大家来讨论一下关于s3c4510b移植ucos的问题?(付源码)
1733|4
henry188|  楼主 | 2009-5-12 11:19 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我的启动代码是这样的
vector.s
;System informition
;Flash: 1M x 16bit
;SDRAM: 1M x 4bank x 16bit
ModeMask         EQU    0x1F
SVC32Mode        EQU    0x13
IRQ32Mode        EQU    0x12
FIQ32Mode        EQU    0x11
User32Mode        EQU    0x10
Abort32Mode        EQU    0x17
Undef32Mode        EQU    0x1B
IRQ_BIT            EQU    0x80
FIQ_BIT            EQU    0x40
;RomBaseAddr    EQU        0   ;
RamBaseAddr        EQU        0x100      ;Sdram at 16M
RamLoaderAddr     EQU     0x100      ;@22M
;RamEndAddr        EQU        &200
    GBLS    MainEntry
MainEntry    SETS    "main"
    IMPORT    $MainEntry
;//检查是否使用tasm.exe进行编译
 GBLL    THUMBCODE
    [ {CONFIG} = 16
THUMBCODE SETL    {TRUE}
    CODE32
THUMBCODE SETL    {FALSE}
    [ THUMBCODE
    CODE32   ;for start-up code for Thumb mode
    AREA    SelfBoot,    CODE,    READONLY
    IMPORT    UDF_INS_VECTOR
    IMPORT    SWI_SVC_VECTOR
    IMPORT    INS_ABT_VECTOR
    IMPORT    DAT_ABT_VECTOR
    IMPORT    IRQ_SVC_VECTOR
    IMPORT    FIQ_SVC_VECTOR
    ENTRY
    IF :DEF: |ads$version|
    ELSE
    EXPORT    __main
__main
    ENDIF
ResetEntry
    b    SYS_RST_HANDLER
    b    UDF_INS_HANDLER
    b    SWI_SVC_HANDLER
    b    INS_ABT_HANDLER
    b    DAT_ABT_HANDLER
    b    .
    b    IRQ_SVC_HANDLER
    b    FIQ_SVC_HANDLER
    MACRO
$Label    HANDLER    $Vector
$Label
    sub    lr, lr, #4
    stmfd    sp!, {r0-r3, lr}
    ldr    r0, =$Vector
    ldr    pc, [r0]
    ldmfd    sp!, {r0-r3, pc}^
    MEND
UDF_INS_HANDLER
    ldr    r0, =UDF_INS_VECTOR
    mov    lr, pc
    ldr    pc, [r0]
SWI_SVC_HANDLER
    ldr    r0, =SWI_SVC_VECTOR
    mov    lr, pc
    ldr    pc, [r0]
INS_ABT_HANDLER
    sub    lr, lr, #4
    ldr    r0, =INS_ABT_VECTOR
    mov    lr, pc
    ldr    pc, [r0]
DAT_ABT_HANDLER
    sub    lr, lr, #4
    ldr    r0, =DAT_ABT_VECTOR
    mov    lr, pc
    ldr    pc, [r0]
IRQ_SVC_HANDLER
    sub    lr, lr, #4
    stmfd    sp!, {r0-r12, lr}
    mrs    r0, spsr
    stmfd    sp!, {r0}
    ldr    r0, =IRQ_SVC_VECTOR
    ldr    pc, [r0]
FIQ_SVC_HANDLER
    sub    lr, lr, #4
    mrs    r0, spsr
    stmfd    sp!, {r0}
    ldr    pc, [r0]
;//**********************Copy Code*********************************
SYS_RST_HANDLER
    mrs    r0, cpsr                ;enter svc mode and disable irq,fiq
    bic    r0, r0, #ModeMask
    orr    r0, r0, #(SVC32Mode :OR: IRQ_BIT :OR: FIQ_BIT)
    msr    cpsr_c, r0
    IMPORT    InitSystem           ;//init system
    bl    InitSystem
    adr    r0, ResetEntry          ;Get start address 0
    mov    r3, #(RamLoaderAddr<<16)  ;Destination address(sdram)   0x160 @22M
    ldr    r1, BaseOfROM            ;RO Section
    ldr    r2, TopOfROM
    add    r1, r1, r3              ;RamBaseAddr+BaseOfROM = R1  addr offset
    add    r2, r2, r3                ;RamBaseAddr+TopOfROM  = R2
    ldmia    r0!, {r4-r11}       ;Copy code to Sdram
    stmia    r1!, {r4-r11}
    cmp    r1, r2                    ;size == RO size,r1==TopofRO
    bcc    %B0
    sub    r1, r1, r2               ;r1 - r2 = 0x4
    sub    r0, r0, r1                 ;r0 == BaseOfBSS
    ldr    r1, BaseOfBSS
    ldr    r2, BaseOfZero
    add    r1, r1, r3                 ;RAMbase+
    add    r2, r2, r3
1                                ;copy RW sec
    cmp    r1,    r2
    ldrcc    r4, [r0], #4
    strcc    r4, [r1], #4
    bcc    %B1
    mov    r0,    #0
    ldr    r2,    EndOfBSS
    add    r2, r2, r3
3                                ;copy  ZI
    cmp    r1,    r2
    strcc    r0, [r1], #4
    bcc    %B3
    IMPORT    RemapMemory
    adr    r0, ResetEntry        ;Copy code to befor BaseOfROM
    ldr    r1, =RemapMemory      ;why  reload again?
