[PIC®/AVR®/dsPIC®产品] 877a驱动max7219时点阵闪烁问题
1973|16
 楼主| jinwe 发表于 2019-10-12 21:08 | 显示全部楼层 |阅读模式
max7219驱动4块8*8组成8*32点阵时,总是第三块有闪烁,好像是第一块的数据在此闪一下。请问是代码写的问题吗?谢谢了!
  1. #include <pic.h>
  2. __CONFIG(HS&WDTDIS&LVPDIS);
  3. #define INT8U   unsigned char
  4. #define _XTAL_FREQ 4000000UL
  5. //定义Max7219端口
  6. #define DIN RB0
  7. #define CS  RB1
  8. #define CLK RB2
  9. const INT8U disp1[10][8]={
  10. {0x3C,0x42,0x42,0x42,0x42,0x42,0x42,0x3C},//0
  11. {0x18,0x28,0x08,0x08,0x08,0x08,0x08,0x08},//1
  12. {0x3c,0x42,0x42,0x02,0x1c,0x20,0x40,0x7E},//2
  13. {0x3c,0x42,0x42,0x0c,0x2,0x42,0x42,0x3c},//3
  14. {0x28,0x28,0x48,0x48,0x7e,0x8,0x8,0x8},//4
  15. {0x3e,0x40,0x40,0x7c,0x2,0x2,0x42,0x3c},//5
  16. {0x3e,0x42,0x40,0x7C,0x42,0x42,0x42,0x3c},//6
  17. {0x7E,0x02,0x4,0x8,0x8,0x8,0x8,0x8},//7
  18. {0x3c,0x42,0x42,0x3c,0x42,0x42,0x42,0x3c},//8
  19. {0x3c,0x42,0x42,0x42,0x3e,0x2,0x42,0x3c}//9
  20. };
  21. //-----------------------------------------------------------------------------
  22. //向MAX7219写入字节
  23. //-----------------------------------------------------------------------------
  24. void Write_Max7219_byte(INT8U DATA)
  25. {
  26.         INT8U i;
  27.         CS=0;                                //CS=0有效,CS=1锁存
  28.         for(i=8;i>=1;i--)
  29.     {
  30.             CLK=0;
  31.             if(DATA & 0x80) DIN=1; else DIN=0;
  32.                 //DIN=(DATA&0x80);  //&10000000, 编译器对位操作的理解:非0即为1
  33.                 DATA=DATA<<1;
  34.                 CLK=1;                    //上升沿把数据送出去
  35.         }
  36. }
  37. //------------------------------------------------------------------
  38. //向M第一片MAX7219写入数据
  39. //------------------------------------------------------------------
  40. void Write_Max7219_1(INT8U add1,INT8U dat1)
  41. {
  42.      CS=0;
  43.          Write_Max7219_byte(add1);           //写入地址,即数码管编号
  44.      Write_Max7219_byte(dat1);               //写入数据,即数码管显示数字
  45.          CS=1;
  46. }
  47. //---------------------------------------------------------------------
  48. //第二片MAX7219的写入数据
  49. //---------------------------------------------------------------------
  50. void Write_Max7219_2(INT8U add2,INT8U dat2)
  51. {
  52.         CS=0;
  53.         Write_Max7219_byte(add2);
  54.         Write_Max7219_byte(dat2);
  55.         CLK=1;
  56.         Write_Max7219_byte(0x00);  //片1写入空
  57.         Write_Max7219_byte(0x00);
  58.         CS=1;
  59. }
  60. //---------------------------------------------------------------------
  61. //第三片MAX7219的写入数据
  62. //---------------------------------------------------------------------
  63. void Write_Max7219_3(INT8U add3,INT8U dat3)
  64. {
  65.         CS=0;
  66.         Write_Max7219_byte(add3);
  67.         Write_Max7219_byte(dat3);
