通过EXIT按键调节PWM的占空比
192|0
3月的尾巴|  楼主 | 2019-11-27 18:06 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
想用EXIT按键功能调节PWM的占空比,定时周期为1000,占空比有500,250,但按下按键由500变250时,输出的方波是这样的   ___| ̄|_| ̄|___,并不是我想要的占空比为250的方波
void TIM3_Mode_Config(int pulse)
        TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
        TIM_OCInitTypeDef  TIM_OCInitStructure;
        u16 t[] = {500,250};
         /* Time base configuration */
  TIM_TimeBaseStructure.TIM_Period = 999;
  TIM_TimeBaseStructure.TIM_Prescaler = 0;
  TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1 ;
  TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
  TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure);
  /* PWM1 Mode configuration: Channel1 */
  TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;
  TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
  TIM_OCInitStructure.TIM_Pulse = t[0];
  TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
  TIM_OC1Init(TIM3, &TIM_OCInitStructure);
  TIM_OC1PreloadConfig(TIM3, TIM_OCPreload_Enable);
        TIM_ARRPreloadConfig(TIM3, ENABLE);
        /* TIM3 enable counter */
  TIM_Cmd(TIM3, ENABLE);
