[STM32F1]
有没有串口模拟lin芯片的例程啊
233|4
班杰明|  楼主 | 2024-2-26 17:30 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
标准库hal库都可以
Henryko| | 2024-2-29 23:17 | 只看该作者
这个应该很简单的
裤脚口感好| | 2024-3-31 00:54 | 只看该作者
使用HAL库的STM32串口模拟LIN通信的简单例程:
#include "stm32f4xx_hal.h"
UART_HandleTypeDef huart2;
void SystemClock_Config(void);
static void MX_GPIO_Init(void);
static void MX_USART2_UART_Init(void);
int main(void)
  HAL_Init();
  SystemClock_Config();
  MX_GPIO_Init();
  MX_USART2_UART_Init();
  uint8_t data[8] = {0x00, 0x01, 0x02, 0x03, 0x04, 0x05, 0x06, 0x07};
  while (1)
    HAL_UART_Transmit(&huart2, data, sizeof(data), HAL_MAX_DELAY); // 发送数据
    HAL_Delay(10); // 模拟LIN的帧间隔时间
  RCC_OscInitTypeDef RCC_OscInitStruct;
  RCC_ClkInitTypeDef RCC_ClkInitStruct;
  __HAL_RCC_PWR_CLK_ENABLE();
  __HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE1);
  RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI;
  RCC_OscInitStruct.HSIState = RCC_HSI_ON;
  RCC_OscInitStruct.HSICalibrationValue = RCC_HSICALIBRATION_DEFAULT;
  RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
  RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSI;
  RCC_OscInitStruct.PLL.PLLM = 16;
  RCC_OscInitStruct.PLL.PLLN = 336;
  RCC_OscInitStruct.PLL.PLLP = RCC_PLLP_DIV4;
  RCC_OscInitStruct.PLL.PLLQ = 7;
  if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
    Error_Handler();
  RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
                              |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
  RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
  RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
  RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV2;
  RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;
  if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_5) != HAL_OK)
    Error_Handler();
  huart2.Instance = USART2;
  huart2.Init.BaudRate = 9600;
  huart2.Init.WordLength = UART_WORDLENGTH_8B;
  huart2.Init.StopBits = UART_STOPBITS_1;
  huart2.Init.Parity = UART_PARITY_NONE;
  huart2.Init.Mode = UART_MODE_TX;
  huart2.Init.HwFlowCtl = UART_HWCONTROL_NONE;
  huart2.Init.OverSampling = UART_OVERSAMPLING_16;
  if (HAL_UART_Init(&huart2) != HAL_OK)
    Error_Handler();
void Error_Handler(void)
  // 错误处理代码
#ifdef  USE_FULL_ASSERT
void assert_failed(uint8_t *file, uint32_t line)
  // 用户自定义断言处理代码
#endif
是一个简单的例程,初始化了USART2作为UART通信接口,并使用HAL库中的函数HAL_UART_Transmit周期性发送数据以模拟LIN通信
在STM32的标准库(Standard Peripheral Library)和HAL库(Hardware Abstraction Layer)中,都提供了串口(USART)的功能,可以用来模拟LIN(Local Interconnect Network)通信协议
LIN是一种用于汽车电子系统的串行通信协议,常用于连接车辆内部的各种控制单元。
