0;
                        break;
                switch (buffer[i * 2 + 1])
                case 'a':
                case 'A':Lbyte = 10;
                        break;
                case 'b':
                case 'B':Lbyte = 11;
                        break;
                case 'c':
                case 'C':Lbyte = 12;
                        break;
                case 'd':
                case 'D':Lbyte = 13;
                        break;
                case 'e':
                case 'E':Lbyte = 14;
                        break;
                case 'f':
                case 'F':Lbyte = 15;
                        break;
                case '0':Lbyte = 0;
                        break;
                case '1':Lbyte = 1;
                        break;
                case '2':Lbyte = 2;
                        break;
                case '3':Lbyte = 3;
                        break;
                case '4':Lbyte = 4;
                        break;
                case '5':Lbyte = 5;
                        break;
                case '6':Lbyte = 6;
                        break;
                case '7':Lbyte = 7;
                        break;
                case '8':Lbyte = 8;
                        break;
                case '9': Lbyte = 9;
                        break;
                default:  Lbyte = 0;
                        break;
                SendByte[i] = Hbyte * 16 + Lbyte;
                return 0;
        bWriteStat = WriteFile(m_hIDComDev, SendByte, len, &dwBytesWritten, &m_OverlappedWrite);
        if (!bWriteStat)
                if (GetLastError() == ERROR_IO_PENDING)
                        if (WaitForSingleObject(m_OverlappedWrite.hEvent, 10000))
                                return GetLastError();
                        else
                                GetOverlappedResult(m_hIDComDev, &m_OverlappedWrite, &dwBytesWritten, FALSE);//sleep
                                m_OverlappedWrite.Offset += dwBytesWritten;
        else
        return(dwBytesWritten);
DWORD  ReadData(HANDLE m_hIDComDev, char *buffer)
                return 0;
        BOOL   bReadStatus;
        DWORD   dwBytesRead, dwErrorFlags;
        COMSTAT   ComStat;
        ComStat.fRlsdHold = 1;
        OVERLAPPED   m_OverlappedRead;
        while (ComStat.fRlsdHold != 0)
            ClearCommError(m_hIDComDev, &dwErrorFlags, &ComStat);
        if (!ComStat.cbInQue)
                return 0;
        dwBytesRead = (DWORD)ComStat.cbInQue;
        bReadStatus = ReadFile(m_hIDComDev, buffer, dwBytesRead, &dwBytesRead, &m_OverlappedRead);
        if (!bReadStatus)
                        WaitForSingleObject(m_OverlappedRead.hEvent, 20000);//sleep
                        //GetOverlappedResult(m_hIDComDev, &m_OverlappedRead, &dwBytesRead, TRUE);
                        return(dwBytesRead);
        return dwBytesRead;
//***********************************Test***************************************************
HANDLE handle = NULL;
char sendTo[25] = { 0 };
char input[50] = { 0 };
DWORD sd = -1, rd = -1;
int count = 0;
void main()
        // 129 : 1
        handle = OpenCom(3, 115200);
        if (!(handle > 0))
                printf("com open error!\n");
                return;
        count = 0;
        for (int i = 0; i < 80000; i++)
                if (i==0)
                        Sleep(200);
                memset(sendTo, '0', sizeof(sendTo));
                strcpy(sendTo, "0100010000000000640064");
                sd = SendHexStr(handle, sendTo);
                if (!(sd > 0))
                        printf("com send error!\n");
                Sleep(10);
                memset(input, '0', sizeof(input));
                rd = ReadData(handle, input);
                if (!(rd > 0 && sd > 0))
                        count++;
                        printf("com readerData error!%d\n", count);
                else
                        count = 0;
        system("pause");
yklstudent 发表于 2018-7-12 09:41 | 显示全部楼层
你发错地方了
