[STM32F7]
STM32Fxx之串口DMA配置
812|45
烟雨蒙蒙520|  楼主 | 2024-3-31 23:52 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
简介:
        串口高波特率通讯时需要用DMA传输数据。本文档串口DMA驱动采样stm32标准库版本。
1、时钟配置
//时钟配置
static void USART_RCC_Config(void)
    //使能DMA外设
    RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE);
    //使能GPIO时钟
    RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA, ENABLE);
    //使能串口时钟
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1, ENABLE);
    //使能系统时钟配置
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_SYSCFG, ENABLE);
烟雨蒙蒙520|  楼主 | 2024-3-31 23:53 | 只看该作者
串口GPIO配置
//串口GPIO配置
static void USART_GPIO_Config(void)
    //usart引脚配置
    GPIO_PinAFConfig(GPIOA, GPIO_PinSource9, GPIO_AF_1);
    GPIO_PinAFConfig(GPIOA, GPIO_PinSource10, GPIO_AF_1);
    //配置 Tx pins
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
    GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
    GPIO_Init(GPIOA, &GPIO_InitStructure);
    //配置Rx pins
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
    GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;
初始化串口1
//初始化串口1
void USART1_Init(uint32_t baudrate)
    USART_InitTypeDef USART_InitStructure;
    DMA_InitTypeDef DMA_InitStructure;
    //使能外设时钟
    USART_RCC_Config();
    //配置串口GPIO
    USART_GPIO_Config();
    //DMA映射串口的发送与接收
    DMA_RemapConfig(DMA1,DMA1_CH2_USART1_TX);
    DMA_RemapConfig(DMA1,DMA1_CH3_USART1_RX);
    USART_OverSampling8cmd(USART1, ENABLE);    //高波特率开启8bit过采样
    USART_InitStructure.USART_BaudRate = baudrate;
    USART_InitStructure.USART_WordLength = USART_WordLength_8b;
    USART_InitStructure.USART_StopBits = USART_StopBits_1;
    USART_InitStructure.USART_Parity = USART_Parity_No;
    USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
    USART_InitStructure.USART_Mode = USART_Mode_Tx | USART_Mode_Rx;
    USART_Init(USART1, &USART_InitStructure);
    //DMA配置
    DMA_InitStructure.DMA_BufferSize = MAX_LEN;
    DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Byte;
    DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoreDataSize_Byte;
    DMA_InitStructure.DMA_PeripheralInc = DMA_MemoryInc_Enable;
    DMA_InitStructure.DMA_Mode = DMA_Mode_Normal;
    DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
    //DMA1 channel2配置
    DMA_InitStructure.DMA_MemoryBaseAddr = (uint32_t)test_buffer;
    DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralDST;
    DMA_InitStructure.DMA_Priority = DMA_Priority_Medium;
    DMA_InitStructure.DMA_PeripheralBaseAddr = USART1_TDR_Address;
    DMA_Init(DMA1_Channel2, &DMA_InitStructure);
    //DMA1 channel3配置
    DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;
    DMA_InitStructure.DMA_Priority = DMA_Priority_Low;
    DMA_InitStructure.DMA_PeripheralBaseAddr = USART1_RDR_Address;
    DMA_Init(DMA1_Channel3, &DMA_InitStructure);
    //clear DMA1 TC flag
    DMA_ClearFlag(DMA1_FLAG_TC2);
    DMA_ClearFlag(DMA1_FLAG_TC3);
    //使能串口发送接收请求
    USART_DMACmd(USART1, USART_DMAReq_Rx, ENABLE);
    //使能DMA通道
    DMA_Cmd(DMA1_Channel2, ENABLE);
    DMA_Cmd(DMA1_Channel3, ENABLE);
    //使能串口
    USART_Cmd(USART1, ENABLE);
串口DMA发送
void USART1_DMA_Send(uint8_t *buff, uint16_t len)
    //失能DMA1通道
    DMA_Cmd(DMA1_Channel2, DISABLE);
    //clear DMA1 TC flags
    DMA_ClearFlag(DAM1_FLAG_TC2);
    DMA_SetCurrDataCounter(DMA1_Channel2, len);
    USART_DMACmd(USART1, USART_DMAReq_Tx, ENABLE);
    while(RESET == DMA_GetFlagStatus(DMA1_FLAG_TC2)){}
串口DMA接收
void USART1_DMA_Receive(void)
    //失能DMA1通道
    DMA_Cmd(DMA1_Channel3, DISABLE);
    DMA_ClearFlag(DAM1_FLAG_TC3);
    DMA_SetCurrDataCounter(DMA1_Channel3, MAX_LEN);
youtome| | 2024-4-5 21:37 | 只看该作者
配置DMA传输方向,确保数据从正确的源传输到正确的目的地。对于串口发送,数据应从内存传输到串口;对于接收,数据应从串口传输到内存。
cemaj| | 2024-4-6 12:45 | 只看该作者
配置DMA传输完成、半传输完成和错误中断(如果需要的话),以便在传输完成后进行适当的处理。
mickit| | 2024-4-7 15:04 | 只看该作者
在多任务系统中,需要确保DMA操作的优先级设置得当,以避免其他任务打断DMA传输。
hearstnorman323| | 2024-4-7 17:05 | 只看该作者
DMA支持一些中断事件,如传输完成、传输半完成等。在配置DMA中断时,需要根据应用需求选择合适的中断事件,并编写相应的中断处理程序。
kkzz| | 2024-4-7 21:29 | 只看该作者
如果使用DMA进行数据传输,可以禁止串口相关的中断,因为DMA传输完成后会通过DMA中断来通知。
albertaabbot| | 2024-4-8 16:47 | 只看该作者
设置DMA传输的数据量、数据宽度、源地址和目标地址等。
jimmhu| | 2024-4-9 12:04 | 只看该作者
配置好与串口DMA相关的硬件资源,比如GPIO、时钟源等。
uiint| | 2024-4-9 15:44 | 只看该作者
在使用DMA进行串口数据传输之前,需要配置串口的工作参数,如波特率、数据位、停止位、校验位等。这可以通过设置寄存器或者使用HAL库函数来实现。
youtome| | 2024-4-9 18:22 | 只看该作者
为DMA传输分配足够大小的内存缓冲区,并确保缓冲区地址是正确的。
alvpeg| | 2024-4-9 22:07 | 只看该作者
DMA控制器需要正确配置,包括设置源地址(串口接收缓冲区地址)、目标地址(数据要存放的内存地址)、数据传输方向(从外设到内存或从内存到外设)、数据传输大小(字节、半字或字)、数据块大小以及DMA通道优先级等。
chenci2013| | 2024-4-10 12:24 | 只看该作者
在需要实时处理数据的应用中,可以配置DMA中断。当DMA传输完成时,会产生相应的中断信号,以便在中断服务程序中处理数据。
kkzz| | 2024-4-10 15:40 | 只看该作者
DMA支持不同的数据传输大小,如8位、16位和32位。在配置DMA传输大小时,需要根据应用需求选择合适的大小。
saservice| | 2024-4-11 22:01 | 只看该作者
DMA支持从内存到外设和从外设到内存的双向传输。在配置DMA传输方向时,需要根据应用需求选择合适的方向。
biechedan| | 2024-4-12 09:02 | 只看该作者
在配置DMA之前,需要确保已使能相应的DMA通道和流。通常可以通过设置寄存器或者使用HAL库函数来实现。
benjaminka| | 2024-4-12 15:51 | 只看该作者
在更改DMA设置后,如果需要,可以执行软件复位或硬件复位来确保新的设置生效。
