44
569
1956
助理工程师
下载附件
2021-11-30 10:25 上传
Stack_Size EQU 0x00000800 AREA STACK, NOINIT, READWRITE, ALIGN = 3 Stack_Mem SPACE Stack_Size __initial_sp
Heap_Size EQU 0x00000400 AREA HEAP, NOINIT, READWRITE, ALIGN = 3 __heap_base Heap_Mem SPACE Heap_Size __heap_limit PRESERVE8 THUMB
__Vectors DCD __initial_sp ; Top of Stack DCD Reset_Handler ; Reset Handler DCD NMI_Handler ; NMI Handler DCD HardFault_Handler ; Hard Fault Handler DCD MemManage_Handler ; MPU Fault Handler DCD BusFault_Handler ; Bus Fault Handler DCD UsageFault_Handler ; Usage Fault Handler DCD 0 ; Reserved DCD 0 ; Reserved DCD 0 ; Reserved DCD 0 ; Reserved DCD SVC_Handler ; SVCall Handler DCD DebugMon_Handler ; Debug Monitor Handler DCD 0 ; Reserved DCD PendSV_Handler ; PendSV Handler DCD SysTick_Handler ; SysTick Handler ; /* external interrupts handler */ DCD WWDGT_IRQHandler ; 16:Window Watchdog Timer DCD LVD_IRQHandler ; 17:LVD through EXTI Line detect DCD TAMPER_IRQHandler ; 18:Tamper Interrupt DCD RTC_IRQHandler ; 19:RTC through EXTI Line DCD FMC_IRQHandler ; 20:FMC DCD RCU_IRQHandler ; 21:RCU DCD EXTI0_IRQHandler ; 22:EXTI Line 0 DCD EXTI1_IRQHandler ; 23:EXTI Line 1 DCD EXTI2_IRQHandler ; 24:EXTI Line 2 DCD EXTI3_IRQHandler ; 25:EXTI Line 3 DCD EXTI4_IRQHandler ; 26:EXTI Line 4 DCD DMA0_Channel0_IRQHandler ; 27:DMA0 Channel 0 DCD DMA0_Channel1_IRQHandler ; 28:DMA0 Channel 1 DCD DMA0_Channel2_IRQHandler ; 29:DMA0 Channel 2 DCD DMA0_Channel3_IRQHandler ; 30:DMA0 Channel 3 DCD DMA0_Channel4_IRQHandler ; 31:DMA0 Channel 4 DCD DMA0_Channel5_IRQHandler ; 32:DMA0 Channel 5 DCD DMA0_Channel6_IRQHandler ; 33:DMA0 Channel 6 DCD ADC0_1_IRQHandler ; 34:ADC0 and ADC1 DCD CAN0_TX_IRQHandler ; 35:CAN0 TX DCD CAN0_RX0_IRQHandler ; 36:CAN0 RX0 DCD CAN0_RX1_IRQHandler ; 37:CAN0 RX1 DCD CAN0_EWMC_IRQHandler ; 38:CAN0 EWMC DCD EXTI5_9_IRQHandler ; 39:EXTI Line 5 to EXTI Line 9 DCD TIMER0_BRK_TIMER8_IRQHandler ; 40:TIMER0 Break and TIMER8 global DCD TIMER0_UP_TIMER9_IRQHandler ; 41:TIMER0 Update and TIMER9 global DCD TIMER0_TRG_CMT_TIMER10_IRQHandler ; 42:TIMER0 Trigger and Commutation and TIMER10 global DCD TIMER0_Channel_IRQHandler ; 43:TIMER0 Channel Capture Compare DCD TIMER1_IRQHandler ; 44:TIMER1 DCD TIMER2_IRQHandler ; 45:TIMER2 DCD TIMER3_IRQHandler ; 46:TIMER3 DCD I2C0_EV_IRQHandler ; 47:I2C0 Event DCD I2C0_ER_IRQHandler ; 48:I2C0 Error DCD I2C1_EV_IRQHandler ; 49:I2C1 Event DCD I2C1_ER_IRQHandler ; 50:I2C1 Error DCD SPI0_IRQHandler ; 51:SPI0 DCD SPI1_IRQHandler ; 