[STM32F0]
STM32F030K6使用DMA SPI单线发送数据有问题请教!!!
1206|6
lizhenming|  楼主 | 2018-8-21 22:17 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
        GPIO_InitTypeDef            GPIO_InitStructure;
        SPI_InitTypeDef            SPI_InitStructure;
  DMA_InitTypeDef            DMA_InitStructure;
        RCC_AHBPeriphClockCmd( RCC_AHBPeriph_GPIOA, ENABLE);
        RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE);
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_SPI1, ENABLE);
        DMA_DeInit(DMA1_Channel3);
        DMA_InitStructure.DMA_BufferSize = 0;
        DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t) & (SPI1->DR);               //
        DMA_InitStructure.DMA_MemoryBaseAddr = (uint32_t)SPiTram.TramBuff;                    //ÉèÖÃSRAM´æ´¢µØÖ·
        DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralDST;                                //´«Êä·½Ïò ÄÚ´æ->ÍâÉè
        DMA_InitStructure.DMA_Priority = DMA_Priority_High;                           //ÉèÖÃSPIµÄ½ÓÊÕ³¤¶È
        DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;                  //ÍâÉèµØÖ·ÔöÁ¿²»±ä
        DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;                           //ÄÚ´æµØÖ·ÔöÁ¿±ä»¯
        DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;       //ÍâÉè´«Êä¿í¶È
        DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;               //ÄÚ´æ´«Êä¿í¶È
        DMA_InitStructure.DMA_Mode = DMA_Mode_Normal;           //´«Ê䷽ʽ£¬Ò»´Î´«ÊäÍêÍ£Ö¹£¬²»ÖØмÓÔØ
        DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;                                //½ûÖ¹DMAÄÚ´æµ½ÄÚ´æ´«Êä
        DMA_Init(DMA1_Channel3, &DMA_InitStructure);
        DMA_Cmd(DMA1_Channel3, ENABLE);
//                SPI_I2S_DeInit(SPI1);
  SPI_I2S_DMACmd(SPI1, SPI_I2S_DMAReq_Tx, ENABLE);
        SPI_StructInit(&SPI_InitStructure);
        SPI_InitStructure.SPI_Direction = SPI_Direction_1Line_Tx;//SPI_Direction_Tx;//µ¥¹¤Í¨ÐÅ Ö»·¢ËÍ
        SPI_InitStructure.SPI_Mode = SPI_Mode_Master;
        SPI_InitStructure.SPI_DataSize = SPI_DataSize_16b;//16λ·¢ËÍ£¬DMAÒ²ÊÇ16λ´«ËÍÊý¾Ý
        SPI_InitStructure.SPI_CPOL = SPI_CPOL_Low;
        SPI_InitStructure.SPI_CPHA = SPI_CPHA_1Edge;
        SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;
        SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_4;//12MHZ
        SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;                                 //ÏÈ´«¸ß×Ö½Ú
        SPI_InitStructure.SPI_CRCPolynomial = 7;
        SPI_Init(SPI1, &SPI_InitStructure);
        SPI_Cmd(SPI1, ENABLE);
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5|GPIO_Pin_7;//SPIÒ»¶¨Òª³õʼ»¯SCK(PA5)½Å²ÅÄÜÆôÓÃSPI£¬¼´Ê¹²»Óõ½SCK(PA5)½Å
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
        GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
        GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;
        GPIO_Init(GPIOA, &GPIO_InitStructure);
        GPIO_PinAFConfig(GPIOA,GPIO_PinSource5,GPIO_AF_0);
        GPIO_PinAFConfig(GPIOA,GPIO_PinSource7,GPIO_AF_0);
/********** 更新一次数据 ********/
    if(DMA_GetCurrDataCounter(DMA1_Channel3) == 0)
                        DMA_Cmd(DMA1_Channel3, DISABLE);
                        DMA_ClearFlag(DMA1_FLAG_TC3);//发送完成标志
                        DMA_SetCurrDataCounter(DMA1_Channel3, 96);//数据长度96
配置代码如上;
问题是使用示波器测量:SPI-MOSI引脚GPIOA_PIN7并没有数据输出,仿真能看到有跑进去更新数据发送那里。不知道哪里配置有问题,如果是用循环发送那种方式就看到有数据
heimaojingzhang| | 2018-8-22 08:26 | 只看该作者
亲 你的输出数据在哪里
lizhenming|  楼主 | 2018-8-22 13:30 | 只看该作者
heimaojingzhang 发表于 2018-8-22 08:26
亲 你的输出数据在哪里
测量SPI MOSI脚,PA7
lizhenming|  楼主 | 2018-8-22 21:36 | 只看该作者
没有人知道吗???
heimaojingzhang| | 2018-8-23 09:49 | 只看该作者
lizhenming 发表于 2018-8-22 13:30
测量SPI MOSI脚,PA7
我的意思是你有没有给输出赋值
lizhenming|  楼主 | 2018-8-23 11:41 | 只看该作者
heimaojingzhang 发表于 2018-8-23 09:49
我的意思是你有没有给输出赋值
已解决
select326| | 2019-4-29 15:18 | 只看该作者
怎么解决的呀???
