HCPSOC-PRO-9.61
1659|15
llia|  楼主 | 2011-8-29 10:25 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
谁能提供HCPSOC-PRO-9.61的下载地址
wangpe| | 2011-8-29 10:28 | 只看该作者
这个得到外国网站下吧
llia|  楼主 | 2011-8-29 10:33 | 只看该作者
找了很多外国网站都下不了
guoyt| | 2011-8-29 10:41 | 只看该作者
为什么非要用这个编译器呢
这个好像是收费的
hanwe| | 2011-8-29 11:00 | 只看该作者
imagecraft也很好用啊
llia|  楼主 | 2011-8-29 11:15 | 只看该作者
主要是想比较一下,看能不能将代码编译的更紧凑一下
zhanglli| | 2011-8-29 11:26 | 只看该作者
啥原因
llia|  楼主 | 2011-8-29 14:06 | 只看该作者
FLASH 不够
yufe| | 2011-8-29 14:09 | 只看该作者
Cypress 认为IMAGECRAFT比较好用
llia|  楼主 | 2011-8-29 14:24 | 只看该作者
我反汇编过用两用两个编译器编译出来的HEX文档,IMAGECRAF编译出来的基本上是跟汇编写的一样
然后用HCPSOC编译出来的,做了很多调整,特别是BOOT部分,一些代码并没有按照汇编文件规划的放置而且还添加了一些额外的代码
wangpe| | 2011-8-29 14:28 | 只看该作者
呵呵,所以想找HCPSOC来试验试验?
llia|  楼主 | 2011-8-29 14:31 | 只看该作者
是i啊,看他到底调整了多少
zhuww| | 2011-8-29 14:41 | 只看该作者
以前版本的designer3.3里面自带的编译器就是HCPSOC-PRO,不过不清楚版本。
New C Compiler in Service Pack 4.5
Service Pack 4.5 introduces the new ImageCraft free C-compiler. If you currently have a compiler, such as the Hi-Tech Pro compiler, there is no reason for you to upgrade. If you currently use the existing ImageCraft compiler, you may want to upgrade to obtain a compiler which supports the latest Cypress devices and includes some additional optimization.
Following are some frequently asked questions regarding the new, free C-compiler in Service Pack 4.5.
Q1. I notice PSoC Designer no longer supports a free, C-compiler from Hi-Tech Software.
A1. This is correct. Hi-Tech Software was purchased by Microchip. The terms of the Cypress agreement with Microchip require us to remove Hi-Tech Lite as our free compiler in PSoC Designer. Our new free compiler is from ImageCraft. It is an improved ImageCraft compiler that supports the latest Cypress devices and includes some additional optimization.
Q2: I am a Hi-Tech Pro customer, what does this mean to me?
A2: Microchip will continue to sell and support the Hi-Tech Pro compiler through the end of September 2009. By the end of September 2009 Cypress will offer a new Cypress Pro compiler to replace the Hi-Tech Pro compiler. Anyone that owns a Hi-Tech Pro compiler at the end of September will be entitled to a free copy of the new Cypress Pro compiler if they have registered at our web site for the new free compiler. This registration web site will be active soon. . The Hi-Tech compiler will still run after September, but Hi-Tech will not provide support.
Q3: I am a Hi-Tech Pro customer and am approaching the max flash size for my design. What can you tell me about the new Pro compiler?
A3: Cypress has a set of benchmark designs for the new Pro compiler. Flash size will be a key metric monitored to determine whether or not the new compiler is ready. While each design is different, we expect Flash size to remain the same or decrease as measured by our benchmarks.
llia|  楼主 | 2011-8-29 14:49 | 只看该作者
嗯,知道了,先结贴了
