RGB565转BMP格式 C语言程序
143|0
roucun|  楼主 | 2018-10-6 12:38 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
以前做过一个项目 ,就是从屏幕上抓图片下来。我先把RGB图片转BMP的程序分享给大家,这个程序可以在LINUX 系统下执行。压缩包中有750K的RGB 文件,也有1126K的已转化文件。大家可以自己试试。tu0 tu1 tu3 zzz.txt都是原始图片  .bmp的是经过a.out 转化过后的输出文件。我是从某火的429开发板的配套屏幕上截取的图,用的是某火配套的摄像头模块。
单片机源程序如下:
#include<string.h>
#include<stdlib.h>
#include<stdio.h>
#include"rgb2bmp.h"
int RGB2BMP(char *,int ,int ,FILE *);
int main(int argc,char *argv[]){
        double  num_tmp = 0;
        FILE *p;
/***************  input data  ***********
filename      :RGB数据文件名称
nWidth        :所生成文件的水平像素
nHeight       :所生成文件的垂直像素
newFile       :最终生成文件的名称
        size_t read_size;
        size_t write_size;
        printf("argv[1]= %s\n",argv[1]);
        printf("argv[2]= %s\n",argv[2]);
        char * filename = "rgb565_800_480_woman";
        int nWidth = 800;
        int nHeight = 480;
        char *newFile = "rgb565_800_480_woman_0x7f.bmp";
        if(argc!=3){
                printf("Usage:./a.out <picturename> <newpicturename.bmp>\n");
                return -1;
        filename = argv[1];
        newFile = argv[2];
        p = fopen(filename,"rb");
        if( p == NULL){
                printf("open file %s error \n",filename);
                return 0;
        printf("open file %s success\n",filename);
/*************** read Image Data **********/
        long nData = nWidth *nHeight;
        unsigned short * rgb_buffer = malloc(nData * sizeof(short));
        //read_size = fread(rgb_buffer,2,nData,p);
        //printf("rgb_buffer[384000] = %d\n",*(rgb_buffer+383980));
        read_size = fread(rgb_buffer,2,384000,p);
        printf("fread 读取到的字节数是 %ld\n",read_size);
        unsigned long total = nWidth*nHeight*3;
        unsigned char *pVisit = malloc(total*sizeof(char));
        unsigned char *tmp = pVisit;
        long i = 0;
        unsigned char R,G,B;
        unsigned short *free1= rgb_buffer;
        unsigned char *free2= pVisit;
        while(i<nData){
                R = *rgb_buffer&0x1f;
                G = (*rgb_buffer>>5)&0x3f;
                B = (*rgb_buffer>>11)&0x1f;
                B<<3;
                G<<2;
                R<<3;
                num_tmp = R;
                num_tmp/= 31;
                R = num_tmp * 255;
                num_tmp = G;
                num_tmp/= 63;
                G = num_tmp * 255;
                num_tmp = B;
                num_tmp/= 31;
                B = num_tmp * 255;
                *pVisit = R;pVisit++;
                *pVisit = G;pVisit++;
                *pVisit = B;pVisit++;
                rgb_buffer++;
                i++;
        //free(free1);
        printf("read file over. nData = %ld\n",nData);
        fclose(p);
        p = NULL;
        /**************** write file *********/
        FILE *result = fopen(newFile,"wb");
        if(result == NULL){
                printf("open new file failed");
                return -1;
        RGB2BMP(tmp,nWidth,nHeight,result);
        printf("total = %ld\n",total);
        write_size =  fwrite(((char *)pVisit),1,total/3,result);
        printf("write_size = %ld \n",write_size);
        write_size =  fwrite(((char *)pVisit)+total/3,1,total/3,result);
        write_size =  fwrite(((char *)pVisit)+total/3*2,1,total/3,result);
        write_size =  fwrite(free2,1,1152000,result);
        write_size =  fwrite(pVisit+752000,1,500000,result);
        fclose(result);
        result = NULL;
        free(free2);
        return 0;
int RGB2BMP(char *rgb_buffer,int nWidth,int nHeight,FILE *fp1){
        BmpHead m_BMPHeader;
        char bfType[2] = {'B','M'};
        m_BMPHeader.imageSize = 3*nWidth*nHeight + 54;
        m_BMPHeader.blank=0;
        m_BMPHeader.startPosition=54;
        //m_BMPHeader.startPosition=1078;
        fwrite(bfType,sizeof(bfType),1,fp1);
        fwrite(&m_BMPHeader.imageSize,sizeof(m_BMPHeader.imageSize),1,fp1);
        fwrite(&m_BMPHeader.blank,sizeof(m_BMPHeader.blank),1,fp1);
        fwrite(&m_BMPHeader.startPosition,sizeof(m_BMPHeader.startPosition),1,fp1);
        InfoHead m_BMPInfoHeader;
        m_BMPInfoHeader.Length=40;
        m_BMPInfoHeader.width = nWidth;
        m_BMPInfoHeader.height = nHeight;
        m_BMPInfoHeader.colorPlane = 1;
        m_BMPInfoHeader.bitColor = 24;
        m_BMPInfoHeader.zipFormat = 0;
        m_BMPInfoHeader.realSize = 3*nHeight*nWidth;
        m_BMPInfoHeader.xPels=2835;
        m_BMPInfoHeader.yPels=2835;
        m_BMPInfoHeader.colorUse=0;
        m_BMPInfoHeader.colorImportant=0;
        fwrite(&m_BMPInfoHeader.Length,sizeof(m_BMPInfoHeader.Length),1,fp1);
        fwrite(&m_BMPInfoHeader.width,sizeof(m_BMPInfoHeader.width),1,fp1);
        fwrite(&m_BMPInfoHeader.height,sizeof(m_BMPInfoHeader.height),1,fp1);
        fwrite(&m_BMPInfoHeader.colorPlane,sizeof(m_BMPInfoHeader.colorPlane),1,fp1);
        fwrite(&m_BMPInfoHeader.bitColor,sizeof(m_BMPInfoHeader.bitColor),1,fp1);
        fwrite(&m_BMPInfoHeader.zipFormat,sizeof(m_BMPInfoHeader.zipFormat),1,fp1);
        fwrite(&m_BMPInfoHeader.realSize,sizeof(m_BMPInfoHeader.realSize),1,fp1);
        fwrite(&m_BMPInfoHeader.xPels,sizeof(m_BMPInfoHeader.xPels),1,fp1);
        fwrite(&m_BMPInfoHeader.yPels,sizeof(m_BMPInfoHeader.yPels),1,fp1);
        fwrite(&m_BMPInfoHeader.colorUse,sizeof(m_BMPInfoHeader.colorUse),1,fp1);
        fwrite(&m_BMPInfoHeader.colorImportant,sizeof(m_BMPInfoHeader.colorImportant),1,fp1);
        return 0;
复制代码