  68.         CLK=1;
  69.         Write_Max7219_byte(0x00); //片1写入空
  70.         Write_Max7219_byte(0x00);
  71.         Write_Max7219_byte(0x00); //片2写入空
  72.         Write_Max7219_byte(0x00);
  73.         CS=1;
  74. }
  75. //---------------------------------------------------------------------
  76. //第四片MAX7219的写入数据
  77. //---------------------------------------------------------------------
  78. void Write_Max7219_4(INT8U add4,INT8U dat4)
  79. {
  80.         CS=0;
  81.         Write_Max7219_byte(add4);
  82.         Write_Max7219_byte(dat4);
  83.         CLK=1;
  84.         Write_Max7219_byte(0x00); //片1写入空
  85.         Write_Max7219_byte(0x00);
  86.         Write_Max7219_byte(0x00); //片2写入空
  87.         Write_Max7219_byte(0x00);
  88.         Write_Max7219_byte(0x00); //片3写入空
  89.         Write_Max7219_byte(0x00);
  90.         CS=1;
  91. }
  92. //---------------------------------------------------------------------
  93. //初始化芯片
  94. //---------------------------------------------------------------------
  95. void Init_MAX7219(void)
  96. {
  97.         Write_Max7219_1(0x09, 0x00);       //译码方式:不译码
  98.         Write_Max7219_1(0x0a, 0x00);       //亮度最小
  99.         Write_Max7219_1(0x0b, 0x07);       //扫描界限;8个数码管显示
  100.         Write_Max7219_1(0x0c, 0x01);       //掉电模式:0,普通模式:1
  101.         Write_Max7219_1(0x0f, 0x00);       //显示测试:1;测试结束,正常显示:0
  102.         Write_Max7219_2(0x09, 0x00);       //译码方式:不译码
  103.         Write_Max7219_2(0x0a, 0x00);       //亮度最小
  104.         Write_Max7219_2(0x0b, 0x07);       //扫描界限;8个数码管显示
  105.         Write_Max7219_2(0x0c, 0x01);       //掉电模式:0,普通模式:1
  106.         Write_Max7219_2(0x0f, 0x00);       //显示测试:1;测试结束,正常显示:0
  107.         Write_Max7219_3(0x09, 0x00);       //译码方式:不译码
  108.         Write_Max7219_3(0x0a, 0x00);       //亮度最小
  109.         Write_Max7219_3(0x0b, 0x07);       //扫描界限;8个数码管显示
  110.         Write_Max7219_3(0x0c, 0x01);       //掉电模式:0,普通模式:1
  111.         Write_Max7219_3(0x0f, 0x00);       //显示测试:1;测试结束,正常显示:0
  112.
  113.         Write_Max7219_4(0x09, 0x00);       //译码方式:不译码
  114.         Write_Max7219_4(0x0a, 0x00);       //亮度最小
  115.         Write_Max7219_4(0x0b, 0x07);       //扫描界限;8个数码管显示
  116.         Write_Max7219_4(0x0c, 0x01);       //掉电模式:0,普通模式:1
  117.         Write_Max7219_4(0x0f, 0x00);       //显示测试:1;测试结束,正常显示:
  118. }
  119. //---------------------------------------------------------------------
  120. //*********************主程序**************************
  121. //---------------------------------------------------------------------
  122. void main(void)
  123. {
  124.         INT8U i,j=0,k=0;;
  125.         TRISB=0;
  126.         PORTB=0x00;
  127.
  128.         __delay_ms(50);
  129.         Init_MAX7219();
  130.
