[STM32F1]
STM32f103 四通道做ADC采样,采样结果异常
890|51
elephant00|  楼主 | 2024-1-4 10:02 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
使用STM32做ADC电流采样,4通道,发现当只有一个通道输入电流和四个通道都有电流输入的时候,采样结果会有差异。比如通道1输入3mA电流,其它通道都输入0mA,这时候1通道采样值为2.975mA,当1通道输入仍为3mA,其它通道都输入20mA,这时候的1通道采样值为2.896mA.检测过运放输出端的电压在两种情况下都没有发生改变,采样值却发生了改变。
有没有哪位大神解决过这样的问题?
驱动代码如下,理论上驱动代码应该不会有问题的
ADC_InitTypeDef     ADC_InitStructure;
   GPIO_InitTypeDef    GPIO_InitStructure;
   ADC_DeInit(ADC1);                                                             //ADC1 DeInit
   RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1 | RCC_APB2Periph_GPIOC, ENABLE);   //ADC1 Periph and GPIOC Periph clock enable
   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_2 | GPIO_Pin_3;//Configure ADC Channel 10-13 as analog input
   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN;
   GPIO_Init(GPIOC, &GPIO_InitStructure);
   /* ADC1 configuration ------------------------------------------------------*/
   ADC_InitStructure.ADC_Mode = ADC_Mode_Independent;
   ADC_InitStructure.ADC_ScanConvMode = ENABLE;
   ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;
   ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None;
   ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;
   ADC_InitStructure.ADC_NbrOfChannel = 4;
   ADC_Init(ADC1, &ADC_InitStructure);
   ADC_RegularChannelConfig(ADC1, ADC_Channel_10, 1, ADC_SampleTime_55Cycles5);
   ADC_RegularChannelConfig(ADC1, ADC_Channel_11, 2, ADC_SampleTime_55Cycles5);
   ADC_RegularChannelConfig(ADC1, ADC_Channel_12, 3, ADC_SampleTime_55Cycles5);
   ADC_RegularChannelConfig(ADC1, ADC_Channel_13, 4, ADC_SampleTime_55Cycles5);
   ADC_DMACmd(ADC1, ENABLE);                                                     //Enable ADC1 DMA
   ADC_Cmd(ADC1, ENABLE);                                                        // Enable ADC1
   ADC_ResetCalibration(ADC1);                                                   //Enable ADC1 reset calibration register
   while(ADC_GetResetCalibrationStatus(ADC1));                                   //Check the end of ADC1 reset calibration register
   ADC_StartCalibration(ADC1);                                                   //Start ADC1 calibration
   while(ADC_GetCalibrationStatus(ADC1));                                        //Check the end of ADC1 calibration
   ADC_SoftwareStartConvCmd(ADC1, ENABLE);                                       //Start ADC1 Software Conversion
DMA_InitTypeDef   DMA_InitStructure;
   /* DMA1 clock enable */
   RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1 , ENABLE);
   /* DMA1 Channel1 Config */
   DMA_DeInit(DMA1_Channel1);
   DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t)ADC1_DR_Address;         //ADC1->DR
   DMA_InitStructure.DMA_MemoryBaseAddr = (uint32_t)ConvData_Tab;
   DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;
   DMA_InitStructure.DMA_BufferSize = ADC_TIMES_ALL ;
   DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
   DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
   DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
   DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
   DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;
   DMA_InitStructure.DMA_Priority = DMA_Priority_High;
   DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
   DMA_Init(DMA1_Channel1, &DMA_InitStructure);
   /* DMA1 Channel1 enable */
   DMA_Cmd(DMA1_Channel1, ENABLE);
probedog| | 2024-1-4 15:18 | 只看该作者
校准ADC
laocuo1142| | 2024-1-4 15:18 | 只看该作者
增加采样时间
flycamelaaa| | 2024-1-4 15:19 | 只看该作者
尽可能减少不同通道之间的相互影响。例如,您可以尝试使用隔离放大器或光耦来隔离不同的通道。
mbutterfly| | 2024-1-4 15:55 | 只看该作者
硬件呢,最后不是都测电压的吗
qintian0303| | 2024-1-4 17:15 | 只看该作者
20mA的电流?
一周一天班| | 2024-1-5 07:47 | 只看该作者
使用DMA的ADC,通常第一个数据非常可能是无效值.建议要么用DMA时做单通道,且采样数>1,丢弃第一个数据.这种方式还适合做过采样.要么多通道不采用DMA.
asdsfgwsafd| | 2024-1-5 08:53 | 只看该作者
上古时期有一招,换采样通道中间间隔一下采一次地
Dick Hou| | 2024-1-5 09:00 | 只看该作者
增加采样时间可解决
xch| | 2024-1-5 09:08 | 只看该作者
先用万用表验证一下说法
储小勇_526| | 2024-1-5 09:27 | 只看该作者
之前做过一个小项目也是ADC采样第一次不准,然后在正常采样上面加一次采样然后丢弃数据的方式,当时也没去深入研究过此问题。
emma2012| | 2024-1-5 14:33 | 只看该作者
belindagraham| | 2024-1-6 16:43 | 只看该作者
如果使用了外部电源或地线,检查它们是否稳定并符合要求
hudi008| | 2024-1-6 17:33 | 只看该作者
查是否正确配置了ADC通道和对应的GPIO引脚
vivilyly| | 2024-1-6 17:58 | 只看该作者
若阻抗过大,则需要延长采样时间以保证转换精度。
jtracy3| | 2024-1-6 19:38 | 只看该作者
检查读取转换结果的代码是否正确,特别是多通道顺序采集时,需要按照指定的顺序读取数据,并等待相应的EOC标志位。
belindagraham| | 2024-1-6 21:16 | 只看该作者
检查ADC输入通道的外部电路连接是否正确,包括参考电压、信号源和接地。
uptown| | 2024-1-6 21:55 | 只看该作者
检查参考电压是否稳定,ADC的输入范围是否正确设置
maqianqu| | 2024-1-6 22:07 | 只看该作者
在执行采样之前,ADC已经过了充分的校准和初始化时间。
wengh2016| | 2024-1-6 22:38 | 只看该作者
ADC的通道、序列、采样时间、数据对齐等配置正确无误
