[STM32WBA] 【STM32WBA52CG测评】-3- 蓝牙BLE:LED与button例程分析
1564|2
 楼主| 南来之风 发表于 2023-7-31 15:25 | 显示全部楼层 |阅读模式
STM32WBA52CG是支持蓝牙BLE 5.3,官方提供的STM32Cube_FW_WBA_V1.1.0资料包中提供了一个非常好的入门案例:BLE_p2pServer。
准备材料:
Keil, ST BLE Toolbox
图形化配置时钟:
主要的代码包括在主函数中调用aci_gatt_init()来初始化GATT接口,调用aci_gap_init()来初始化GAP:
  1. /* Initialize GATT interface */
  2.   ret = aci_gatt_init();
  3.   if (ret != BLE_STATUS_SUCCESS)
  4.   {
  5.     APP_DBG_MSG("  Fail   : aci_gatt_init command, result: 0x%02X\n", ret);
  6.   }
  7.   else
  8.   {
  9.     APP_DBG_MSG("  Success: aci_gatt_init command\n");
  10.   }
  11.   /* Initialize GAP interface */
  12.   role = 0U;
  13.   role |= GAP_PERIPHERAL_ROLE;
  14.   /* USER CODE BEGIN Role_Mngt*/
  15.   /* USER CODE END Role_Mngt */
  16.   if (role > 0)
  17.   {
  18.     ret = aci_gap_init(role,
  19. #if ((CFG_BD_ADDRESS_TYPE == GAP_RESOLVABLE_PRIVATE_ADDR) || (CFG_BD_ADDRESS_TYPE == GAP_NON_RESOLVABLE_PRIVATE_ADDR))
  20.                        PRIVACY_ENABLED,
  21. #else
  22.                        PRIVACY_DISABLED,
  23. #endif /* (CFG_BD_ADDRESS_TYPE == GAP_RESOLVABLE_PRIVATE_ADDR) || (CFG_BD_ADDRESS_TYPE == GAP_NON_RESOLVABLE_PRIVATE_ADDR) */
  24.                        sizeof(a_GapDeviceName),
  25.                        &gap_service_handle,
  26.                        &gap_dev_name_char_handle,
  27.                        &gap_appearance_char_handle);
相关的函数调用栈:
main() -> MX_APPE_Init() -> APP_BLE_Init() -> Ble_Hci_Gap_Gatt_Init()
安卓手机安装ST BLE TOOLBOX V1.3.5,这个版本支持STM32WB系列的新产品例程。
打开ST蓝牙助手,找到例程对应的ST ble设备,即下图的p2pS_00。这里的设备名称与官方文档中的有些差异:
  • Open ST BLE Toolbox application: select the P2PS_WBAxx in the device list, where xx is the 2 last digits of the BD ADDRESS.
点击Connect后,串口助手输出如下:==>> Start Ble_Hci_Gap_Gatt_Init function
  Success: aci_hal_write_config_data command - CONFIG_DATA_PUBADDR_OFFSET
  Public Bluetooth Address: 00:80:e1:2a:18:00
  Success: aci_hal_write_config_data command - CONFIG_DATA_IR_OFFSET
  Success: aci_hal_write_config_data command - CONFIG_DATA_ER_OFFSET
  Success: aci_hal_set_tx_power_level command
  Success: aci_gap_init command
  Success: aci_gatt_update_char_value - Device Name
  Success: aci_gatt_update_char_value - Appearance
  Success: hci_le_set_default_phy command
  Success: aci_gap_set_io_capability command
  Success: aci_gap_set_authentication_requirement command
  Success: aci_gap_configure_whitelist command
==>> End Ble_Hci_Gap_Gatt_Init function
Services and Characteristics creation
  Success: aci_gatt_add_service command: P2P_Server
  Success: aci_gatt_add_char command   : LED_C
  Success: aci_gatt_add_char command   : SWITCH_C
End of Services and Characteristics creation
  Success: aci_hal_set_radio_activity_mask command
==>> aci_gap_set_discoverable - Success
==>> Success: Start Advertising
>>== HCI_LE_CONNECTION_COMPLETE_SUBEVT_CODE - Connection handle: 0x0001
     - Connection established with @:7e:3b:af:7b:98:e6
>>== HCI_LE_CONNECTION_UPDATE_COMPLETE_SUBEVT_CODE
-- P2P APPLICATION SERVER : NOTIFICATION ENABLED
点击LED灯的图标,即可打开或者关闭板子上的LED.
串口助手的输出:
  1. -- GATT : LED CONFIGURATION RECEIVED
  2. -- P2P APPLICATION SERVER : LED1 ON
  3. -- GATT : LED CONFIGURATION RECEIVED
  4. -- P2P APPLICATION SERVER : LED1 OFF
在开发板上按BTN1,
  1. Button 1 pressed
  2. -- P2P APPLICATION SERVER : INFORM CLIENT BUTTON 1 PUSHED
  3.   Success: aci_gatt_update_char_value SWITCH_C command
实物图:
附件:ST BLE TOOLBOX
ST BLE Toolbox_1.3.5_Apkpure.zip (5.76 MB, 下载次数: 8)
meiyaolei 发表于 2023-8-7 22:38 | 显示全部楼层
很赞哦
xuanhuanzi 发表于 2023-8-8 10:08 | 显示全部楼层
这个是怎么实现的按键和LED蓝牙控制?