52:SPI1 DCD USART0_IRQHandler ; 53:USART0 DCD USART1_IRQHandler ; 54:USART1 DCD USART2_IRQHandler ; 55:USART2 DCD EXTI10_15_IRQHandler ; 56:EXTI Line 10 to EXTI Line 15 DCD RTC_Alarm_IRQHandler ; 57:RTC Alarm through EXTI Line DCD USBFS_WKUP_IRQHandler ; 58:USBFS WakeUp from suspend through EXTI Line DCD TIMER7_BRK_TIMER11_IRQHandler ; 59:TIMER7 Break Interrupt and TIMER11 global DCD TIMER7_UP_TIMER12_IRQHandler ; 60:TIMER7 Update Interrupt and TIMER12 global DCD TIMER7_TRG_CMT_TIMER13_IRQHandler ; 61:TIMER7 Trigger and Commutation Interrupt and TIMER13 DCD TIMER7_Channel_IRQHandler ; 62:TIMER7 Channel Capture Compare DCD ADC2_IRQHandler ; 63:ADC2 DCD EXMC_IRQHandler ; 64:EXMC DCD SDIO_IRQHandler ; 65:SDIO DCD TIMER4_IRQHandler ; 66:TIMER4 DCD SPI2_IRQHandler ; 67:SPI2 DCD UART3_IRQHandler ; 68:UART3 DCD UART4_IRQHandler ; 69:UART4 DCD TIMER5_IRQHandler ; 70:TIMER5 DCD TIMER6_IRQHandler ; 71:TIMER6 DCD DMA1_Channel0_IRQHandler ; 72:DMA1 Channel0 DCD DMA1_Channel1_IRQHandler ; 73:DMA1 Channel1 DCD DMA1_Channel2_IRQHandler ; 74:DMA1 Channel2 DCD DMA1_Channel3_IRQHandler ; 75:DMA1 Channel3 DCD DMA1_Channel4_IRQHandler ; 76:DMA1 Channel4 DCD ENET_IRQHandler ; 77:Ethernet DCD ENET_WKUP_IRQHandler ; 78:Ethernet Wakeup through EXTI line DCD CAN1_TX_IRQHandler ; 79:CAN1 TX DCD CAN1_RX0_IRQHandler ; 80:CAN1 RX0 DCD CAN1_RX1_IRQHandler ; 81:CAN1 RX1 DCD CAN1_EWMC_IRQHandler ; 82:CAN1 EWMC DCD USBFS_IRQHandler ; 83:USBFS DCD 0 ; 84:Reserved DCD DMA1_Channel5_IRQHandler ; 85:DMA1 Channel5 DCD DMA1_Channel6_IRQHandler ; 86:DMA1 Channel6 DCD USART5_IRQHandler ; 87:USART5 DCD I2C2_EV_IRQHandler ; 88:I2C2 Event DCD I2C2_ER_IRQHandler ; 89:I2C2 Error DCD 0 ; 90:Reserved DCD 0 ; 91:Reserved DCD 0 ; 92:Reserved DCD 0 ; 93:Reserved DCD DCI_IRQHandler ; 94:DCI DCD CAU_IRQHandler ; 95:CAU DCD HAU_TRNG_IRQHandler ; 96:HAU and TRNG DCD 0 ; 97:Reserved DCD UART6_IRQHandler ; 98:UART6 DCD UART7_IRQHandler ; 99:UART7 DCD 0 ; 100:Reserved DCD 0 ; 101:Reserved DCD 0 ; 102:Reserved DCD 0 ; 103:Reserved DCD TLI_IRQHandler ; 104:TLI DCD TLI_ER_IRQHandler ; 105:TLI error __Vectors_End __Vectors_Size EQU __Vectors_End - __Vectors
AREA |.text|, CODE, READONLY
Reset_Handler PROC EXPORT Reset_Handler [WEAK] IMPORT __main IMPORT SystemInit LDR R0, =SystemInit BLX R0 LDR R0, =__main BX R0 ENDP
发表回复 本版积分规则 回帖后跳转到最后一页
扫码关注 21ic 官方微信
扫码关注嵌入式微处理器
扫码关注21ic项目外包
扫码关注21ic视频号
扫码关注21ic抖音号
本站介绍 | 申请友情链接 | 欢迎投稿 | 隐私声明 | 广告业务 | 网站地图 | 联系我们 | 诚聘英才 | 论坛帮助
京公网安备 11010802024343号