  131.          while(1)
  132.          {
  133.                    for(i=1;i<9;i++)
  134.                    {
  135.                         Write_Max7219_1(i,disp1[j%10][i-1]);
  136.                         Write_Max7219_2(i,disp1[j/10%10][i-1]);
  137.                         Write_Max7219_3(i,disp1[j/100%10][i-1]);
  138.                         Write_Max7219_4(i,disp1[k][i-1]);
  139.                 }
  140.                 j+=1;
  141.                 if(j>254)
  142.                 {
  143.                         j=0;k+=1;
  144.                         if(k>9) k=0;
  145.                 }
  146.                    __delay_ms(300);
  147.         }
  148. }
 楼主| jinwe 发表于 2019-10-12 21:15 | 显示全部楼层
这是运行时的视频
mintspring 发表于 2019-10-13 14:55 | 显示全部楼层
是不是给的指令或者电路接线有问题。
之前用过这个 芯片,而且可以在Proteus里仿真这个,没遇到过问题,给楼主个建议,在Proteus里仿真一下试试看,我记得支持PIC单片机。
wanduzi 发表于 2019-10-13 19:33 | 显示全部楼层
这个是静态的,莫非楼主填写的代码有问题?
 楼主| jinwe 发表于 2019-10-13 21:25 | 显示全部楼层
另外3个都没问题,图片可能看一清,视频非常清楚。有一种多余的半暗的点。仿真好像没问题
lcczg 发表于 2019-10-14 10:18 | 显示全部楼层
在底层驱动中,CLK =0 -> 1的时间是长的,但从CLK =1 -> 0的时间感觉比较短,楼主看了波形吗?max7219手册上高低脉冲要求最小是50nS.要看下是否符合。
        INT8U i;
        for(i=8;i>=1;i--)
            CLK=0;
                DATA=DATA<<1;
                CLK=1;                    //上升沿把数据送出去
 楼主| jinwe 发表于 2019-10-14 14:18 | 显示全部楼层
在底层驱动中,CLK =0 -> 1的时间是长的,但从CLK =1 -> 0的时间感觉比较短,楼主看了波形吗?max7219手册 ...
谢谢了!我在CLK=1;后面加了2个空操作NOP();NOP();还是有闪烁,怪就怪在只是第3个闪,另外3个没问题。谢谢了,请帮忙指教一下!
lcczg 发表于 2019-10-14 16:40 | 显示全部楼层
谢谢了!我在CLK=1;后面加了2个空操作NOP();NOP();还是有闪烁,怪就怪在只是第3个闪,另外3个没问 ...
外面四片MAX7219写入数据是不是应该顺序写入四三二一。不需要调用单独每片的写函数?这样就不用写入空了。硬件也核查下。
 楼主| jinwe 发表于 2019-10-15 14:12 | 显示全部楼层
代码问题,解决了,参考了一个arduino代码,解决了,谢谢各位的指导!
lcczg 发表于 2019-10-15 14:19 | 显示全部楼层
分享下细节。。
 楼主| jinwe 发表于 2019-10-15 14:40 | 显示全部楼层
  1. #include <pic.h>
  4. #define INT16U  unsigned int
  5. #define _XTAL_FREQ 4000000UL
  6. #define LED_Count 4
  7. //定义Max7219端口
  8. #define DIN RB0
  9. #define CS  RB1
  10. #define CLK RB2
  11. const INT8U disp1[10][8]=
  12. {
  13.         {0x3C,0x42,0x42,0x42,0x42,0x42,0x42,0x3C}, //0
  14.         {0x18,0x28,0x08,0x08,0x08,0x08,0x08,0x08}, //1
  15.         {0x3c,0x42,0x42,0x02,0x1c,0x20,0x40,0x7E}, //2
  16.         {0x3c,0x42,0x42,0x0c,0x02,0x42,0x42,0x3c}, //3
  17.         {0x28,0x28,0x48,0x48,0x7e,0x08,0x08,0x08}, //4
  18.         {0x3e,0x40,0x40,0x7c,0x02,0x02,0x42,0x3c}, //5
  19.         {0x3e,0x42,0x40,0x7C,0x42,0x42,0x42,0x3c}, //6
  20.         {0x7E,0x02,0x04,0x08,0x08,0x08,0x08,0x08}, //7
  21.         {0x3c,0x42,0x42,0x3c,0x42,0x42,0x42,0x3c}, //8
  22.         {0x3c,0x42,0x42,0x42,0x3e,0x02,0x42,0x3c}  //9
  23. };
  24. //-----------------------------------------------------------------------------
  25. //向MAX7219写入字节
