耐压18V,2A高效率同步降压芯片-ZCC1496替代MP1496
211|0
HPT-Lt|  楼主 | 2024-4-1 16:39 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
FEATURES
 High Efficiency: Up to 98%
 600KHz Frequency Operation
 2A Output Current
 No Schottky Diode Required
 4.0V to 18V Input Voltage Range
 0.6V Reference
 Slope Compensated Current Mode
Control for Excellent Line and
Load Transient Response
 Integrated internal compensation
 Stable with Low ESR Ceramic Output Capacitors
 Over Current Protection with Hiccup-Mode
 Thermal Shutdown
 Inrush Current Limit and Soft Start
 Available in SOT23-6 Package
 -40°C to +85°C Temperature Range
APPLICATIONS
Distributed Power Systems
Digital Set Top Boxes
Flat Panel Television and Monitors
Wireless and DSL Modems
Notebook Computer
GENERAL DESCRIPTION
The ZCC1496A is a fully integrated, high efficiency 2A synchronous rectified step
down converter. The ZCC1496A operates at high efficiency over a wide output current
load range.
This device offers two operation modes, PWM control and PFM Mode switching control, which allows a
high efficiency over the wider range of the load. The ZCC1496A requires a minimum
number of readily available standard external components and is available in a 6-pin SOT23-6 compliant package.
