 /* Copyright(c) 2009 Nuvoton Technology Corp. All rights reserved.                                         */
 #include <stdio.h>
 /*  Include hear file
 #include "DrvTIMER.h"
 #include "DrvUART.h"
 #include "DrvGPIO.h"
 #include "DrvSYS.h"
 #include "assert.h"
 #include "DrvPWM.h"
 /* Global variables        */
 uint32_t volatile complete = 0;
 static int cnt = 0;
 void TMR1_Callback(uint32_t u32Param)
 printf("%d=>%d Hz\n", ++cnt, (12000000 * 100) / DrvTIMER_GetCaptureData(E_TMR1));
 complete = 1;
 /* PWM Timer Callback function        */
 /*  Main Function
 int32_t main (void)
 S_DRVPWM_TIME_DATA_T sPt;
 STR_UART_T param;
 uint8_t u8Timer = DRVPWM_TIMER1;
 UNLOCKREG();
 CLK->PWRCTL_BITS.LXT_EN = 1;
 CLK->PWRCTL_BITS.HXT_EN = 1;
 DrvSYS_Open(32000000);//将时钟设定为32MHz
 while(1)
 if (CLK->CLKSTATUS_BITS.LXT_STB == 1)
 break;
 //DrvSYS_SelectHCLKSource (1);
 //DrvSYS_Delay(5000);
 //DrvGPIO_InitFunction (E_FUNC_CLKO);//将GPIOB.12设置为CLKO输出
 //DrvSYS_SelectIPClockSource (FRQDIV_CLK_SET, 0x02);// 分频源选择
 //DrvSYS_SetFreqDividerOutput (1, 0); // 使能与分频
 DrvGPIO_InitFunction(E_FUNC_PWM01); // 设置GPIO口的PWM01功能
 DrvPWM_Open(DRVPWM_TIMER1); //使能PWM时钟并复位
 DrvSYS_Delay(500);
 /* PWM Timer property */
 sPt.u8Mode = DRVPWM_AUTO_RELOAD_MODE;
 sPt.u8HighPulseRatio = 20; /* High Pulse peroid : Total Pulse peroid = 20 : 100 */
 sPt.i32Inverter = 0;
 sPt.u32Frequency = 600000; // Set 1KHz to PWM timer output frequency
 /* Select PWM engine clock */
 DrvPWM_SelectClockSource(DRVPWM_TIMER1,DRVPWM_HCLK); //选择系统时钟作为PWM的时钟
 //DrvPWM_SelectClockSource(u8Timer, DRVPWM_EXT_12M);
 /* Set PWM Timer0 Configuration */
 DrvPWM_SetTimerClk(u8Timer, &sPt);
 /* Enable Output for PWM Timer0 */
 DrvPWM_SetTimerIO(u8Timer, 1);
 /* Enable Interrupt Sources of PWM Timer 0 and install call back function */
 //DrvPWM_EnableInt(u8Timer, 0, DRVPWM_PwmIRQHandler);
 /* Enable the PWM Timer 0 */
 DrvPWM_Enable(u8Timer);
 //DrvSYS_SelectHCLKSource(0);
 /* Select UART Clock Source From 12Mhz*/
 DrvSYS_SelectIPClockSource(UART_CLK_SET, 0);
 DrvGPIO_InitFunction(E_FUNC_UART0);
 param.u32BaudRate        = 115200;
 param.u8cDataBits        = DRVUART_DATABITS_8;
 param.u8cStopBits        = DRVUART_STOPBITS_1;
 param.u8cParity          = DRVUART_PARITY_NONE;
 param.u8cRxTriggerLevel  = DRVUART_FIFO_1BYTES;
 DrvUART_Open(UART_PORT0, ¶m);
 DrvTIMER_Init();
 printf(" TIMER Sample Code \n");
 /* Set all the TIMER clock source are from 12MHz */
 DrvSYS_SelectIPClockSource(TMR0_CLK_SET, 0);
 DrvSYS_SelectIPClockSource(TMR1_CLK_SET, 0);
 /* Using TIMER0 in E_ONESHOT_MODE, take frequency every 100 pulse */
 DrvTIMER_OpenCounter(E_TMR0, 100, E_ONESHOT_MODE);
 DrvTIMER_Stop(E_TMR0);
 // Don't need to timer start now. OpenCounter automatically starts timer
 /* Using TIMER1 in E_PERIODIC_MODE, counter counter works at 12MHz*/
 DrvTIMER_Open(E_TMR1, 1000000, E_PERIODIC_MODE);
 DrvTIMER_Stop(E_TMR1);
 DrvTIMER_SetPrescale(E_TMR1, 0);
 // Overwrite DrvTIMER_Open() setting
 DrvTIMER_SetCompareValue(E_TMR1, 0xFFFFFF); // Full scale
 /* Install callback "TMR1_Callback" and trigger callback when interrupt occures */
 DrvTIMER_SetTimerEvent(E_TMR1, 1, (TIMER_CALLBACK)TMR1_Callback, 1);
 /* Enable TIMER1 Intettupt */
 DrvTIMER_EnableInt(E_TMR1, E_TIMER_TCAP_INT);
 while(1) {
 complete = 0;
 DrvTIMER_EnableInterTimerTriggerMode(E_TMR0);
 DrvTIMER_Start(E_TMR0);
 //DrvTIMER_EnableExternalEventMode (E_TMR0, E_TIMER_EVENT_FALLING_EDGE);
 GCR->PB_H_MFP_BITS.PB8 = 2;
 while(complete == 0);
 GCR->PB_H_MFP_BITS.PB8 = 0;
