[综合信息] 【HC32L136 demo板】+TN9
1744|7
 楼主| Cjy_JDxy 发表于 2019-9-26 20:32 | 显示全部楼层 |阅读模式
今晚写了个TN9的读取程序,开发环境是IAR。
代码:
* Include files
#include "gpio.h"
* Local pre-processor symbols/macros ('#define')
typedef unsigned char uchar;
void ACK_0() { Gpio_ClrIO(GpioPortB, GpioPin8);}  //
void ACK_1() { Gpio_SetIO(GpioPortB, GpioPin8);}
#define DATA            Gpio_GetInputIO(GpioPortC, GpioPin10)
#define CLOCK           Gpio_GetInputIO(GpioPortC, GpioPin12)
float Temp;
float Temp1,Temp2;
unsigned char ReadData[5];
unsigned int a,b;
//函数名称:Delay()
//功    能:延时子程序
void Delay(unsigned char us)  //5,7,9
  while(--us);
//函数名称:Delayms()
void Delayms(unsigned int ims)
  unsigned int i,j;
    for(i=0;i<ims;i++)
      for(j=0;j<65;j++) { Delay(1); }
void InitIO(void)
    stc_gpio_config_t pstcGpioCfg;
    //stc_gpio_config_t stcGpioCfg;
    ///< 打开GPIO外设时钟门控
    Sysctrl_SetPeripheralGate(SysctrlPeripheralGpio, TRUE);
    ///< 端口方向配置->输出
    pstcGpioCfg.enDir = GpioDirOut;
    ///< 端口驱动能力配置->高驱动能力
    pstcGpioCfg.enDrv = GpioDrvH;
    ///< 端口上下拉配置->无上下拉
    pstcGpioCfg.enPuPd = GpioNoPuPd;
    ///< 端口开漏输出配置->开漏输出关闭
    pstcGpioCfg.enOD = GpioOdDisable;
    ///< 端口输入/输出值寄存器总线控制模式配置->AHB
    pstcGpioCfg.enCtrlMode = GpioAHB;
    ///< GPIO IO PD05初始化(PD05在STK上外接LED)
    Gpio_Init(GpioPortD, GpioPin5, &pstcGpioCfg);
    Gpio_Init(GpioPortB, GpioPin8, &pstcGpioCfg);
     ///< 端口方向配置->输入
    pstcGpioCfg.enDir = GpioDirIn;
    pstcGpioCfg.enDrv = GpioDrvL;
    ///< 端口上下拉配置->上拉
    pstcGpioCfg.enPuPd = GpioPu;
    ///< GPIO IO PD04初始化(PD04在STK上外接KEY(USER))
    Gpio_Init(GpioPortC, GpioPin10, &pstcGpioCfg);
    Gpio_Init(GpioPortC, GpioPin12, &pstcGpioCfg);
void TN_IRACK_EN(void)
        ACK_0();
        Delay(1);
void TN_IRACK_UN(void)
        ACK_1();
        Delay(1);
void TN_ReadData(unsigned char Flag)
        unsigned char i,j,k,BitState=0;
        for(k=0;k<7;k++)
                for(j=0;j<5;j++)
                        for(i=0;i<8;i++)
                                while(1)
                                  if(CLOCK==0)
                                    break;
                                  Delay(1);
                                Delay(1);
                                if(DATA==1)
                                  BitState=1;
                                else
                                  BitState=0;
                                ReadData[j]= ReadData[j]<<1;
                                ReadData[j]= ReadData[j]|BitState;
                                Delay(1);
                                while(1)
                                  if(CLOCK==1)
                                    break;
                                  Delay(1);
                if(ReadData[0]==Flag)
                        k=8;
        TN_IRACK_UN();
float TN_GetData(unsigned char X)
        //Ack_Clk_Data_init;
        InitIO();
        TN_ReadData(X);
        Temp=(ReadData[1]<<8)|ReadData[2];
        Temp=(float)Temp/16.00-273.15;
        return Temp;
float TN_GetTemp(unsigned char mode)
        float T;
                TN_IRACK_UN();
                TN_IRACK_EN();
                if(mode==0)
                        T=TN_GetData(0x4c);
                else
                        T=TN_GetData(0x66);
        return T;
** \brief  Main function of project
** \return uint32_t return value, if needed
** This sample
int32_t main(void)
    InitIO();
    while(1)
        Temp1=TN_GetTemp(0);
        Temp2=TN_GetTemp(1);
        a=((unsigned int)(Temp1*10));
        b=((unsigned int)(Temp2*10));
        Delayms(1500);
效果图:
图中289表示28.9度,290表示29度。
a是体温,b是环境温度。
其中Data脚接PC10,Clock接PC12。有个问题不明白,一开始Data脚接PB5,Clock接PB7则读取不对。
有高手知道,望告知。谢谢!
smartpower 发表于 2019-9-27 08:03 | 显示全部楼层
手动点个赞!
zlmin 发表于 2019-10-3 10:39 来自手机 | 显示全部楼层
谢谢分享!
mcu430 发表于 2019-10-10 15:18 | 显示全部楼层
tn9是啥
 楼主| Cjy_JDxy 发表于 2019-10-10 15:30 | 显示全部楼层
caizhiwei 发表于 2019-10-10 15:51 | 显示全部楼层
有点辣啊
wakayi 发表于 2019-10-31 13:33 | 显示全部楼层
非常感谢楼主分享
凡人8000 发表于 2019-10-31 15:56 | 显示全部楼层
看看是否这个电容影响: 675295dba9380e97f4.png
个人签名:绿水本无忧因风皱面,青山原不老为雪白头。
553