  26. //-----------------------------------------------------------------------------
  27. void Write_Max7219_byte(INT8U DATA)
  28. {
  29.   INT8U i;
  30.   CS=0;
  31.   for(i=8;i>=1;i--)
  32.   {
  33.     CLK=0;
  34.     if(DATA&0x80)DIN=1;else DIN=0;
  35.     DATA = DATA<<1;
  36.     CLK=1;
  37.   }
  38. }
  39. //---------------------------------------------------------------------
  40. //MAX7219写入数据
  41. //---------------------------------------------------------------------
  42. void Write_Max7219(INT8U address,INT8U dat)
  43. {
  44.   CS=0;
  45.   Write_Max7219_byte(address);
  46.   Write_Max7219_byte(dat);
  47.   CS=1;
  48. }
  50. //初始化芯片
  51. //---------------------------------------------------------------------
  52. void Init_MAX7219(void)
  53. {
  54.   for(int i=0;i<LED_Count;i++)
  55.   {
  56.     Write_Max7219(0x09, 0x00); // 译码方式:不译码
  57.     Write_Max7219(0x0a, 0x00); // 亮度:0-F
  58.     Write_Max7219(0x0b, 0x07); // 扫描界限;8个数码管显示
  59.     Write_Max7219(0x0c, 0x01); // 掉电模式:0,普通模式:1
  60.     Write_Max7219(0x0f, 0x00); // 显示测试:1;测试结束,正常显示:0
  61.   }
  62. }
  63. void DisplayLED88(INT16U Count)
  64. {
  65.   for(int i=1;i<9;i++)
  66.   {
  67.     CS=0;
  68.     for(int j=0 ; j< LED_Count; j++)
  69.     {
  70.       switch(j)
  71.       {
  72.         case 0:
  73.           Write_Max7219_byte(i);
  74.           Write_Max7219_byte(disp1[Count/1000][i-1]);
  75.           break;
  76.         case 1:
  77.           Write_Max7219_byte(i);
  78.           Write_Max7219_byte(disp1[Count/100%10][i-1]);
  79.           break;
  80.         case 2:
  81.           Write_Max7219_byte(i);
  82.           Write_Max7219_byte(disp1[Count/10%10][i-1]);
  83.           break;
  84.         case 3:
  85.           Write_Max7219_byte(i);
  86.           Write_Max7219_byte(disp1[Count%10][i-1]);
  87.           break;
  88.       }
  89.     }
  90.     CS=1;
  91.   }
  92. }
  93. //---------------------------------------------------------------------
  94. //*********************主程序**************************
  95. //---------------------------------------------------------------------
  96. void main(void)
  97. {
  98.     INT16U k=0;
  99.     TRISB=0;
  100.     PORTB=0x00;
  101.
  102.     __delay_ms(50);
  103.     Init_MAX7219();
  104.
  105.     while(1)
  106.     {
  107.             DisplayLED88(k);
  108.             k+=1;
  109.             if(k>9999) k=0;
  110.             __delay_ms(500);
  111.     }
  112. }
 楼主| jinwe 发表于 2019-10-15 14:41 | 显示全部楼层
这代码还简洁些,完全不闪了
奔波儿熊 发表于 2019-10-15 14:47 | 显示全部楼层
根本问题在哪里,没看出区别啊,指教下
 楼主| jinwe 发表于 2019-10-15 18:34 | 显示全部楼层
应该是写数据这块,这用循环写,好像没了空写入。我也还没搞明白
kxsi 发表于 2019-11-13 11:34 | 显示全部楼层
刷新频率是多少
nawu 发表于 2019-11-13 11:49 | 显示全部楼层
因该就是代码问题
