[STM32L0] 请问如何配置STML0单片机多通道ADC采集呀
1928|10
 楼主| wdliming 发表于 2019-3-1 14:10 | 显示全部楼层 |阅读模式
问题如题所示,请问如何用stm32L011芯片配置成多通道ADC采样,比如PA0,PA1两路采样,我的配置如下:
  1. int main(void)
  3. /* USER CODE BEGIN 1 */
  4. uint8_t value_L;
  5. uint8_t value_H;
  6. uint8_t i = 0;
  7. /* USER CODE END 1 */
  8. /* MCU Configuration----------------------------------------------------------*/
  9. /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
  10. HAL_Init();
  11. /* USER CODE BEGIN Init */
  12. /* USER CODE END Init */
  13. /* Configure the system clock */
  14. SystemClock_Config();
  15. /* USER CODE BEGIN SysInit */
  16. /* USER CODE END SysInit */
  17. /* Initialize all configured peripherals */
  18. MX_GPIO_Init();
  19. MX_ADC_Init();
  20. MX_USART2_UART_Init();
  21. /* USER CODE BEGIN 2 */
  22. USART_SendData(USART2,"a");
  23. USART_SendData(USART2,"a");
  24. USART_SendData(USART2,"a");
  25. //HAL_ADC_Start_DMA(&hadc, (uint32_t*)&uhADCxConvertedValue, 1);
  26. /* USER CODE END 2 */
  27. /* Infinite loop */
  28. /* USER CODE BEGIN WHILE */
  29. while (1)
  30. {
  31. /* USER CODE END WHILE */
  32. /* USER CODE BEGIN 3 */
  33. for(i=0;i<2;i++)
  34. {
  35. HAL_ADC_Start(&hadc);
  36. HAL_ADC_PollForConversion(&hadc,0xffff);//wait adc
  37. uhADCxConvertedValue[i]=HAL_ADC_GetValue(&hadc);
  38. //printf("------ch:%d--%d-------\r\n",i,adcBuf[i]);
  39. value_H = (uhADCxConvertedValue[i] & 0xff00 ) >> 8;
  40. value_L = (uhADCxConvertedValue[i] & 0x00ff );
  41. LL_USART_TransmitData8(USART2, value_L);
  42. LL_USART_TransmitData8(USART2, value_H);
  43. }
  44. HAL_ADC_Stop(&hadc);
  45. LL_mDelay(1000);
  46. }
  47. /* USER CODE END 3 */
  48. }
  49. ADC init function is below
  50. /* ADC init function */
  51. void MX_ADC_Init(void)
  52. {
  53. ADC_ChannelConfTypeDef sConfig;
  54.   /**Configure the global features of the ADC (Clock, Resolution, Data Alignment and number of conversion)
  55.   */
  56. hadc.Instance = ADC1;
  57. hadc.Init.OversamplingMode = DISABLE;
  58. hadc.Init.ClockPrescaler = ADC_CLOCK_SYNC_PCLK_DIV1;
  59. hadc.Init.Resolution = ADC_RESOLUTION_12B;
  60. hadc.Init.SamplingTime = ADC_SAMPLETIME_79CYCLES_5;
  61. hadc.Init.ScanConvMode = ADC_SCAN_DIRECTION_FORWARD;
  62. hadc.Init.DataAlign = ADC_DATAALIGN_RIGHT;
  63. hadc.Init.ContinuousConvMode = DISABLE;
  64. hadc.Init.DiscontinuousConvMode = ENABLE;
  65. hadc.Init.ExternalTrigConvEdge = ADC_EXTERNALTRIGCONVEDGE_NONE;
  66. hadc.Init.ExternalTrigConv = ADC_SOFTWARE_START;
  67. hadc.Init.DMAContinuousRequests = DISABLE;
  68. hadc.Init.EOCSelection = ADC_EOC_SINGLE_CONV;
  69. hadc.Init.Overrun = ADC_OVR_DATA_PRESERVED;
  70. hadc.Init.LowPowerAutoWait = DISABLE;
  71. hadc.Init.LowPowerFrequencyMode = DISABLE;
  72. hadc.Init.LowPowerAutoPowerOff = DISABLE;
  73. if (HAL_ADC_Init(&hadc) != HAL_OK)
  74. {
  75.   _Error_Handler(__FILE__, __LINE__);
  76. }
  77.   /**Configure for the selected ADC regular channel to be converted.
  78.   */
  79. sConfig.Channel = ADC_CHANNEL_0;
  80. sConfig.Rank = 0;
  81. if (HAL_ADC_ConfigChannel(&hadc, &sConfig) != HAL_OK)
  82. {
  83.   _Error_Handler(__FILE__, __LINE__);
  84. }
  85.   /**Configure for the selected ADC regular channel to be converted.
  86.   */
  87. sConfig.Channel = ADC_CHANNEL_1;
  88. sConfig.Rank = 1;
  89. if (HAL_ADC_ConfigChannel(&hadc, &sConfig) != HAL_OK)
  90. {
  91.   _Error_Handler(__FILE__, __LINE__);
  92. }
  93. }
但是只能采集到PA0的电压,
高手们请问stm32L011的dma配置和F103的配置哪里一样啊?
 楼主| wdliming 发表于 2019-3-1 14:14 | 显示全部楼层
我用cubemx配置如下:
不知道哪里错了?
ZHMSGE 发表于 2019-3-1 14:15 | 显示全部楼层
在采集函数里面切换通道,只能帮到这里,不用谢我
我也是这样搞的,当时这个问题花费点时间,左后完美解决。任意通道的采集。  发表于 2019-3-11 17:51
 楼主| wdliming 发表于 2019-3-1 14:34 | 显示全部楼层
请问有示例吗??谢谢
guanjiaer 发表于 2019-3-11 13:13 | 显示全部楼层
楼主想用哪种模式进行采集呢
heimaojingzhang 发表于 2019-3-11 13:42 | 显示全部楼层
请问有示例吗??谢谢
他这个配置完了之后自然生成代码啊
keaibukelian 发表于 2019-3-11 14:16 | 显示全部楼层
楼主按照地板进行设置就能生成代码
 楼主| wdliming 发表于 2019-3-12 13:30 | 显示全部楼层
已经弄好了。。
sdswsasx 发表于 2019-3-12 14:43 | 显示全部楼层
代码空行太多。。。
 楼主| wdliming 发表于 2019-3-13 16:41 | 显示全部楼层
代码空行太多。。。
这个无所谓的
个人签名:我的未来不是梦
76