    ldr    r2, BaseOfROM
    sub    r2, r1, r2
    add    r0, r0, r2
    add    r1, r2, r3
    mov    r2,    #32
    ldr    r3, [r0], #4
    str    r3, [r1], #4
    subs    r2, r2,    #1
    bne    %B0
    ldr    lr,    GotoMain    ;load main addr
    b    RemapMemory
GotoMain    DCD    $MainEntry
    IMPORT    |Image$$RO$$Base|    ; ROM code start
    IMPORT    |Image$$RO$$Limit|    ; RAM data starts after ROM program
    IMPORT    |Image$$RW$$Base|    ; Pre-initialised variables
    IMPORT    |Image$$ZI$$Base|    ; uninitialised variables
    IMPORT    |Image$$ZI$$Limit|    ; End of variable RAM space
BaseOfROM    DCD    |Image$$RO$$Base|
TopOfROM    DCD    |Image$$RO$$Limit|
BaseOfBSS    DCD    |Image$$RW$$Base|
BaseOfZero    DCD    |Image$$ZI$$Base|
EndOfBSS    DCD    |Image$$ZI$$Limit|
;//此处添加Image 搬移代码  two param  Image dst Addr
TIP_SIZE    EQU    256
    IMPORT    ResetMemSet
    EXPORT    trans_to_boot
trans_to_boot               ;BootLoader Image R0 = biosbase 0x10000
                            ;                  R1 = bios load 0x1000
    mov    lr, r1                ; a2 = r1
    ldr    r1, =ResetMemSet    ;载入函数地址
    ldr    r2, BaseOfROM       ;载入RO地址
    sub    r2, r1, r2            ;函数地址-RO地址
    add    r0, r0, r2            ;a1 = r0
    mov    r2,    #TIP_SIZE
    ldr    r3, [r1], #4          ;//将ResetMemSet函数搬移到之前执行  猜想为了主程序初始化,清除主程序运行之前的寄存器配置
    str    r3, [r0], #4
    subs    r2, r2,    #1
    bne    %B0
    sub    r0, r0, #TIP_SIZE*4   ;//先执行一段初始化代码
    mov    pc,    r0                    ;//jump to 0x10000
    END
henry188|  楼主 | 2009-5-12 11:24 | 只看该作者
继续
void main()
    TimerSetup();    //配置硬件时钟并安装时钟向量
    OSInit();
    OSTaskCreate(Task1, (void *)0, &Task1Stk[TASK_STK_SIZE-1], 3);
    DelayNS(50);
    Print("OSTaskCreate ");
    OSStart();
这是启动代码,但是UCOS不能运行?请大家发表一下看法。
henry188|  楼主 | 2009-5-13 13:23 | 只看该作者
没人回答
请问版主,能否解决呢?
Ice_River| | 2009-5-15 11:42 | 只看该作者
呵呵 好像很久没人做这个东西了!
henry188|  楼主 | 2009-5-18 16:34 | 只看该作者
好好研究
我好好研究一下,多谢!
