[DemoCode下载]
PDMA功能进行内存到内存的数据传输
325|2
xuanhuanzi|  楼主 | 2024-2-19 22:56 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
* [url=home.php?mod=space&uid=288409]@file[/url]     main.c
* [url=home.php?mod=space&uid=895143]@version[/url]  V1.00
* $Revision: 4 $
* $Date: 18/07/13 4:20p $
* [url=home.php?mod=space&uid=247401]@brief[/url]    Use PDMA channel 1 to transfer data from memory to memory.
* @note
* SPDX-License-Identifier: Apache-2.0
* Copyright (C) 2018 Nuvoton Technology Corp. All rights reserved.
#include <stdio.h>
#include "NuMicro.h"
#define PDMA_CH    1
/* Global variables        */
uint32_t PDMA_TEST_LENGTH = 64;
#ifdef __ICCARM__
#pragma data_alignment=4
uint8_t au8SrcArray[256];
uint8_t au8DestArray[256];
#else
__attribute__((aligned(4))) uint8_t au8SrcArray[256];
__attribute__((aligned(4))) uint8_t au8DestArray[256];
#endif
uint32_t volatile g_u32IsTestOver = 0;
* @brief       DMA IRQ
* @param       None
* [url=home.php?mod=space&uid=266161]@return[/url]      None
* [url=home.php?mod=space&uid=1543424]@Details[/url]     The DMA default IRQ, declared in startup_M031Series.s.
void PDMA_IRQHandler(void)
    uint32_t status = PDMA_GET_INT_STATUS(PDMA);
    if (status & PDMA_INTSTS_ABTIF_Msk)   /* abort */
        /* Check if channel 1 has abort error */
        if (PDMA_GET_ABORT_STS(PDMA) & PDMA_ABTSTS_ABTIF1_Msk)
            g_u32IsTestOver = 2;
        /* Clear abort flag of channel 1 */
        PDMA_CLR_ABORT_FLAG(PDMA, PDMA_ABTSTS_ABTIF1_Msk);
    else if (status & PDMA_INTSTS_TDIF_Msk)     /* done */
        /* Check transmission of channel 1 has been transfer done */
        if (PDMA_GET_TD_STS(PDMA) & PDMA_TDSTS_TDIF1_Msk)
            g_u32IsTestOver = 1;
        /* Clear transfer done flag of channel 1 */
        PDMA_CLR_TD_FLAG(PDMA, PDMA_TDSTS_TDIF1_Msk);
    else
        printf("unknown interrupt !!\n");
void SYS_Init(void)
    /* Init System Clock        */
    /* Unlock protected registers */
    SYS_UnlockReg();
    /* Enable HIRC clock (Internal RC 48MHz) */
    CLK->PWRCTL |= CLK_PWRCTL_HIRCEN_Msk;
    /* Wait for HIRC clock ready */
    while((CLK->STATUS & CLK_STATUS_HIRCSTB_Msk) != CLK_STATUS_HIRCSTB_Msk);
    /* Select HCLK clock source as HIRC and HCLK source divider as 1 */
    CLK->CLKSEL0 = (CLK->CLKSEL0 & (~CLK_CLKSEL0_HCLKSEL_Msk)) | CLK_CLKSEL0_HCLKSEL_HIRC;
    CLK->CLKDIV0 = (CLK->CLKDIV0 & (~CLK_CLKDIV0_HCLKDIV_Msk)) | CLK_CLKDIV0_HCLK(1);
    /* Enable UART0 clock */
    CLK->APBCLK0 |= CLK_APBCLK0_UART0CKEN_Msk;
    /* PDMA Clock Enable */
    CLK->AHBCLK |= CLK_AHBCLK_PDMACKEN_Msk;
    /* Switch UART0 clock source to HIRC and UART0 clock divider as 1 */
    CLK->CLKSEL1 = (CLK->CLKSEL1 & (~CLK_CLKSEL1_UART0SEL_Msk)) | CLK_CLKSEL1_UART0SEL_HIRC;
    CLK->CLKDIV0 = (CLK->CLKDIV0 & (~CLK_CLKDIV0_UART0DIV_Msk)) | CLK_CLKDIV0_UART0(1);
    /* Update System Core Clock */
    /* User can use SystemCoreClockUpdate() to calculate SystemCoreClock and cyclesPerUs automatically. */
    SystemCoreClockUpdate();
    /* Init I/O Multi-function        */
    /* Set PB multi-function pins for UART0 RXD=PB.12 and TXD=PB.13 */
    SYS->GPB_MFPH = (SYS->GPB_MFPH & ~(SYS_GPB_MFPH_PB12MFP_Msk | SYS_GPB_MFPH_PB13MFP_Msk)) |
                    (SYS_GPB_MFPH_PB12MFP_UART0_RXD | SYS_GPB_MFPH_PB13MFP_UART0_TXD);
    /* Lock protected registers */
    SYS_LockReg();
void UART0_Init(void)
    /* Init UART        */
    /* Reset UART IP */
    SYS->IPRST1 |=  SYS_IPRST1_UART0RST_Msk;
    SYS->IPRST1 &= ~SYS_IPRST1_UART0RST_Msk;
    /* Configure UART0 and set UART0 Baudrate */
    UART0->BAUD = UART_BAUD_MODE2 | UART_BAUD_MODE2_DIVIDER(__HIRC, 115200);
    UART0->LINE = UART_WORD_LEN_8 | UART_PARITY_NONE | UART_STOP_BIT_1;
int main()
    SYS_Init();
