[STM32F4] stm32f407IGT6串口问题
824|15
 楼主| chenho 发表于 2019-7-20 13:58 | 显示全部楼层 |阅读模式
最近做一个项目,使用407用到多个串口,串口一,二正常,串口三,六波特率不对,找了半天也沒发现问题,哪位大侠
遇到过?
lizye 发表于 2019-7-20 14:01 | 显示全部楼层
自己用LL库写的还是 CubeMX生成的?
chuxh 发表于 2019-7-20 14:04 | 显示全部楼层
自己配置的仔细看下时钟的配置吧,你这么表述别人也很难具体分析原因的
 楼主| chenho 发表于 2019-7-20 14:11 | 显示全部楼层
串口一六用的同一个时钟,串口二三用的同一个时钟,如果是时钟配置不对,串口一二应该也不正常才对
stly 发表于 2019-7-20 14:14 | 显示全部楼层
你要这么说那就是对的 肯定是你看错了
liliang9554 发表于 2019-7-20 14:18 | 显示全部楼层
你这种得把实际东西贴出来啊 不然不都是猜吗  对结果毫无意义啊
 楼主| chenho 发表于 2019-7-20 14:21 | 显示全部楼层
初始化代码如下:
UARTn_Init(COM1,115200);
UARTn_Init(COM2,115200);
UARTn_Init(COM3,115200);
UARTn_Init(COM6,115200);
void UARTn_Init(COMn_TypeDef COM,uint32_t BaudRate)
        USART_InitTypeDef USART_InitStructure;
        /* Enable GPIO clock */
  RCC_AHB1PeriphClockCmd(COM_TX_PORT_CLK[COM] | COM_RX_PORT_CLK[COM], ENABLE);
  if (COM == COM1 ||COM == COM6)
    /* Enable UART clock */
    RCC_APB2PeriphClockCmd(COM_USART_CLK[COM], ENABLE);
  else
    RCC_APB1PeriphClockCmd(COM_USART_CLK[COM], ENABLE);
        /* USARTx configured as follow:
        - BaudRate = 115200 baud
        - Word Length = 8 Bits
        - One Stop Bit
        - No parity
        - Hardware flow control disabled (RTS and CTS signals)
        - Receive and transmit enabled
  USART_InitStructure.USART_BaudRate = BaudRate;//115200;
  USART_InitStructure.USART_WordLength = USART_WordLength_8b;
  USART_InitStructure.USART_StopBits = USART_StopBits_1;
  USART_InitStructure.USART_Parity = USART_Parity_No;
  USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
  USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
        /* USART configuration */
  USART_Init(COM_USART[COM], &USART_InitStructure);
  /* Connect PXx to USARTx_Tx*/
  GPIO_PinAFConfig(COM_TX_PORT[COM], COM_TX_PIN_SOURCE[COM], COM_TX_AF[COM]);
  /* Connect PXx to USARTx_Rx*/
  GPIO_PinAFConfig(COM_RX_PORT[COM], COM_RX_PIN_SOURCE[COM], COM_RX_AF[COM]);
  /* Configure USART Tx as alternate function  */
  GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
  GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
  GPIO_InitStructure.GPIO_Pin = COM_TX_PIN[COM];
  GPIO_Init(COM_TX_PORT[COM], &GPIO_InitStructure);
  /* Configure USART Rx as alternate function  */
  GPIO_InitStructure.GPIO_Pin = COM_RX_PIN[COM];
  GPIO_Init(COM_RX_PORT[COM], &GPIO_InitStructure);
        Buf_Fifo_Init(COM);
  /* Enable USART */
  USART_Cmd(COM_USART[COM], ENABLE);
        USART_ClearFlag(COM_USART[COM],USART_FLAG_TC);
        USARTn_Int_Init(COM);
dingy 发表于 2019-7-20 14:24 | 显示全部楼层
串口太多了,没搞过。
supernan 发表于 2019-7-20 14:35 | 显示全部楼层
都一样的;
最好程序都贴出来;
 楼主| chenho 发表于 2019-7-20 14:37 | 显示全部楼层
代码没问题,犯了一个低级错误,问题解决了,感谢各位关注
xxrs 发表于 2019-7-20 14:41 | 显示全部楼层
楼主,讲讲你所谓的低级错误啊,免得我也犯这个错误。
 楼主| chenho 发表于 2019-7-20 14:45 | 显示全部楼层
错误太低级。作为一个老司机都不好意思说了。232电平和ttl电平搞错了
 楼主| chenho 发表于 2019-7-20 15:23 | 显示全部楼层
嗯,预料中的结果,先结贴吧,多谢大家啦
wowu 发表于 2019-8-9 12:49 | 显示全部楼层
霍霍  解决问题就好
xiaoqizi 发表于 2019-8-9 12:53 | 显示全部楼层
呵呵  我也明白了
木木guainv 发表于 2019-8-9 12:57 | 显示全部楼层
到底怎么解决的问题啊
