[开发工具]
【APM32F107VC-MINI开发板测评】矩阵键盘
641|34
今天搞了一下矩阵键盘。
行线:PC0,PC1,PC2,PC3。列线:PA4,PA5,PA6,PA7。
原理图:
串口打印键值。
代码:
#include "main.h"
/** @addtogroup Examples
#define Hang_00_L  GPIO_ResetBit(GPIOC,GPIO_PIN_0)
#define Hang_00_H  GPIO_SetBit(GPIOC,GPIO_PIN_0)
#define Hang_01_L  GPIO_ResetBit(GPIOC,GPIO_PIN_1)
#define Hang_01_H  GPIO_SetBit(GPIOC,GPIO_PIN_1)
#define Hang_02_L  GPIO_ResetBit(GPIOC,GPIO_PIN_2)
#define Hang_02_H  GPIO_SetBit(GPIOC,GPIO_PIN_2)
#define Hang_03_L  GPIO_ResetBit(GPIOC,GPIO_PIN_3)
#define Hang_03_H  GPIO_SetBit(GPIOC,GPIO_PIN_3)
#define Lie_00_V   GPIO_ReadInputBit(GPIOA,GPIO_PIN_4)
#define Lie_01_V   GPIO_ReadInputBit(GPIOA,GPIO_PIN_5)
#define Lie_02_V   GPIO_ReadInputBit(GPIOA,GPIO_PIN_6)
#define Lie_03_V   GPIO_ReadInputBit(GPIOA,GPIO_PIN_7)
#define Lie_04_V   ((GPIO_ReadInputPort(GPIOA)>>4) & 0x0FU)
#define Hang_10_L  GPIO_ResetBit(GPIOA,GPIO_PIN_4)
#define Hang_10_H  GPIO_SetBit(GPIOA,GPIO_PIN_4)
#define Hang_11_L  GPIO_ResetBit(GPIOA,GPIO_PIN_5)
#define Hang_11_H  GPIO_SetBit(GPIOA,GPIO_PIN_5)
#define Hang_12_L  GPIO_ResetBit(GPIOA,GPIO_PIN_6)
#define Hang_12_H  GPIO_SetBit(GPIOA,GPIO_PIN_6)
#define Hang_13_L  GPIO_ResetBit(GPIOA,GPIO_PIN_7)
#define Hang_13_H  GPIO_SetBit(GPIOA,GPIO_PIN_7)
#define Lie_10_V    GPIO_ReadInputBit(GPIOC,GPIO_PIN_0)
#define Lie_11_V    GPIO_ReadInputBit(GPIOC,GPIO_PIN_1)
#define Lie_12_V    GPIO_ReadInputBit(GPIOC,GPIO_PIN_2)
#define Lie_13_V    GPIO_ReadInputBit(GPIOC,GPIO_PIN_3)
#define Lie_14_V   ((GPIO_ReadInputPort(GPIOC)<<4)  & 0xF0U)
#define  jpys 20   //??????jpys==20?????????
uint8_t temp;
uint8_t txBuffer[50];
uint8_t rxBuffer[10];
uint8_t cord_h,cord_l;//???????
volatile uint32_t nBytesRead = 0;
//volatile bool txThresholdEventReceived = false;
//volatile bool rxThresholdEventReceived = false;
/** @addtogroup USART_Printf
/** @addtogroup USART_Printf_Variables Variables
volatile uint32_t tick = 0;
uint8_t txBuf[] = "Key Value = :   \r\n";
/**@} end of group USART_Printf_Variables */
void DelayMs(uint16_t nms)
        uint16_t i,j;
        for(i=0;i<nms;i++)
       for(j=0;j<200;j++);
/** @addtogroup USART_Printf_Functions Functions
void PORT_Initialize1(void)
   /************************** GROUP 0 Initialization *************************/
         GPIO_Config_T GPIO_ConfigStruct;
   /************************** GROUP 1 Initialization *************************/
   RCM_EnableAPB2PeriphClock(RCM_APB2_PERIPH_GPIOA | RCM_APB2_PERIPH_GPIOC);
                GPIO_ConfigStruct.mode = GPIO_MODE_OUT_PP;
                GPIO_ConfigStruct.pin = GPIO_PIN_0 | GPIO_PIN_1 | GPIO_PIN_2 | GPIO_PIN_3;
                GPIO_ConfigStruct.speed = GPIO_SPEED_50MHz;
                GPIO_Config(GPIOC, &GPIO_ConfigStruct);
                GPIO_ConfigStruct.mode = GPIO_MODE_IN_PU;
                GPIO_ConfigStruct.pin = GPIO_PIN_4 | GPIO_PIN_5 | GPIO_PIN_6 | GPIO_PIN_7;
                GPIO_Config(GPIOA, &GPIO_ConfigStruct);
void PORT_Initialize2(void)
unsigned char KeyScan(void)  //????????????????
    uint16_t i,j;
    PORT_Initialize1();
    for(i=0;i<1250;i++);
    Hang_00_L;
    Hang_01_L;
    Hang_02_L;
    Hang_03_L;
    //cord_h=(Lie_04_V&0x0f);
    cord_h=(uint8_t)(Lie_04_V);
    //cord_h=Lie_01_V|Lie_02_V|Lie_03_V|Lie_04_V;
    if(cord_h != 0xf0)    //?????????
         DelayMs(10);        //??
        if(cord_h!=0xf0)
            cord_h=(uint8_t)(Lie_04_V);        //?????
