AHB slave ·2
176|0
丑帅丑帅的|  楼主 | 2018-9-9 11:32 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Is there any possibilities that if write transaction is in progress and if burst is not completed then HWRITE will be low after some clock. i.e. if HWRITE is high and size is 32 and burst is INCR8, ADDR is 0x30. Then it is possible that after 4 cycle HWRITE will be low means when address is 0x40, HWRITE will be low. and if possible than what is the slave respose and HREADY?