    /* Init UART0 to 115200-8n1 for print message */
    UART0_Init();
    printf("\n\nCPU [url=home.php?mod=space&uid=72445]@[/url] %dHz\n", SystemCoreClock);
    printf("+------------------------------------------------------+ \n");
    printf("|    PDMA Memory to Memory Driver Sample Code          | \n");
                         au8SrcArray                         au8DestArray
                       /| [0]  | [1]  |  [2] |  [3] |       | [0]  | [1]  |  [2] |  [3] |\
       PDMA_TEST_LENGTH |            ...            |       |            ...            | PDMA_TEST_LENGTH
                       \| [60] | [61] | [62] | [63] |       | [60] | [61] | [62] | [63] |/
                               32bits(one word)                     32bits(one word)
      PDMA transfer configuration:
        Channel = 1
        Operation mode = basic mode
        Request source = PDMA_MEM(memory to memory)
        transfer done and table empty interrupt = enable
        Transfer count = PDMA_TEST_LENGTH
        Transfer width = 32 bits(one word)
        Source address = au8SrcArray
        Source address increment size = 32 bits(one word)
        Destination address = au8DestArray
        Destination address increment size = 32 bits(one word)
        Transfer type = burst transfer
        Total transfer length = PDMA_TEST_LENGTH * 32 bits
    /* Open Channel 1 */
    PDMA->CHCTL |= (1 << PDMA_CH);
    /* Transfer configuration of Channel 1 */
    PDMA->DSCT[PDMA_CH].CTL = ((PDMA_TEST_LENGTH - 1) << PDMA_DSCT_CTL_TXCNT_Pos) | /* Transfer count is PDMA_TEST_LENGTH */ \
                              PDMA_WIDTH_32 |  /* Transfer width is 32 bits(one word) */ \
                              PDMA_SAR_INC |   /* Source increment size is 32 bits(one word) */ \
                              PDMA_DAR_INC |   /* Destination increment size is 32 bits(one word) */ \
                              PDMA_REQ_BURST | /* Transfer type is burst transfer type */ \
                              PDMA_BURST_4 |   /* Burst size is 4. No effect in single transfer type */ \
                              PDMA_OP_BASIC;   /* Operation mode is basic mode */
    /* Configure source address */
    PDMA->DSCT[PDMA_CH].SA = (uint32_t)au8SrcArray;
    /* Configure destination address */
    PDMA->DSCT[PDMA_CH].DA = (uint32_t)au8DestArray;
    /* Configure PDMA channel 1 as memory to memory transfer */
    PDMA->REQSEL0_3 = (PDMA->REQSEL0_3 & ~PDMA_REQSEL0_3_REQSRC1_Msk) | (PDMA_MEM << PDMA_REQSEL0_3_REQSRC1_Pos);
    /* Enable interrupt */
    PDMA->INTEN |= (1 << PDMA_CH);
    /* Enable NVIC for PDMA */
    NVIC_EnableIRQ(PDMA_IRQn);
    /* Generate a software request to trigger transfer with PDMA channel 1  */
    PDMA->SWREQ = (1 << PDMA_CH);
    /* Waiting for transfer done */
    while (g_u32IsTestOver == 0);
    /* Check transfer result */
    if (g_u32IsTestOver == 1)
        printf("test done...\n");
    else if (g_u32IsTestOver == 2)
        printf("target abort...\n");
    /* Close channel 1 */
    PDMA->CHCTL = 0;
    while (1);
/*** (C) COPYRIGHT 2018 Nuvoton Technology Corp. ***/
初始化设置:
启用 HIRC(High Internal RC,内部高速振荡器)作为系统时钟源,并等待 HIRC 就绪。
将 UART0 时钟源设置为 HIRC,并配置波特率为 115200。
启用 UART0 和 PDMA 的时钟。
配置 PB12 和 PB13 为 UART0 的 RXD 和 TXD。
PDMA 中断处理函数:
定义了一个 PDMA_IRQHandler() 函数,用于处理 PDMA 中断。当数据传输完成或发生异常时,会触发中断,根据中断状态来更新相应的标志位。
主函数:
初始化系统和 UART0。
配置 PDMA 通道 1 的传输设置:
设置传输计数为 PDMA_TEST_LENGTH(64)。
设置传输宽度为 32 位(一个字)。
源地址和目的地址的增量大小均为 32 位。
传输类型为 burst transfer。
将源地址和目的地址配置为对应的数组 au8SrcArray 和 au8DestArray。
将 PDMA 请求源设置为内存到内存传输。
启用 PDMA 通道 1 的中断。
通过软件触发 PDMA 通道 1 的传输。
等待传输完成,并根据 g_u32IsTestOver 的值来判断传输是否成功或是否发生异常。
最后关闭 PDMA 通道 1,程序进入无限循环。
xuanhuanzi|  楼主 | 2024-2-19 22:57 | 只看该作者
在这段代码中,PDMA 负责将 au8SrcArray 中的数据传输到 au8DestArray 中,传输过程中可以处理中断事件,以便及时处理传输完成或异常情况。