            PORT_Initialize2();
            if((cord_h&0x01)==0x01)
                Hang_10_H;
            else
                Hang_10_L;
            if((cord_h&0x02)==0x02)
                Hang_11_H;
            else
                Hang_11_L;
            if((cord_h&0x04)==0x04)
                Hang_12_H;
            else
                Hang_12_L;
            if((cord_h&0x08)==0x08)
                Hang_13_H;
            else
                Hang_13_L;
            cord_l=(uint8_t)(Lie_14_V);                   //?????
            while(1)     //???????
                j=(uint8_t)(Lie_14_V);
                if(j==0xF0)
                    break;
            return(cord_h+cord_l);//????????
    return(0xff);     //????*/
unsigned char KeyPro(void)
switch(KeyScan())
  case 0x7e:return 0;break;//0 ??????????????
  case 0x7d:return 1;break;//1
  case 0x7b:return 2;break;//2
  case 0x77:return 3;break;//3
  case 0xbe:return 4;break;//4
  case 0xbd:return 5;break;//5
  case 0xbb:return 6;break;//6
  case 0xb7:return 7;break;//7
  case 0xde:return 8;break;//8
  case 0xdd:return 9;break;//9
  case 0xdb:return 10;break;//a
  case 0xd7:return 11;break;//b
  case 0xee:return 12;break;//c
  case 0xed:return 13;break;//d
  case 0xeb:return 14;break;//e
  case 0xe7:return 15;break;//f
  default:return 0xff;break;
* [url=home.php?mod=space&uid=247401]@brief[/url]       Main program
* @param       None
* @retval      None
int main(void)
    uint8_t i;
    USART_Config_T USART_ConfigStruct;
    APM_MINI_LEDInit(LED2);
    RCM_EnableAPB2PeriphClock((RCM_APB2_PERIPH_T)(RCM_APB2_PERIPH_GPIOA | RCM_APB2_PERIPH_USART1));
    GPIO_ConfigStruct.mode = GPIO_MODE_AF_PP;
    GPIO_ConfigStruct.pin = GPIO_PIN_9;
    USART_ConfigStruct.baudRate = 115200;
    USART_ConfigStruct.hardwareFlow = USART_HARDWARE_FLOW_NONE;
    USART_ConfigStruct.mode = USART_MODE_TX;
    USART_ConfigStruct.parity = USART_PARITY_NONE;
    USART_ConfigStruct.stopBits = USART_STOP_BIT_1;
    USART_ConfigStruct.wordLength = USART_WORD_LEN_8B;
    USART_Config(USART1, &USART_ConfigStruct);
    USART_Enable(USART1);
    SysTick_Config(SystemCoreClock / 1000);
    while(1)
                                temp=KeyPro();
        if(temp!=0xff)
                                                if((temp>=0)&&(temp<=9))
                                                        txBuf[14]=temp+0x30;
                                                else if((temp>=10)&&(temp<=15))
                                                        txBuf[14]=temp+55;
                                                for(i = 0; i < sizeof(txBuf); i++)
        while(USART_ReadStatusFlag(USART1, USART_FLAG_TXBE) == RESET);
        USART_TxData(USART1, txBuf[i]);
* @brief       Delay
* @param       None
* @retval      None
void Delay(void)
    tick = 0;
    while(tick < 500);
/**@} end of group USART_Printf_Functions */
/**@} end of group USART_Printf */
/**@} end of group Examples */
效果图:
forgot 2023-5-31 08:43 回复TA
挺好的
blust5| | 2023-3-7 14:18 | 只看该作者
不错不错,支持一个
strang| | 2023-3-8 08:29 | 只看该作者
不错,支持下LZ
tpgf| | 2023-4-4 08:12 | 只看该作者
这种矩阵键盘我们能操作的按键就是取决于能使用的io数量吧
qcliu| | 2023-4-4 11:12 | 只看该作者
现在一般什么产品上需要用到这种键盘呢
drer| | 2023-4-4 11:45 | 只看该作者
楼主检测按键使用的是什么模式呢
coshi| | 2023-4-4 12:14 | 只看该作者
当两个按键间距很近的时候会不会产生干扰呢
kxsi| | 2023-4-4 15:07 | 只看该作者
感觉只有高频状态下才会产生干扰  这种情况就是小意思啦
wiba| | 2023-4-4 15:18 | 只看该作者
这种多个按键的情况 我们如何区分是正常按压还是干扰信号呢
比神乐|  楼主 | 2023-4-5 09:45 | 只看该作者
drer 发表于 2023-4-4 11:45
楼主检测按键使用的是什么模式呢
就是扫描
比神乐|  楼主 | 2023-4-5 09:46 | 只看该作者
那要看多近了,我的矩阵键盘感觉比较近了,没有干扰的情况
wangqy_ic| | 2023-4-6 09:09 | 只看该作者
第一张图片,文不对题呀
比神乐|  楼主 | 2023-4-6 10:09 | 只看该作者
wangqy_ic 发表于 2023-4-6 09:09
第一张图片,文不对题呀
我把矩阵键盘的值用串口打印出来,贴的是串口的原理图,怎么叫文不对题呀?
hearstnorman323| | 2023-4-8 21:50 | 只看该作者
哪位给点写APM32F107VC 4*4矩阵键盘的思路,要用中断的
ulystronglll| | 2023-4-8 22:04 | 只看该作者
矩阵键盘如何实现松手检测
alvpeg| | 2023-4-8 22:20 | 只看该作者
按键行列逐级扫描法实现的吧。
minzisc| | 2023-4-8 22:26 | 只看该作者
4×4矩阵键盘的键值怎么求?
bestwell| | 2023-4-9 13:45 | 只看该作者
矩阵按键输入一般用什么模式?
uytyu| | 2023-4-9 13:51 | 只看该作者
矩阵键盘按键gpio怎么初始化设置
tifmill| | 2023-4-9 14:50 | 只看该作者
4*8矩阵键盘行列方式如何扩展?求c程序
