问一下PSOC4 flash读写的问题
1570|3
 楼主| qw014756 发表于 2019-7-12 16:12 | 显示全部楼层 |阅读模式
入手的片子是CY8C4147  128K ,看提供的CYflash.c里只有写函数,请问具体读取和擦除是怎么实现的。
也不是很清楚 这些资料去哪找,麻烦知道的说一下,谢谢
 楼主| qw014756 发表于 2019-7-12 16:14 | 显示全部楼层
uint32 CySysFlashWriteRow(uint32 rowNum, const uint8 rowData[])
    volatile uint32 retValue = CY_SYS_FLASH_SUCCESS;
    volatile uint32 clkCnfRetValue = CY_SYS_FLASH_SUCCESS;
    volatile uint32 parameters[(CY_FLASH_SIZEOF_ROW + CY_FLASH_SRAM_ROM_DATA) / sizeof(uint32)];
    uint8  interruptState;
    #if (CY_FLASH_CHECKSUM_WORKAROUND)
        uint32 needChecksumWorkaround = 0u;
        uint32 savedIndex = 0u;
        uint32 savedValue = 0u;
        uint32 checksum = 0u;
        uint32 bits = 0u;
        uint32 i;
    #endif  /* (CY_FLASH_CHECKSUM_WORKAROUND) */
    if ((rowNum < CY_FLASH_NUMBER_ROWS) && (rowData != 0u))
        /* Copy data to be written into internal variable */
        (void)memcpy((void *)&parameters[2u], rowData, CY_FLASH_SIZEOF_ROW);
            for (i = 2u; i < ((CY_FLASH_SIZEOF_ROW / sizeof(uint32)) + 2u); i++)
                uint32 tmp = parameters[i];
                if (tmp != 0u)
                    checksum += tmp;
                    bits |= tmp;
                    savedIndex = i;
            needChecksumWorkaround = ((checksum == 0u) && (bits != 0u)) ? 1u : 0u;
            if (needChecksumWorkaround != 0u)
                savedValue = parameters[savedIndex];
                parameters[savedIndex] = 0u;
        /* Load Flash Bytes */
        parameters[0u] = (uint32) (CY_FLASH_GET_MACRO_FROM_ROW(rowNum)        << CY_FLASH_PARAM_MACRO_SEL_OFFSET) |
                         (uint32) (CY_FLASH_PAGE_LATCH_START_ADDR             << CY_FLASH_PARAM_ADDR_OFFSET     ) |
                         (uint32) (CY_FLASH_KEY_TWO(CY_FLASH_API_OPCODE_LOAD) << CY_FLASH_PARAM_KEY_TWO_OFFSET  ) |
                         CY_FLASH_KEY_ONE;
        parameters[1u] = CY_FLASH_SIZEOF_ROW - 1u;
        CY_FLASH_CPUSS_SYSARG_REG = (uint32) &parameters[0u];
        CY_FLASH_CPUSS_SYSREQ_REG = CY_FLASH_CPUSS_REQ_START | CY_FLASH_API_OPCODE_LOAD;
        CY_NOP;
        retValue = CY_FLASH_API_RETURN;
        if(retValue == CY_SYS_FLASH_SUCCESS)
            * Mask all the exceptions to guarantee that Flash write will
            * occur in the atomic way. It will not affect system call
            * execution (flash row write) since it is executed in the NMI
            * context.
            interruptState = CyEnterCriticalSection();
            clkCnfRetValue = CySysFlashClockBackup();
        #if(CY_IP_SPCIF_SYNCHRONOUS)
            if(clkCnfRetValue == CY_SYS_FLASH_SUCCESS)
                retValue = CySysFlashClockConfig();
        #endif  /* (CY_IP_SPCIF_SYNCHRONOUS) */
                /* Write Row */
                parameters[0u]  = (uint32) (((uint32) CY_FLASH_KEY_TWO(CY_FLASH_API_OPCODE_WRITE_ROW) <<  CY_FLASH_PARAM_KEY_TWO_OFFSET) | CY_FLASH_KEY_ONE);
                parameters[0u] |= (uint32)(rowNum << 16u);
                CY_FLASH_CPUSS_SYSREQ_REG = CY_FLASH_CPUSS_REQ_START | CY_FLASH_API_OPCODE_WRITE_ROW;
                CY_NOP;
                if ((retValue == CYRET_SUCCESS) && (needChecksumWorkaround != 0u))
                    (void)memset((void *)&parameters[2u], 0, CY_FLASH_SIZEOF_ROW);
                    parameters[savedIndex] = savedValue;
                                     CY_FLASH_KEY_ONE;
                    CY_NOP;
                        /* Program Row */
                        parameters[0u]  =
                            (uint32) (((uint32) CY_FLASH_KEY_TWO(CY_FLASH_API_OPCODE_PROGRAM_ROW) <<
                        CY_FLASH_CPUSS_SYSREQ_REG = CY_FLASH_CPUSS_REQ_START | CY_FLASH_API_OPCODE_PROGRAM_ROW;
                        CY_NOP;
                clkCnfRetValue = CySysFlashClockRestore();
                if(clkCnfRetValue != CY_SYS_FLASH_SUCCESS)
                    retValue = clkCnfRetValue;
            CyExitCriticalSection(interruptState);
    else
        retValue = CY_SYS_FLASH_INVALID_ADDR;
    return (retValue);
 楼主| qw014756 发表于 2019-7-12 16:15 | 显示全部楼层
只看到了是按照扇区去写,然后扇区怎么擦除呢
 楼主| qw014756 发表于 2019-7-12 16:23 | 显示全部楼层
有知道去哪找资料的么
