[技术问答]
M051的spi每次有效片选,最多只能发送4个byte?
1793|11
dandadudou|  楼主 | 2019-1-27 15:15 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
新唐的手册,M051的spi接口,每次有效片选,似乎最多只能发送32bit数据。有没有连续发送或者接收模式?
捉虫天师| | 2019-1-27 16:33 | 只看该作者
SPI是作为从机还是主机啊?
643757107| | 2019-1-27 21:14 | 只看该作者
应该没有字节限制吧。
dandadudou|  楼主 | 2019-1-27 22:47 | 只看该作者
捉虫天师 发表于 2019-1-27 16:33
SPI是作为从机还是主机啊?
主机,手册里面描述的是最多32bit。而且手册里面没有详细的时序图,比如ss下降沿到sck的时间等等
yiyigirl2014| | 2019-1-27 23:11 | 只看该作者
* [url=home.php?mod=space&uid=288409]@file[/url]     main.c
* [url=home.php?mod=space&uid=895143]@version[/url]  V3.00
* $Revision: 4 $
* $Date: 5/20/14 10:38a $
* [url=home.php?mod=space&uid=247401]@brief[/url]    M051 Series SPI Driver Sample Code
* @note
* Copyright (C) 2014 Nuvoton Technology Corp. All rights reserved.
#include <stdio.h>
#include "M051Series.h"
#define TEST_COUNT             64
uint32_t g_au32SourceData[TEST_COUNT];
uint32_t g_au32DestinationData[TEST_COUNT];
/* Function prototype declaration */
void SYS_Init(void);
void SPI_Init(void);
/* Main function */
int main(void)
    uint32_t u32DataCount, u32TestCount, u32Err;
    /* Init System, IP clock and multi-function I/O.
       In the end of SYS_Init() will issue SYS_LockReg()
       to lock protected register. If user want to write
       protected register, please issue SYS_UnlockReg()
       to unlock protected register if necessary. */
    SYS_Init();
    /* Configure UART0: 115200, 8-bit word, no parity bit, 1 stop bit. */
    UART_Open(UART0, 115200);
    /* Init SPI */
    SPI_Init();
    printf("\n\n");
    printf("+--------------------------------------------------------------------+\n");
    printf("|                   M051 SPI Driver Sample Code                      |\n");
    printf("\n");
    printf("\nThis sample code demonstrates SPI0 self loop back data transfer.\n");
    printf(" SPI0 configuration:\n");
    printf("     Master mode; data width 32 bits.\n");
    printf(" I/O connection:\n");
    printf("     P1.5 MOSI <--> P1.6 MISO \n");
    printf("\nSPI0 Loopback test ");
    u32Err = 0;
    for(u32TestCount = 0; u32TestCount < 0x1000; u32TestCount++)
        /* set the source data and clear the destination buffer */
        for(u32DataCount = 0; u32DataCount < TEST_COUNT; u32DataCount++)
            g_au32SourceData[u32DataCount] = u32DataCount;
            g_au32DestinationData[u32DataCount] = 0;
        u32DataCount = 0;
        if((u32TestCount & 0x1FF) == 0)
            putchar('.');
        while(1)
            /* Write to TX register */
            SPI_WRITE_TX0(SPI0, g_au32SourceData[u32DataCount]);
            /* Trigger SPI data transfer */
            SPI_TRIGGER(SPI0);
            /* Check SPI0 busy status */
            while(SPI_IS_BUSY(SPI0));
            /* Read received data */
            g_au32DestinationData[u32DataCount] = SPI_READ_RX0(SPI0);
            u32DataCount++;
            if(u32DataCount > TEST_COUNT)
                break;
        /*  Check the received data */
            if(g_au32DestinationData[u32DataCount] != g_au32SourceData[u32DataCount])
                u32Err = 1;
        if(u32Err)
            break;
    if(u32Err)
        printf(" [FAIL]\n\n");
    else
        printf(" [PASS]\n\n");
    /* Close SPI0 */
    SPI_Close(SPI0);
    while(1);
void SYS_Init(void)
    /* Unlock protected registers */
    SYS_UnlockReg();
    /* Init System Clock        */
    /* Enable external 12MHz XTAL */
    CLK_EnableXtalRC(CLK_PWRCON_XTL12M_EN_Msk);
    /* Waiting for clock ready */
    CLK_WaitClockReady(CLK_CLKSTATUS_XTL12M_STB_Msk);
    /* Switch HCLK clock source to HXT and HCLK source divide 1 */
    CLK_SetHCLK(CLK_CLKSEL0_HCLK_S_HXT, CLK_CLKDIV_HCLK(1));
    /* Select HXT as the clock source of UART0 */
    CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UART_S_HXT, CLK_CLKDIV_UART(1));
    /* Select HCLK as the clock source of SPI0 */
    CLK_SetModuleClock(SPI0_MODULE, CLK_CLKSEL1_SPI0_S_HCLK, MODULE_NoMsk);
    /* Enable UART peripheral clock */
    CLK_EnableModuleClock(UART0_MODULE);
    /* Enable SPI0 peripheral clock */
    CLK_EnableModuleClock(SPI0_MODULE);
    /* Init I/O Multi-function        */
    /* Set P3 multi-function pins for UART0 RXD and TXD */
    SYS->P3_MFP = SYS_MFP_P30_RXD0 | SYS_MFP_P31_TXD0;
    /* Setup SPI0 multi-function pins */
    SYS->P1_MFP = SYS_MFP_P14_SPISS0 | SYS_MFP_P15_MOSI_0 | SYS_MFP_P16_MISO_0 | SYS_MFP_P17_SPICLK0;
    /* Lock protected registers */
    SYS_LockReg();
    /* Update System Core Clock */
    /* User can use SystemCoreClockUpdate() to calculate SystemCoreClock and CyclesPerUs automatically. */
    SystemCoreClockUpdate();
void SPI_Init(void)
    /* Init SPI        */
    /* Configure as a master, clock idle low, 32-bit transaction, drive output on falling clock edge and latch input on rising edge. */
    /* Set IP clock divider. SPI clock rate = 2MHz */
    SPI_Open(SPI0, SPI_MASTER, SPI_MODE_0, 32, 2000000);
    /* Enable the automatic hardware slave select function. Select the SS pin and configure as low-active. */
    SPI_EnableAutoSS(SPI0, SPI_SS, SPI_SS_ACTIVE_LOW);
/*** (C) COPYRIGHT 2014 Nuvoton Technology Corp. ***/
官方 提供的测试例子是连续发送接收64个字符。都没啥问题。
dandadudou|  楼主 | 2019-1-27 23:33 | 只看该作者
谢谢,我先看看
mintspring| | 2019-1-27 23:45 | 只看该作者
应该没有限制数量。
mintspring| | 2019-1-27 23:46 | 只看该作者
楼主是作为主机使用,从机要看是什么,从机那边也要配置好。
如果是芯片,那要看那边的协议如何。
arm86| | 2019-1-29 09:31 | 只看该作者
楼主用的是设置寄存器特殊功能的片选吧?如果片选线设置为 GPIO 的输出,无论发送多少个字节都是没有问题的。
gaoyang9992006| | 2019-1-29 09:48 | 只看该作者
参考官方例子的配置方式。这个自发自己收的例子还是很有参考价值的。
xch| | 2019-1-29 11:46 | 只看该作者
别用自动SS模式 :SPI_EnableAutoSS(SPI0, SPI_SS, SPI_SS_ACTIVE_LOW);
