[PCB] Wallys QCA9880 802.11ac Dual band Qualcomm-Atheros
1147|0
 楼主| wirelesswifi6 发表于 2022-2-24 09:31 | 显示全部楼层 |阅读模式
DR600VX
QCA9880 2x2 2.4G/5G FCC/CE
Qualcomm-Atheros #QCA9880 chipset
2.4GHz max 24dBm & 5GHz max 23dBm output power
IEEE 802.11accompliant & backward compatible with 802.11a/b/g/n
2x2 MIMO Technology, up to 867Mbps
Mini PCI Express edge connector
Support the Frequency 4920MHz~4980MHz
RoHS compliance ensure a high level protection of human health and the environment from risks that can be posed by chemicals
Supports Spatial Multiplexing, Cyclic-Delay Diversity (CDD), Low-Density Parity Check
(LDPC) Codes, Maximal Ratio Combining (MRC), Space Time Block Code (STBC)
Supports IEEE 802.11d, e, h, i, k, r, v time stamp, and w standards
Supports Dynamic Frequency Selection (DFS)
https://www.wallystech.com/Network_Card/DR600VX-Qualcomm-Atheros-QCA9880-2T2R-MIMO-802.11ac-Mini-PCIe-Wi-Fi-Module-Dual-Band-2.4GHz-5GHz.html
EMAIL:sales@wallystech.com
WEB:https://www.wallystech.com/
